Question about Hobart Handler 140 Mig Welder
Wire feed is sticking when I try to weld. If I increase friction it only jams the wire. I have never cleaned of replaced the liner. Is this my problem? I don't use this welder that much.
  • jdh45890 Oct 17, 2010
    "sticking" to what? the part you're welding? Or in the gun? To eliminate the gun liner lay out the whip straight and try to feed wire thru it without a tip in the gun. If if feeds ok then it is probably the tip.
    Sergeant:
  • 223 Answers
Cleanliness is important when it comes to Mig welding. Any rust, dirt, dust, oil is liable to be deposited in the whip liner. If it's just a dirty liner you can try cleaning it with a solvent that doesn't leave an oil deposit (electric motor cleaner, brake cleaner, that sort of thing) compressed air and flexing of the whip.
Make sure your whip hasn't been crimped, if it has then no amount of cleaning will restore it to operation.. a new liner is the only reasonable answer.
It's possible that a bad tip can cause feed issues. Miller type tips are the worst, in my experience, sometimes you just get a tip that will weld to the wire when the current passes between them. I've worked in shops where I might go through three tips in five minutes and then hit one that would last all afternoon. If the wire sticks and you can hold the gun up and rotate your wrist and you feel a 'pop' and the wire jumps out of the tip then just change the tip out. Excessive roller pressure with a tip that's sticking to the wire can really make trouble for you. Nozzle dip is your friend sometimes with tip sticking issues.
Copper clad wire is not particularly friendly to liners, the copper is liable to flake off in the liner. I use bare wire, I bag the wire in a plastic bag on the feeder and I wrap a scratcher pad on the wire just before it goes into the feeder and I find that I have few feed issues. Wire that has even a trace of rust should be discarded as it will both fill your liner with rust and give poor quality welds.
lp
Posted on Dec 24, 2010
I have a Lincoln sp135+ changed liner tip and put a new spool on it and added gas.... The wire stopped feeding but drive wheel keeps turning... any he would be appreciated Thank you Bryan
indicates that the liner has a groove worn in it and the wire is jamming in that groove
replace the liner from the drive wheel to the nozzle
Jan 13, 2018 | Lincoln Welding Tools
My welder won't feed wire it sounds like it's trying to energize but can't. A couple of times it fed through but wouldn't feed to weld so I had stick weld. What happens if the liner has a restriction?
first unscrew the tiny tip at very end of torch (can be hot)!! then try to feed wire thru handle,gently shake cable as you do helps to feed wire thru cable , if successful you have allowed the amps to get too high for the feed rate (slow) and melted the tip closed , these tips are replaceable from miller and are not expensive
Aug 09, 2016 | Miller Multimatic 200 MIG TIG & Stick...
Wire feed moter problem ?
erratic wire feed speed can be from worn inner liner in the lead
the inner lining is like a close woven spring and with the welding wire moving through it , it will wear a groove in the liner that jams the wire as it moves through
Really evident if you change from a small gauge wire to a slightly larger wire
rust in the liner from wire that has not being used for a while will also cause the erratic feed
the fix is to clean the wire prior to going into the liner or replace the liner for both
Aug 06, 2015 | Welding Tools
Wire feed is not stable on Hobart handler 135
is this a lower end machine ? the cheaper machines take the power from the welding transformer to power the feed motor and as a result the feed isn't stable, also is the wire liner and tip in good condition if not replace them, try blowing through the liner with compressed air to clear any dust from the wire
Sep 17, 2013 | Hobart Welding Tools
Wire is broken off inside wire feed tube and wont pull through tube either
Hi:
You need to replace the gun's liner. To avoid this problem you must decrease the voltage or increase your wire speed.
A new liner will cost you around 20 buck at your nearest Praxair welding store.
If this was useful to you please vote. Thanks
Apr 15, 2011 | Lincoln Electric Handy MIG K21851 Welder
Wire feed works intermittenly,welder has not been used in along time.
Intermitten welds require a faster wire speed, or to reduce the voltage a little bit. Try increase the wire speed. if it still doing that, then check that your drive rolls are not slipping, check the right size rolls for the wire, check the tension on the wire tensor, no more than 3, and final, check that the wire run smooth all along the liner and a out the contact tip. Probably the liner it's all clogged due to rust or dirt.
Jan 15, 2011 | Welding Tools
My welder no longer produces high quality welds
You could have a poor ground clamp connection. Check that. also increasing the gas flow will cause turbulence at the weld, this can have a negative effect on weld quality.
Check your connections, check your liner, actually, replace it if you haven't recently.
Feb 15, 2010 | Lincoln Electric LE 83180 Century...
Lincoln weld pak 100. The wire jams in the hose. it is feeding pro... the wire jams in the hose. it is feeding properly but the wire gets hung up a foot or 2 before the nozzle. More the wire jams in the...
In your other post I had mentioned installing a Teflon liner that would help with the wire.It narrows the gap in the hose and gives it a more easier feed.
Jan 10, 2010 | Saws
Will not feed wire when trigger is pulled. feed
1. Wire jammed
2. Out of wire
3. Not enough tension
4. Wire liner worn
5. Wire disconnected internally
6. Contact tip clogged
Aug 06, 2009 | Welding Tools
I have a pro-mig 135 and while welding the arc surges up and down along with the wire feed.the feed is real jumpy and will not keep a constant smooth puddle
You need to clean and perhaps replace the liner in your wire feed gun. The liner gets tiny bits of dirt and **** up inside. After even normal use for a while, the liner itself gets worn away and makes the wire stick rather than smoothly poke into the puddle.
Liner maintenance time is also a good time to check the feed wheels for wear, look for the little ruts in the wheel to be dull or obviously worn at the edges. Wipe off the drive shafts and housing as long as you've got the drive wheels off anyway. :-)
All of this should have a nicely illustrated procedure in your user manual.
The other thing that can cause problems is that the welding wire can sometimes get rusty enough to be sticky inside the liner. Roll off a good length of wire (2 or 3 wraps around the spool) and inspect it for any sort of funkyness. If in doubt, blow out the liner, change the wire, and weld something to see if it works better.
Regards,
Carl
Jan 24, 2009 | Welding Tools
Hobart Handler 140 Mig Welder Logo
195 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
