Question about Roper Refrigerators
I have a Roper model RTATXKQ refrigerator that drips water from the freezer into the refrigerator compartment near the back where the air flows. I found some ice buildup on the freezer bottom about 1/8" thick and removed it thinking I solved the problem. The ice however has built up once more and is dripping into the refrigerator again. Can you help? Thanks, Paul
  • Roper Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 12, 2010
Dripping water
Mine had the same problem today. I found the drip tray under the screwed on panels in the freezer was full.
There is an evaporative tray above the compressor in back, and feeding that was a drain pipe that was blocked with crud. Removing and cleaning the cap made it flow freely again. Hopefully that fixes it.
Jan 23, 2014 | Sanyo SR-1030W Top Freezer Refrigerator
Model et18pkxfno1 serial eg4024334 type c18tfa97\r\nwater drips into refrigerator compartment somewhere from freezer (inside). Occurs daily. Tried to adjust temp in both refrigerator and freezer but...
The problem is that your fridge's drain line (which is located in the freezer) is iced over. So water can't drain out of the freezer when your fridge enters it's defrost cycle. The freezer and drain line needs to be defrosted by hand. Or you can unplug the fridge and open the doors for a 2-3 hours. Eventully, if no action is taken, the ice build up in the freezer will block the cold air flow to the refrigerator compartment .
Feb 19, 2011 | Whirlpool Refrigerators
I have a Roper refgigerator RTATXKQ built Feb 2005. Ice buildup from the freezer is melting and dripping into the refrigerator compartment in the back where the air flows. I found a thin ice buildup and...
The problem is the drain is clogged. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½" in diameter this is the drain tube. Try using a turkey baster to flush out the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. After cleaning mix a 50 -50 solution of baking soda and water and run some down the drain tube this should help prevent future clogs. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Oct 11, 2010 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Water drips in refrigerator. I think it has to do with the defrost feature, which seems to drip only periodically.
You are correct. the defrost drain is most likely plugged up causing the water to drip into the refrigerator through the air returns in the ceiling of the fridge.
To access the defrost drain hole in your model you will have to remove the back wall from the freezer compartment and possibly the floor of the freezer as well if it has the floor air flow tray.
The repair is quite simple- remove as much of the ice as possible (i use a putty knife to pull it up in as large chunks as possible and then use a moistened dish towel to pick up the smaller pieces.
Use a turkey baster with some hot water to "plunge" the drain hole out. The drain hole is located in the bottom center of the evaporator opening.
Jun 15, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
RS25AWXEW01 side x side refrigerator has leak at ice maker water drips into frozen ice chute and leaks onto floor and also in freezer compartment
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Aug 13, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Water dripping into refrigerator from cooling area
Your defrost drain in the freezer is frozen closed.
Turn the fridge off.
Remove the rear freezer panel.
Remove the visible ice.
Use a hair dryer to thaw the drain hole in the back of the freezer in the center of the drain trough.
Mar 12, 2009 | Refrigerators
Refridgerater
It could be the defrost thermostat located on the condenser coil on the left side of the fan in the freezer compartment... or else it could be the defrost timer located in the refrigerator behind the dome cover... defrost the freezer and make sure the drain tube is not blocked nor the air passage which blow cold air from freezer to refrigerator compartment below. Water should drip from freezer down hole into tube to an evaporator pan on the top of the compressor near the floor in the back. Make sure the tube is free flowing by pouring some hot water down it before restarting refrigerator. Rarely the defrost heating element shorts, but a simple continuity test will determine if that is o.k. Make sure the refrigerator is uplugged before checking any of these areas... there's 120 volts all about and with water and ice it can cause quite a jolt!
Oct 05, 2008 | Roper RT14DKX Top Freezer Refrigerator
Refrigerators Logo
113 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
