Question about Refrigerators
Water in the bottom of the refrigerator under the crisper drawers
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101,,.
Posted on Oct 12, 2010
Water in left bottom crisper drawer
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Jun 11, 2017 | Whirlpool Refrigerators
Water in bottom left crisper drawer and under drawer
I'm sorry to say that it sound as though your door gasket may no longer be sealing correctly.
For me, it's simply a task of getting a replacement gasket for that make and model.
To remove the old one you would, simply, peel the inside of the gasket toward the outside of the edge of the door revealing the mounting screws. Remove these screws all the way around and replace with the new one in the same fashion...
The reason that I recommend this is that humid air outside of the refrigerator can seep past a worn gasket and condense on the inside surfaces making its way to the bottom and into those drawers.
Feb 16, 2014 | Whirlpool Refrigerators
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Frigidare 1812 frig-water under crisper drawers
clogged drain line somewhere in fridge plumbing
Feb 21, 2010 | Refrigerators
Whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Dec 29, 2009 | Refrigerators
I have water under the crisper drawers in my fridge. The water at the bottom on the ?condenser does not seem to be draining what can I do? Thanks Mary
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilshultz
Dec 01, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator has water under the crisper drawers
There is most likely a plugged drain in the freezer section. The easist solution can be to empty the refrigerator and unplug it over night. If this is not possible then the back or bottom should be removed to allow access to the drain and a hair dryer can be used to make defrosting go faster. still takes a while, if there is access in the back of the unit that can be the cause of the plug.
Jun 19, 2009 | Refrigerators
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
