Question about Acer AL2017 20" LCD Monitor
How do you get the monitor apart? - Acer AL2017 20" LCD Monitor
  • chriskennedy
    chriskennedy Oct 11, 2010
    There are no little rubber covers (that I can seem to find). I found 2 screws on the back, which I removed. I have the little plastic clasps popped loose everywhere but the very bottom middle (under the buttons) which will not seem to come loose. Thanks for your help!!!!! : )
  • 2,229 Answers
First you take the little rubber covers off of the front of the monitor--I use a dentist's pick. Under the covers there are screws. Unscrew them.
Now VERY CAREFULLY pry the two halves of the bezel apart. They snap together and I find most times the top of the bezel must be pushed inward as you pry the halves apart.
Posted on Oct 11, 2010
  • chriskennedy
  • Art Ellison
    Art Ellison Oct 11, 2010
    There may be screws that are lower down on the back by the hinges--try them. Some computers have removing the hinges as part of the operation.
How to take apart
problem is in the flash light inverter logic card. the HT power choke is gone weak. replace this and also check the supply capacitors are conected to this circuit
Jul 04, 2014 | Samsung SyncMaster T260HD flat panel TFT...
How do I remove the back of a Dell LCD monitor to clean
Here's a video I made repairing my E178FPb and I show how to take it apart. I assume it comes apart the same as yours.
Feb 14, 2014 | Dell E173FP 17" LCD Monitor
How to open an LCD monitor.
I personally haven't worked on this monitor, but most monitors are held together with plastic clips on either side of the casing.
After removing the stand and all other screws, you will need to use a small flat-head screwdriver (or something of that nature) to pry apart the clips. Find the crease/gap in the plastic where the casing of the monitor comes together. Insert the screwdriver and gently twist and pry the casing apart. When you hear the first click/snap indicating the first clip has come apart, follow the gap with the screwdriver, prying it apart each time you reach an area of resistance. Do this all the way around the monitor.
Keep in mind that after you open up all the clips, the LCD panel and boards may be screwed either the front casing or most likely the back casing. So you must first unscrew the mounting screws inside the monitor to remove the back cover. Also be careful unhooking ribbon or speaker cables that attach the circuit boards of the monitor to the front casing.
Jan 12, 2010 | Gateway FPD2275W LCD Monitor
How to take apart viewsonic w2235 moniter?
There are about 8 screws on the back of the monitor. Remove them, and the monitor's back panel will come off, then you can remove more screws to get further into the monitor. By the way... what are you trying to do by taking your monitor apart?
Oct 19, 2009 | ViewSonic VX2235wm LCD Monitor
Monitor in "off mode" cant get it to be in "on mode"
did you go into dispaly properties and "extend my desktop"
Jul 26, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Take apart monitor
there are clips on the opposite end try pressing the back cover inwards
Jul 14, 2009 | Acer AC713 17" CRT Monitor
No image
I had a similar problem with a Dell monitor after a power outage. I pulled the monitor apart and found a connector not completely seated. I think that something internal has happened to your monitor. It could be an internal fuse or something. If you don'r feel comfortable taking it apart, find a reputable service center.
Sep 13, 2008 | X2Gen MG19MY 19" LCD Monitor
Getting the monitor apart
It is clipped on, or there is a hidden screw underneith a sticker or something.
They make these things hard to disassemble for a reason. There is very little you can do one you've got it open. There's almost nothing inside that can be serviced by any normal user.
Jan 23, 2008 | Sceptre X9G-KomodoV (Black) 19 inch LCD...
To dismantle the dell e153 15 inch monitor
The front and rear of the case is held together with latch and hook type fasteners, this is how I cracked mine apart.Remove the 4 screws holding the stand on the back of monitor, start with either bottom corners and insert a flat head screwdriver or similar soft object such as a wooden popcicle stick into the crack and work your way up the side to the top, then across the bottom, and up other side to top, I then ease the case apart at the top with no effort.
Oct 01, 2007 | Dell E153FP 15" LCD Monitor
Acer AL2017 20" LCD Monitor Logo
202 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
