Question about Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS System
My mercury radiant 1000 inverter dose not give backup time. although my battery is new.and also tell me the salutation of increase the charging.give answer urgent pleas.
Dear, Please check following
1. Are you using correct gauge of wire for batteries (Specification mentioned in the manual)
2. You need to charge your batteries at least for 8 hours (as recommended by Mercury)
3. Please place your Inverter in a cool environment (20 to 30 C)
4. Nominal voltage of battery should be 12Volt if using 1x Battery.
Regards.
Posted on Jul 03, 2012
2 Suggested Answers
mitpatterson
  • 74 Answers
SOURCE: ups repair
First Larn some English (rofl) Then try replacing the batteries,
Posted on Oct 11, 2008
Can't find the transfer switch, and could it go bad. Shore power and generator power works to the main panel box, but won't charge coach batteries
although it is possible to do separately most times the transfer switch is internal to the inverter , and the fact you mention that inverter is not charging batteries tells me your fault lay in the inverter all or part of it is not working , look at it carefully these have sometimes two reset breakers on there cases
Jun 01, 2015 | Inverter Electronics - Others
Can i use 150 am 12 va battery with 2000va microtek inverter
You can use any size you want, just your UPS can charge the battery.
You can also add an extra charger in special cases.
If your UPS calculates backup time, you need to tell how big the UPS batteries that you have ...
Aug 19, 2014 | Computers & Internet
Inverter battery charging
Probably batteries have developed high internal resistance.
Replace with new batteries.
Dec 24, 2013 | Computers & Internet
APC Back-UPS ES500. Battery is new replacement UB1280, and battery has charge and runs fine if unit not plugged in. However, if unit is plugged in to power back-up side outlets in unit don't work.
there are 2 parts of a UPS .
the charge side
and (battery is obvious)
the inverter side.
if the charger fails, all is lost. (are the batteries in backwards?)
if the charger works (volt meter tells you that)
then the inverter is bad. (this unit is not full time UPS , but part time, this means it switches over to inverter at power fail.
(on full time sys. inverter runs full time, like the name states)
the unit, you mean the load right.?
the UPS side plugged into a load. and the load is now dead.
the Backup plugs should work if the mains are hot.
if you kill mains, the inverter will fire off, (hear the squeal?)
and give you 500 watts for some minutes, sucking the batteries dry. (see load run time curves)
I used to do service on HUGE UPS systems, some with 100s of batteries. 3 to 5kw too.
on ours there is a port on the rear , we connect and can
check everything "BEST brand" even charge voltage.
did you look on APC site for special software and connections?
the manual does cover trouble shooting, ever read that?
RTM? start there, its online, for sure.
Oct 03, 2013 | APC Back-UPSĀ® CS 500 UPS System
Upc 900 why my overload alarme with no charge on it?
The overload circuit normally collects the current information from the inverter leg. At times when there is an actual overload, the protective circuit picked up the excess current as compared to the calculated value and thus gives an alarm. However at times when the inverter leg is short circuit or a leakage it also gives the same overload current. Is the inverter on when it gives the overload alarm? Please let us know.
Mar 13, 2011 | APC Back-UPS XS900 (BX900) UPS System
Laptop comes on some times and the battery not charging
1.refix the battery
2.fully charge your battery till 100% without any interption
3.now you work with your laptop untll it would be the 0%.
4.Kindly repeat the steps four times.
5.After that you Defently feel,your battery backup will increase.
Nov 17, 2010 | Dell Vostro 1000 Notebook
How to increase notebook battary backup
Hi, the problem is you cant without buying a new battery but what they dont tell you and should tell you is this.
when your using your notebook off the mains you should remove the battery as this keeps it working at its best only use the battery when you need to and after give it a full charge then leave it out whilst you use the notebook on the mains.
leaving the battery in will sap the life out of the battery and you will end up needing a new battery every few months as it just wont hold the charge as it did when new.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 21, 2010 | Acer Aspire 5100-5033 Notebook
Battery not getting charged
you must check the power cord of your ac adaptor too then check if it has a fuse. you can change the fuse or change the power cord.
Sep 28, 2009 | Computers & Internet
My battery is showing fully charged but not giving the backup .hardly giving 15 min backup. after 30% it shutsdown
Would help to tell us how old is it, and what are your useing habits, but I can tell you that modern Lithium Ion batteries allways needs to keep some charge on them, completely depleating them and then rechargeing is no good at all for them, if that happens what you can see is that full charge is getting enough for lesser and lesser times, if this is the case you need this fixed unfordunately you need to get a new battery and try to never let it depleated, that way it will serve you for long years.
Nov 24, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Ups repair
Oct 11, 2008 | Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS...
Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS System Logo
322 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
