Question about Sylvania 6427FF TV
I need to switch input on my model 6427ff without a remote
    President:
  • 2,777 Answers
The only way to possibly do this would be if it has input selection allowed through changing channels. If you go down to channel 3 for example and keep going down the channels does it cycle through the inputs? Some Sylvania models allow this, but I don't believe this one does. You will need at least a universal remote to get it working again to select input. You can get one for only $9.36 with free shipping and no tax here, and it has input selection on it of course:
http://www.amazon.com/gp/product/B000W4CH8C?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B000W4CH8C
That will definitely work with your Sylvania.
Thanks
Tim
Posted on Oct 11, 2010
How do i get my LM-1750 remote control to operate my sylvania 6427FF television
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 09, 2014 | Sylvania 6427FF TV
I do not have a remote for my model LG 42lc50c and i cannot get to switch from AV2. Is there a way to do this without a remote?
The button that switches from AV2 is the "Input" button, on the lower right side of the TV. But keep in mind, another Audio/Video source needs to be plugged into another input (located on the back of the TV) in order for this to work. The TV has to recognize multiple input sources to switch between them.
Jan 25, 2011 | LG 42LC50C 42 in. LCD TV
How do you put the tv in game mode without a remote
Follow the steps below to switch your TV to game mode without using the remote:
1. Connect the game system to the TV using the AUDIO/VIDEO inputs on the FRONT of the TV.
2. Switch the game system on.
3. Press the "MENU" button on the front of the TV
4. Use the "CH" UP/DOWN buttons on the TV to highlight the "PICTURE" option. This is the first option so should already be highlighted.
5. Press the "VOL UP" button to select this option
6. Use the "CH" UP/DOWN buttons on the TV to highlight the "GAME MODE" option. This is the first option so should already be highlighted.
7. Press the "VOL UP" button to change the GAME MODE setting to "ON"
The TV should automatically switch to GAME MODE if you are using the inputs on the front of the TV.
8. Press "MENU" to exit and play your games.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 06, 2010 | Sylvania 6427FF TV
How do i get my tv on to the av channels without a remote
The short answer is you can't. Most sets now require the remote control, which has a "source" or "input" button that you need to press. To make matters worse, a universal remote often (usually, in fact) won't have the right codes to switch inputs. There are vendors selling original replacement remotes, but they can be pretty costly.
The longer answer is that on a few TVs you might find a source selection through the on-screen menus. If your set has front panel menu control. Some do, but often the functions are very limited. On a few models of RCA sets you could switch to AV inputs using special channel numbers (00, 98 or 99) but these were older models made when cable systems had fewer channels.
Without knowing your brand and model I can't tell you more. But it's almost certain you'll need a remote. Hopefully you can find a universal remote that will work for you.
Mar 26, 2010 | Televison & Video
I cannot find my remote because I do not use it as I have direct tv remote. Somehow my tv got switched to ant and I need to change my video input. Can I do this on the tv without the remote
Usually you can use the front panel buttons to select "input " or video source.depending on your make/model.Reprogram your direct remote or get a universl remote.
Check link it may help:
www.remotecodelist.com/
Oct 23, 2009 | Sansui Televison & Video
Sylvania 6427FF
hook up comp.or change to input your using.
Jul 24, 2008 | Sylvania 6427FF TV
TV will not turn on
I suspect you may have a short in your horizontal deflection circuit that is keeping your power supply from fully energizing. I do not have any information on this model and suspect that it is actually made by symphonic/Funai corp which puts it in the disposable Tv catageory in my opinion.
Apr 10, 2008 | Sylvania 6427FF TV
Remote Code for Sylvania 6427ff TV
If its a 4 number code, try 0171
Mar 06, 2008 | Sylvania 6427FF TV
Channels
If you have a menu button on the front of the Tv, you could search for an autoprogram or channel search menu and select that. Otherwise a cheap universal remote might be needed. You also want to make sure it is selected to receive antenna and not cable channels.
Sep 03, 2007 | Sylvania 6427FF TV
Sylvania Model 6427FF; Serial V31567989
You probably have a couple of resistors out as well as a shorted D396 Zener Diode that is supposed to keep the voltage regulated at 8.2 Volts DC. With it being a Sylvania brand, it is probably not worth repairing.
Jan 24, 2007 | Sylvania 6427FF TV
Sylvania 6427FF TV Logo
258 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
