Question about Refrigerators
It keeps on running! - Refrigerators
  • jkuznar Oct 14, 2010
    What solution? My husband took care of the problem. Please cancel! Do not bill me monthly. Cancel! Jenny Keating Thank you
    IM sorry my husband took care of the problem! You took to long to answer our question! Please cancel! I do not want to be billed monthly! thank you jenny keating.
The first thing to check is the seals. When they get any crud on them or disintegrate and tear, it will constantly run. The second thing is to make sure your freezer is full. The last thing to look at is your freon gas. Check to see if its running low, when it runs low the motor keeps running to compensate.
Click on this link below to read more:
http://answers.yahoo.com/question/index?qid=20080710181150AAUME3u
Posted on Oct 14, 2010
  • Anonymous Oct 14, 2010
    How did your husband correct the probelm?
    President:
  • 4,070 Answers
Hi! May I ask what keeps on running? Thanks!
Posted on Oct 11, 2010
My mule will not keep running. Stopped suddenly after good start. Replaced the fuel pump. Still will not keep running. Fires. Then stops. Fires on starting fluid. What could it be?
When you say it fires with starting fluid can you keep it running with the starting fluid or does it just fire while cranking the starter then stop when the key is turned to run if it keeps running with the starting fluid then you still have a pump problem or the filter could be plugged or the carb could be bad but if it'd fuel injection then it might just not getting enough pressure fuel injection takes high pressure
Sep 18, 2017 | Cars & Trucks
Outboard starts but won't keep running
If you keep sqeezing the fuel bulb, will it keep running? If it runs then fuel pump problem. Also check for a clogged fuel filter.
Jan 04, 2015 | Boating
2004 mazda b 2500 turbo diesel keeps running after switching off
Check how long it runs for after switching off as there may be a delay in the system that keeps the motor running until the turbo slows and cools down then shuts off. If it has it will be about 2-3 minutes. Another reason that diesels keep running is that there is oil getting into the air inlet side of the turbo from a failed seal and this acts as fuel going into the cylinder and as diesels do not need ignition spark they will keep running. have it checked out by a specialist who medals in turbo repair and sales.
Jul 18, 2013 | Cars & Trucks
I have to keep choking the motor to keep it rinning
try running some carb cleaner added to a full tank of gas. Run the whole tankful through.
Mar 24, 2013 | Husqvarna Garden
1994 evinrude boat motor keeps blowing fuse. motor keeps running but once shut off won't restart. also while motor is running the tilt won't work work
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 27, 2012 | Cars & Trucks
Datsun 180b wont keep running
Replace the ballast resistor on the coil.
Mar 19, 2012 | Datsun 1600 Cars & Trucks
The car will turn on and stop running a few minutes later. Will not keep running
was the car battery dead for a while??
If so the car actually forgets how to idle.
try to keep it running with the gas or keep trying over and over
Jul 06, 2009 | 1996 Mercury Sable
Tiller will not keep running
Have you tried squirting gas into carburetor to see if it will keep running? If that keeps it running as long as you are squirting gas in it, your carb need to be cleaned out/repaired.
May 26, 2009 | Troy-Bilt Garden
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Won't Keep Running
Replace the fuel line and filter first. If that doesn't solve the problem it is a crankshaft seal.
Mar 14, 2009 | Garden
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
