Question about Aiwa AV-DV75
Dv75 turning on, but no sound
I have tested all of the speaker connections, tested the receiver from every input, and despite the fact that it turns on and 'appears' to function properly, there is no sound being emitted from the speakers. Any suggestions?
    Problem Solver:
  • 9 Answers
Common to 95% of all audio equiptment is a "Protectiion" feature which turns off the speakers when the electronics or the speakers are in an adverse state, You have only one thing you can do at this point, and that is to check the speaker wiring to see it is not SHORTED, and check the speakers to verify they are all working properly. Other than that, any other cause for the receiver to be in protection is internal and would require technical intervention. Repairs of this nature may run in the area of $75 ~ $150 or more. If you find that your receiver does need service, my advice based on age and development since yours was built would be to replace as technology has superceeded this receiver at a far lower cost than what you paid for this one. I advise you in this manner based on 38 years of audio and video service and I always want the owner to leave the transaction or service smiling, I hope this helps you.
PEACE,
Bri
Posted on Jun 10, 2008
Receiver "appears" to be in PROTECTION! This is NOT a customer repair if (and probably is) the receiver is in protection. Generally under these conditions, the unit will require parts replacement and depending on the extent of the damage, may cost as much as $150 or more. Strong consideration my be given to replacement of the receiver as new units are getting more and more "affordable". Sorry to levy this information on ya' but I'm advising you based on 38 years of servicing audio and video and I am trying to pursuade you to get "more bang for your buck" and leave you smiling in the end.
PEACE,
Bri
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
I have AIWA AV DV75. It turns on but no sounds. Would you tell me the solution if you have an idea?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-AV-DV75-Receivers-manual/id/1076dj797/t/2/
Page 22
We can't make assumptions that all is connected and selected properly.
Feb 19, 2011 | Aiwa AV-DV75
I have an Aiwa av-dv75 receiver that keeps clicking on then off. I have everything disconnected and still clicking on and off. Has anyone found a solution for what looks to be a common problem?
This most likely means you might have some speaker wires crossed in the inputs somewhere. It shuts down to make sure it protects itself from burning up.
Dec 08, 2010 | Aiwa AV-DV75
Only front and center speakers work, not surround.
If by white noise do you mean the test tone generated by the receiver? If so, this is actually pink noise and it is internally generated by the receiver. I would make sure either in the menu or on the remote that you haven't accidently turned off the surrounds and double check the wiring to the surrounds. Good luck.
Feb 15, 2010 | Aiwa AV-DV75
Turned stereo on and turned volume all the way up and could just verly hear it comeing out of the speakers
assuming same issue does not happen if you connect a headphone to your receiver - can you check your speakers' connections - it should be straight not crossed for each and in case speakers are properly connected to your receiver - can you test the audio/sound with internal test audio rather than connected device (ie player) - if this is ok and there is no sound/audio volume settings on connected device - change the input the device connected and test again.
Sep 01, 2009 | Pioneer VSX-456 Receiver
Will not turn on
Page 23...
There may be a short circuit in the speaker terminals.
Disconnect all speakers and try it. If it works troubleshoot each speaker one at a time. Shorted wires are indicated.
© Disconnect the AC cord, then correct the speaker connections.
May 04, 2009 | Aiwa AV-DV75
Speakers stopped working.
More than likely you have blown outputs, as the sound you hear when you touch the leads to the terminals is the DC offset of the power supply being routed through your speakers...accordianman
Jun 09, 2008 | Aiwa AV-DV75
Broken receiver
I bought my AV-DV75 from Best Buy about 10 years ago and it still works. However it did stop working a while back. I don't know why. I alsmost threw it away. But I unplugged it for a couple of days, then plugged it back up and it came back on. It is still working. Maybe that will work for you.
PS
my center speaker quit working recently. If you decide to sell your AIWA speakers will you please email me?
Aug 14, 2007 | Aiwa AV-DV75
AV-DV75 center speaker works surround speakers do not
If all others had been fine before this problem arose, and you are sure that you haven't changed anything in your amplifier's channel selection menus, the problem might be deeper to solve! Try these out; 1-If the amplifier has a test menu to check out all channels plugged in, activate it. You must be able to get sound, which is like rustle, from each speaker. 2- Check your plugs, cables etc. be sure that there isn't any short circuit 3- Grab your amplifier's remote control and find the "channel selection menu" that allows you to increase and decrease volume levels for each speaker independently.
Apr 15, 2007 | Aiwa AV-DV75
Aiwa AV-DV75 Logo
119 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
