Question about Sanyo DS31520 31" TV
Sanyo Model DP42848 42 inch
I cannot get the tv to program the cable channels
  • Anonymous Dec 07, 2008
    A few hours after setting up the television the screen just went blank and now displays no signal. nothing has changed with the setup of my cable, but for some reason the tv will not find any channels when scanning?
Hello - -
Our Sanyo TV (LN-S2641D) started taking more than a minute to "turn on" after pressing the button. This happened using both the remote and on the set itself. Over this weekend it stopped turning on all together. It is only 18 months old. Should I have it repaired? Or is it a lemon that should be replaced? Any suggestions or advice would be appreciated.
Thanks a billion.
- - Jack
Posted on Sep 02, 2008
I bought this tv and it set up the lower 68 channels with no problem. I believe the higher channels (digital cable/HD) you need the cable company's converter box.
hope that helps.
James / nezeray
Posted on Aug 07, 2008
I just bought the Sanyo you inquire about and am afraid of this problem. Did you fix it? How do you like your tv? Wish I could help with your issue and appreciate your time, Pogo.
Posted on Jul 03, 2008
2 Suggested Answers
Slapnuts1975
  • 51 Answers
SOURCE: program an old sanyo tv
You need to go into the menu and set it for cable insted of air/tv. The television is only getting the 2 - 13 because on that setting, its as high as it goes.
Posted on May 20, 2009
I have a sanyo TV and i need to scan cable channels, there is no menu button on it and no remote.I tried a ge universal remote and it. How can I achieve this? Is there an app...
Your GE Universal remote needs to be programmed to match your Sanyo model 32648 TV.
Please visit:
https://jascoproducts.com/support/ge-universal-remote-codes
It will tell you how to determine which version of GE universal remote you have, and how to program your remote.
Then you will need to use the Sanyo manual to perform the scan:
http://www.manualslib.com/manual/317727/Sanyo-Dp26648.html#manual
INITIAL CHANNEL SEARCH is on page 9.
Mar 10, 2016 | Sanyo Televison & Video
Sanyo tv ds25030 how to program chanals 48-96
Your TV must be set in cable mode for channels higher than 69, and your cable provider must allow those channels to be received without a cable box. Menu, Channels, switch air to cable, run auto scan. If it receiving those channels unencrypted, it will find those channels.
Mar 10, 2015 | Sanyo Televison & Video
Program an old sanyo tv
May 20, 2009 | Sanyo DS31590 31" TV
Sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
May 13, 2009 | Sanyo DS27510 27" TV
Tv programming
This TV doesn't have channel labeling. You'll need to keep your cable channel card handy, sorry to say.
Mar 15, 2009 | Sanyo DS31590 31" TV
Menu
I think, Your TV menu item to auto-program has been locked. read its user manaul to unlock it. Many companies gives such lock facility in tv to avoid miss use.
Jun 14, 2008 | Sanyo DS24425 24" TV
Sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
Feb 23, 2008 | Televison & Video
No channels above 47
That works great except I can get the tuner to program any channels above channel47. Is this a limitation of this older model TV yes there is limitation in old tv. is there some setting I can change in order to get more channels using the tv tuner? in INDIA what we do is put a remote control ckt which gives us about 250 channels. of course we replace tuner also called hyper tuner along with remote ckt or replace whole kit which are cheaply available.& serves the purpose. hope this will help
Oct 03, 2007 | Televison & Video
TV problem
Are you using cable to get the picture? If you are, make sure the TV set is in the cable mode,If it is then you most likely have a bad tuner in your set. Good Luck
Mar 21, 2007 | Sanyo AVM-1306 TV
Sanyo DS31520 31" TV Logo
351 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
