Question about Frigidaire Gallery GHSC39ETH Side by Side Refrigerator
Mulitple problems with my side by side
Our frigidaire gallery side by side is a few years old by our estimate (it came with house we bought two years ago). We've had to call a repair guy about 3 times for problems with the fridge not cooling (freezer wasn't cooling and ice in icemaker tray melted and we found a puddle of water on the floor that had leaked from ice dispenser).
First time he had to replace a relay or starter(?), second time he had to replace the compressor, and the third time he replaced a relay(?) with a tubelike thing that has wires coming out of it and says "3 in 1 relay starter" or something on it. The repair guy said that it helps "boost" the compressor. Recently we noticed that the compressor was trying to start, we heard a clicking noise and it wouldn't start. Finally, it started after about 20 minutes. I'm worried that this is going to be an on-going problem, I've been reading that this model has lots of problems/defects and I'm afraid that we're going to keep shelling out cash when it may just be cheaper to replace it.
Any advice, insight or input?
thanks, ER
  • 770 Answers
Sorry to hear you had so many problems. but DONT LET THAT GUY NEAR YOUR REFRIGERATOR!! If he indeed replaced the compresser it should have come with a new start relay and overload that would have been installed at the time the compresser was replaced. the kit he put on was a Hard start kit for compressers having problems staerting up .....but you stated he Just replaced the compresser right? so why should you need a hard start kit installed? the compresser may not be installed properly or the coreect freon charge placed in the unit. or has a leak in his solder joints but by no means should you have to install a hard start kit on a NEW compresser Hope this helps you. BTW Did he give you any Warrty.? if so you should not pay him anything until he fixes the problem
Posted on May 31, 2008
The Clean light on my frigidaire gallery dishwasher is on continuously. The dishwasher will not start. Its over 10 years old.
the problem is in the pcb board which will have to be replaced and cost a few hundred dollars. considering that machine is only designed to last 7 years i would just replace the entire machine.
Sep 26, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire gallery refrigerator freezer and fridge are warm, no air blowing out can hear fan in back, back of freezer wall is iced over. What's wrong with it and how do I fix it?
Replace the timer. It is located in the refrigerator side on the wall behind the temp. contol knobs. Pretty simple job. I has the same problem and a repairman wanted to change the thermostat and the heaters for a few hundred. He never mentioned the timer. Talked to someone else and they suggested the timer and they were right. Haven't had a problem since and it's been a couple of years now.
Sep 17, 2013 | Frigidaire Gallery GLHS66EJSB Stainless...
Our freezer just apparently stopped freezing, but the refrigerator still works. It's a Frigidaire Gallery just purchased a few months ago. Suggestions?
Hello, Thank You for using FixYa. I will be helping you today.All the cooling comes from the freezer side. So if the fresh food side is working then the freezer is only producing enough to allow the temps to be around 38 degrees. Do you notice any frost on the freezer back wall? Its possible its a defrost issue.Can you hear the fan Running in the freezer when the compressor is on? If these all seem fine then I would say you have a sealed system issue. Either a leak or bad compressor. Since its only a few months old call for factory service it should have a one year warranty on parts and labor.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fridge not keeping cool
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 09, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer side works, other side does not cool
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you ti figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
heatman101
May 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
New gallery series frigidaire side by side. 'fridge temp set at 37 degrees, but temp drops to 30 degrees. Everytime I reset to 37 degrees, it eventually goes back down to 30
If it is new (under one year old) then it is under factory warranty, and is not your problem.
Contact your selling dealer and request a service call. There should be no charges to you. Please post back if we are not on the same page as to the age of the machine. Jack
Nov 01, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
Jan 27, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery fridge, 1999. where is the water filter?
What is the model number of the refrigerator. looks like it is in the upper right corner of the fresh food section. If you go to frigidaire.com you can get the owners manual.
Jan 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Where is the water filter on the frigidaire gallery 1999 model?
The filter is in the refer side. Open door and look up in right hand corner of control panel. Push button on right and filter will come out.
Frigidaire Gallery GHSC39ETH Side by Side Refrigerator Logo
142 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
