Question about Penn Gt Series Levelwind Reels 330GTi
I'm cleaning my Penn cv 6000.Captiva reel, I made sure everything went back together as it came apart.in the spool assy. Lubed the bearings with penn grease. My problem is this , after casting and I'm reeling in ,the spool won't lock in place. help...... I've gone back 3 times reversed(turned over) the friction washers, but nothing works. the reel is very smooth now, but I can't figure this out.. Michael Ross email: mnmmdrnholly@yahoo.com phone :904-239-7471
Benimur
  • 6966 Answers
SOURCE: penn fishing reels
For a Penn GTO 220, pls check this page an exploded view of the GTO220 that details parts and their placement. It is a PDF file and would need Abobe Acrobat Reader to view and print.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 03, 2008
  • 2976 Answers
SOURCE: Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Posted on Feb 20, 2009
  • 2976 Answers
SOURCE: Penn 113 senator
If ythere is a screw directly across from the crank, remove the screw and insert the crank from that side
  • 69 Answers
SOURCE: No instructions for how to feed line onto Penn
put line through ur spreader on the multi[plier then tie a loop not cut off the little bit after tying knot then wind up slowly till it starts to get tight then speed up ur process till u are happy with the amount on ur reel
Posted on Mar 23, 2009
  • 231 Answers
SOURCE: how do i reassemble a penn longbeach 68 saltwater
http://www.trails.com/how_39619_penn-long-beach-fishing-reel.html
Check out the above link
Posted on Jun 24, 2010
Testimonial: "good blowup picture- may help"
Old Penn 209 level wind not turning but spool works is there a part missing ??
There are many small parts within the reel itself and something may have gotten dislodged or someone may have taken it apart and not put it back together properly. There are exploded parts diagrams available at www.pennreels.com to assist you, but they can be very difficult to read. If you take your reel apart, be VERY VERY careful not to lose anything, especially a very small spring that holds the ratchet lock (dog) in place.
Aug 02, 2010 | Sport & Outdoor - Others
Penn gto 220 manual
hi, i dont have one but the penn web site should as when i pulled my alvey apart and to clean and didnt have a clue what was what.they have just about every model manual on the site and you can download and keep it for further use, check it out im sure a brand like penn would have a similar thing.
Feb 28, 2010 | Penn Gt Series Levelwind Reels 330GTi
Drag automatically tightens as line is pulled from spool
Clean and grease the reel. Make sure all washers that belong on inside are installed properly
Oct 31, 2009 | Penn Spinfisher 950SSm Saltwater Spinning...
Require a diagram to assemble 330GTI reel. Reel disassembled as drag not functioning properly
Here you go!
330 GTi Schematic
Make sure the drag plates and drag washers go in correctly or the drag will not work very well.
If you are using braided superline, make sure there is monofilament backing under the line otherwise the braided line will slip on the spool arbor, tricking you into thinking the drag is shot.
Best of luck!
Mike
Sep 26, 2009 | Penn Gt Levelwind Series Reels
The Drag on my 750ss does not work what could be the problem?
This happens after you screw the drag too tight so that the plastic washer under the spool is pressed out. The fix is simple: cut excess of that washer and tighten properly.
May 30, 2009 | Penn Spinfisher 7500SS Saltwater Spinning...
My Penn 114H cant't tighten drag,only to 12 lbs ,when I tighten the I can pull the line at 12 lbs
http://www.pennreels.com/
Call customer service.
Your drag is either worn or it is assembled improperly.
When I need parts or service, I call penn directly. They are the best reels out there as far as I'm concerned. And most of them are made in USA and backed by Penn.
It is the only reel that I care to fish with
Apr 21, 2009 | Penn Gt Series Levelwind Reels 330GTi
Nov 29, 2008 | Penn Gt Series Levelwind Reels 330GTi
Penn Gt Series Levelwind Reels 330GTi Logo
135 people viewed this question
Top Penn Sport & Outdoor - Others Experts
raysaw
ray gallant
Tom Chichester
Are you a Penn Sport and Outdoor - Other Expert? Answer questions, earn points and help others
