Question about Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV
Ran leafblower without adding 2 cycle oil , it finally shut off but did not sieze. the motor tried to turn over the next day but wont start again.
  • 885 Answers
If you ran it without oil, the piston and/or cylinder is scored so badly it won't build enough compression to fire. A few of these are worth repairing but usually cheaper and easier to buy a new one.
Posted on Oct 11, 2010
My son added gas/oil mixture into his kids atv and started it bit it shut down in 1min and won't run now.Polaris child atv.what can I do??
2 cycle oil wont hurt it a bit,drain the gas out and start fresh,oil is good for a motor,smell the gas,it may smell bad,which means the oil and gas have congieled
May 22, 2015 | Polaris ATV
Ok, I have a Ford 350 7.3 PSD Ambulance 1997 Model 3 Class 1. I was driving it and it started to shake real bad and lost power. I pulled over, and let it high idle for about 10 to 15 minutes, it idled...
running an engine without oil is like trying to keep your body alive without blood-you probably didn't trip the fuel shut off. I would start by running a compression check-if you have any next would be to see if the plugs are wet with fuel after trying to start and last check to see if spark is getting to plugs-sorry mate-cheers Denny
Nov 04, 2013 | Cars & Trucks
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
Have a 03 matrix with a oilpump promblem I think,bought the car last week ran good next day was drive on highway notice oil lap on and noise from motor ,slowed down light went off.Next day change oil and...
Generally three things can turn the light on. First is the sending unit itself if it's going bad. Next is an obstruction of the pump pickup screen (usually hard carbon deposits). Third is worn engine bearings (usually rod bearings). Best way to find the problem is to have someone put a mechanical pressure gauge on the engine and read the actual pressure. If it's low you need to go into the engine to determine why. if it's normal, replace the sending unit. Senders aren't terribly expensive and you could just buy one and replace the one you have, providing the engine isn't tapping or knocking.
Mar 14, 2011 | 2003 Toyota Matrix
My snowblower just died 2 years old its an ariens 8524 just sold it to a friend and he said it siezed up no iol is this possible or is there a saftey device on the engine that just shuts it down
there is a low oil sensor that does shut down the motor when the oil level gets to low -- fill oil to the correct height and try and start the machine.
now if the motor is infact siezed up and wont even pull ( siezed piston ) then there is a chance that the sensor failed and the machine did run out of oil and siezed up. if this is the case then the piston rings will need to be replaced.
c...
Feb 02, 2011 | Electric Garden
I havw a 2005 90 hp mercury outboard that is locked up by air or some thing.I tryed to start the motor because i ran out of gas and i turned it over til the battery died i recharge the the battery and noe...
I think your starter may have fried before the battery died. You should remove the starter and then see if the motor is seized up. Check your starter if you can jump it off the boat with jumper cables. If it spins freely then try to move the engine. Remove plugs so there is least resistence. If 4 cycle drain and replace oil, check for parts in the oil before adding fresh oil. Then see if it will turn.
Jul 14, 2009 | Boating
Brand new leafblower first use and it stalled after 5 minutes. tried to re-start and the pull string will not move?
hopefully unless it is a 4 cycle? you mixed 2 cycle oil and fuel together as one and put it in the fuel tank? you can use a 40:1 mixture 3.2 oz of 2 cycle oil to 1 gallon of fuel 87 octane will work or 89 octane is better.
if its a 4 cycle (10w-30 for oil) and fuel go in a seperate area?check your manual to verify what they would like you to use
Jul 03, 2009 | Yard Man Garden
Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV Logo
583 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
