Question about Lexmark Z640 InkJet Printer
It will not print and the cardriges are moving really fast across the printer
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 91 Answers
Hello.
It seems like your cardtridges is emty or dry...Boil water in a cetle and put some in a sourser the just put the cartridge's head part in the water ,so that the ink is starting to flow out again.Take a bit of toilet paper then and push the head against the paper towl.when you see a good foot print from the cartridge .Try to put it back in the machine again.and see what happen.otherwise get new cartridges
Posted on Oct 11, 2010
The printer prints White on Black
try to self clean your printer then test print
Jun 05, 2013 | Canon Pixma MX410 All-In-One Printer
There are 3 small dots that print across each page when I print. How do I get rid of those?
what type of printer, laser or inkjet. are the dots spaced down the page or across?
I suspect you have a laser and the dots are down the page in which case it is most likely the fuser unit or the cartridge.
To verify which, you can send a print to the printer and open the printer half way through. If the dots are present before the paper goes through the fuser (the hot bit that fixes the toner to the page) then its the catridge, otherwise it will be the fuser unit. you will need need to replace which ever part is the cause
Sep 02, 2011 | Brother Office Equipment & Supplies
My mp500 probably has a print head alignment problem everything prints green
Take off all your Cardrige and bang it up on a plane paper see if color ink stick into your paper if not change your Cardrige
Sep 29, 2010 | Canon Pixma MP500 All-In-One InkJet...
Not able to print the yellow color through inkjet printer.
Your color cardrige is damage, your color cardrige needs to be replace
May 28, 2010 | HP DeskJet 1220c InkJet Printer
Prints coming out green and orange
the print head is defective or ink cardrige is defective, (perhaps is non original replace ink cardrige)
Dec 20, 2009 | Canon i9100 InkJet Photo Printer
Hp 6980 will not print. can't feed paper
please check the detailled instructions on the HP support site:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00569593&lc=en&dlc=en&cc=us&product=467982&lang=en
Check for the cartridge compatibility for your product, select HP SureSupply
Remove and install the cardriges once following the instuctions.
Sep 01, 2009 | HP Office Equipment & Supplies
Will not print blue
clean head cardrige and calibrate color cardriges.
Jun 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Substitute ink cartridges no longer work
I have the same problem and many Canon users , i try a trick that mayby solve this and last but not least ... Mayby the only cheap solution for all print users !! jumping-smiley-004.gif
My problem .. was looking for a cardrige solution ( IP4300 ) because 4 (of 5) cardrige leds are dimmed off and need to be replaced . I just order 5 adopters and 5 new with chip for all the five cardrige . Problem : The chip uses memory and that makes it very hard to reset . But i have thinking .. mayby this is somthing ..
What you read is new, experimenting with this idea is all at your own risk !
Here is a simple markable solution Unique !!
A - First you need all 5 brandnew cardrige with chips ( please keep all ink preventions inplace )
B - You need is a 4 poles - 1.50 / 2.50 meter +/- telephone cable
C - (five) (new) OEM cardrige without chips
D - Tin and a somthing to solder
E - 5 old chips for adopting the connection outside the printer
F - A box for the 5 new chiped cardriges
Procudure :
1 ) Make of 1,5 / 2,5 meter a 5 pcs of 30 / 50 centimeter
2 ) Solder on each lengt a old chip (this is functioned as a adopter) but first remove all the (useless) electronic components and place them on the cardriges
3 ) Solder the other site of the cable to each new chiped cardrige cq / toner that still sits on the new orriginal cardriges ( our make a alternative contact if you dont want to solder )
4 ) Tape the 5 new cardriges together and *
5 ) Put it in the box and give it a save unremovable place **
6 ) Put the (5) oem cardriges with the empty old chips ) in the right ink location(s)
* ) Looking into the new cardriges : this needs a box because of the intervering with the led this not only makes it nicer but mostly because of the outside light influence .
** ) Dont turn the kid upside down our shake it . If you do , the led indicates that the cardriges are empthy our low and the countdown proces for the chip will start !
I wait for arrive of the new ones, anybody who try make a handshake !
See you soon
John
Netherlands
Jan 29, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon Pixma MP780 Printer - black 3e fails to print
installed a new Print-Head, but that was no changes. I use refill ink, and it seams the BlackInkTank is not exactly on the Printhead and it is Air in the Pipe, i take the Printhead and the Ink-Cardridge in the Bathroom, and press the Ink-cardrige on the Printhead and take a hard breath and blow in the Air-Holes of the Ink-Cardrige until black ink come out of the Printhead, reinstall in the Printer, end it works well.
sorry about my bad english
Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Lexmark Z640 InkJet Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
