Question about Logitech Cordless Desktop Optical 967320-0403 Keyboard
I have a EX 100 wireless keyboard and a wireless mouse. I changes the batteries in the mouse and the next day it said I needed to replace the keyboard batteries as well. I did that on Friday and when I came to work today (Monday) the keyboard doesn't work. The mouse works but I can't type anything. Is it because of changing both sets on batteries? The batteries in the keyboard are new.
    President:
  • 8,637 Answers
Press the Receiver button (and the lights will startflashing.
Then if the Keyboard isn't working, press the small RESET/CONNECTbutton on the back of the board to connect the keyboard to thereceiver.
If the MOUSE isn't working, push the small RESET/CONNECT buttonon the back of the mouse to connect to the receiver. Then theyshould work okay. Hope this helps. Bud
Posted on Oct 11, 2010
  • Weldon Dube'
    Weldon Dube' Oct 20, 2010
    If that didn't work its possible you have the batteries in wrong. Make sure the positive is in the right direction. Bud
  • Logitech Master
  • 13,433 Answers
You just need to reconnect the wireless keyboard, to do this, press on the connect button on the receiver. then on the bottom of the mouse, then press on the receiver again and then on the button in the bottom of the keyboard.
Everything should work normally again, if you just had good batteries in and they are in the right way. If the keyboard still doesn't work check the batteries and try again.
What is logitech 810-000755 used for or what does it do
810-000755 is the part number for the Logitech C-bt44 USB receiver for the Logitech Cordless Desktop EX 100. See http://support.logitech.com/en_us/product/cordless-desktop-ex-100-product/faq#link_19321 . This is the section of the FAQ on using the EX 100 with other USB receivers. The receiver lets select Logitech wireless keyboards and mice communicate with the computer that has this device plugged in. The 810-000755 also works with the Logitech cordless desktop (keyboard/mice) EX 110, and the MK 300. There may be other keyboards and mice that communicate with this receiver. However, newer Logitech keyboards and desktops (keyboard/mice) may not use this receiver.
I hope this helps. Note: the EX 100 uses 2 alkaline AA batteries in the keyboard and 2 alkaline AA batteries in the mouse to communicate with the receiver. I believe the other keyboards and desktops that can communicate with the 810-000755 also use alkaline batteries which last ~6 months before they must be replaced.
Aug 21, 2017 | Logitech Computers & Internet
Can i connect my wireless logitech keyboard with out the mouse
Yes sir I have had one of those Logitech before and what you have to do it's not magic it's a signal that it gets to let him let him know that it's working properly and you probably need to reboot the signal and then it will probably work properly
Feb 06, 2018 | Logitech Cordless Desktop EX110...
Mouse works keyboard does not. changed batteries, reconnected, restarted laptop still the same result
Did you push the connect button on the back of the keyboard? It should be someplace close to where you put the new batteries in.
Hope this helps
May 23, 2011 | Logitech Cordless EX 100 Mouse
As I remember it, the EX 100 was plug and play on my XP PC. The batteries are NOT a problem - as they check OK. I periodically have both mouse and keyboard FREEZE After restarting XP computer everything...
Connect an additional wired keyboard to your pc. And when the freeze happens check if the pc responds at all, using the wired keyboard. If its not responding , its an indication of a faulty PSU or motherboard.
Mar 08, 2011 | Logitech Cordless EX 100 Mouse
I have a logitech wireless mouse and keyboard (7 months old)- I recently moved my computer and when I hooked verythign back up it no longer works- I have tried everything from restarting, plugging the...
Underneath the mouse and the keyboard will be buttons labeled "Connect", you will need to resync with the receiver plugged into your computer. Press the connect button on each device in turn and it will attempt to resync.
If this does not work the next thing is to test with fresh batteries, however it is unlikely that both the keyboard and the mouse would run out at the same time.
Finally try with the receiver right next to the keyboard/mouse, sometimes other devices can interfere with wireless signals (WiFi networks, microwaves, vacuum cleaners etc...).
Feb 28, 2011 | Logitech Cordless EX 100 Mouse
WELL, I HAVE DE EX 100, SO SUDDENLY THE RED LIGHT TURNED OFF, SO I CAN0T USE IT ANYMORE, I TRIED PRESSING THE CONNECT BUTTON, AND THE KEY BOARD IS ONLY WORKING AND THE MOUSE DOESN'T HAVE THE RED LIGHT...
Hello, try fitting new batteries in the mouse. The top rear half of the mouse slides back and lifts off. You will need 2x AA batteries. Use good quality ones (like Duracell) Regards, nicam49
Feb 17, 2011 | Logitech Cordless EX 100 Mouse
I have two sets of this product and when they are both being used at the same time one will stop working completely, help.
These units work on a radio frequency and if you have two units close together they will interfere with each other. The one that is closer to the receiver or has a stronger battery will usually win the battle. The next problem is they both use the same frequency and it can not be changed. The best option is to get a different brand of wireless keyboard or try a bluetooth keyboard. Bluetooth keyboards operate differently and can be used near each other.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 28, 2009 | Logitech Cordless EX 100 Mouse
Logitech ex 100 mouse doesn't work
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 22, 2009 | Logitech Cordless EX 100 Mouse
Logitech wireless keyboard and mouse (ex 100) won't connect
The mouse and keyborard have to be in direct view of the reciever. Even a small obstruction will effect the operation
Nov 02, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Logitech Cordless Desktop Optical 967320-0403 Keyboard Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
