Question about Navman GPS
Navman S90i. My car charger has a wiring break fault. I have replaced it with 2 ( non-navman) in car chargers. When plugged in to the charger the screen display reverts to show a break with the gps signal which cannot be corrected unless I unplug the charger. The satnav works without the charger plugged in and is running only on the battery. P.S. battery does not seem to hold charge for long. Satnav was latetest edition when bought.
  • s_g_mackay Oct 14, 2010
    I think that I knew that I would have to purchase a SATNAV charger at four times the cost ! However having an explanation as to why the others would not work was helpful in reaching that conclusion. I now have their product.
    President:
  • 2,777 Answers
Ok well it sounds like the exact voltage is not matching between the non-navman charger and the Navman device itself. This is pretty common actually with third party chargers and can cause many problems with the device, including actually damaging the internal power components of the navigator. You are going to want to get a Navman charger and I am sure the problems will go away.
Thanks
Tim
Posted on Oct 11, 2010
Manual For Model S90i
If you are referring to a Navman S90i you can find the manual here: http://navman.manualnguide.com/manual-navman-s90i
Nov 06, 2013 | Computers & Internet
I have a navman F35/F37 model that I just purchased. Comes with a car charger but no home charger. Can I use my US Garmin charger instead?
Welcome to FixYa!
No, you cannot use the Garmin charger on your NavMan. Even though it is of the same voltage, the mA is most likely different. It may work, but it might also damage your NavMan's electronic board and circuits.
You can use a universal charger that is available the electronic stores but make sure that it is compatible with Navman.
Thank you for using Fixya.
Have a great day.
Jas247
Jul 22, 2011 | GPS
Will not charge, or turn on
Probably the plug on the navman has suffered what we call dry solder joints from inserting and pulling out the charger you need a tech to fix it. soldering is nesessary shouldnt be too expensive I fixed mine its about half an hours work if not too damaged inside
Feb 15, 2009 | Navman F20 GPS Receiver
I have a navman s90i . When i plug the car charger in the screen shows a compuyer runing into a navman via a cable then shuts down then try's to start but goes to the above screen
No solution but exactly the same model and exactly the same problem. When I put the car charger on the unit, it goes off and then comes back on and ust shows a computer as though the only option it can handle via usb is a computer connection. Interestingly, it still charges, but just becomes useless as a satnav as there are no maps, directions or any scree functionality at all.
Nov 22, 2008 | Navman GPS
Navman won!t charge from in car charger or mains adapter but will charge from garmin in car charger
Your Navman will not run in car unless the output on the charger is 1000ma or 1a. you need to buy a genuine charger, motorola phone chargers do not have the output to run the unit
Jul 22, 2008 | Navman F20 GPS Receiver
Manuals
Dear Harry
Please find the manual that you requested at the following link. Simply press left click on the hyperlink and the download will start automatically.
http://www.activegps.co.uk/car-navigation/navman-s90i/navman-s90i.pdf
Regards.
Please rate this solution as FixYa if it was helpfull!
Apr 04, 2008 | Audio Players & Recorders
Battery Charging Navman S90i
The problem is that most of the chargers have the output of 5V/0.5A. The charger for NAVMAN (C30 in my case) has 5V/1A. And that is causing the trouble. The GPS is undercharged and is switching off itself. Buy one which specify the output power: 5V/1A. Hope I solved your problem
Feb 04, 2008 | Navman F20 GPS Receiver
Navman f20
this is because of high voltage in input AC power so u have to replace it
Nov 06, 2007 | Navman F20 GPS Receiver
GPS Logo
337 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
