Question about HP Compaq Presario V5000Z Notebook
Presario v5000 laptop
The keyboard and touchpad don't respond. I f I plug a regular keyboard and mouse into the USB ports, they work.
Any suggestions?
Thank you
Michael
  • 186 Answers
First of all, check in the Device Manager if you find any yellow ! marks indicating that the drivers are not properly installed or corrupted.
If you find any entries, try reinstalling those drivers by right clicking on the entries with yellow ! mark and selecting Update Drivers.
Additionally, try reinstalling the drivers for the Keyboard and Touchpad from within the Device Manager by following the steps listed below :
Please follow the steps to go to Device Manager :
Right Click on My Computer and select Properties in the list.
Now go to Hardware tab and click on the Device Manager button.
Device Manager window opens in a seperate window.
Now click on the [+] mark next to Keyboards to expand the tree.
In the list that appears, right click on Standard 101/102-Key or Microsoft Natural PS/2 Keyboard and select Uninstall.
Now, restart the computer once the uninstallation is completed so that the default keyboard drivers will be automatically reinstalled.
Now, go back to the Device Manager and click on the [+] mark next to Mice and other pointing devices and if you find any entry with Synaptics Touchpad pointing device, right click on it and select Uninstall and restart the Notebook.
Now, download the Touchpad Drivers from the Notebook for XP from the link below :
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34473.exe
Copy and paste the link in the address bar of a new internet explorer window and press Enter.
Save the file in My Documents or Desktop and double click the file once it is saved.
This will install the Touchpad drivers in the Notebook.
Now, try removing the USB keyboard and mouse to use the Keyboard and Touchpad of the Notebook.
If you are still unable to use the Keyboard and Touchpad of the Notebook, probably, there are internally damaged....need to get them checked by technicians.
Posted on Sep 15, 2008
Toshiba touchpad doesnt respond after 2 minutes
This issue could be a few things. 1. Make sure your driver for the mouse and keyboard are updated. 2. The mouse pad may be going bad. 3. There may be an issue with the motherboard. I would recommend checking your driver first. Then replace the mouse pad. You can also pick up a wireless mouse and plug the usb that comes with it into a usb port if you are not comfortable tearing apart your laptop.
Jan 11, 2014 | Toshiba Computers & Internet
Describe your compaq presario cq60 touchpad not
after rebooting my Compaq Presario CQ60 laptop the touch pad does not work and I have to use a plugged in a mouse
Mar 09, 2010 | HP Compaq Presario CQ60-249US Notebook
Touchpad will not work
Hello, seems like a problem with the touchpad, first disable and enable the touchpad with the button which is located at the top of the touchpad, the corresponding LED should change from blue to orange and vice versa. If this doesn't solve the issue, reinstall the driver for the touchpad, you can find this by searching for 'recovery manager' in the start bar. Next step is to select 'advance options' and choose reïnstall hardware driver, there should be an option called 'Synaptics touchpad driver' select and install. kr Gijs
Sep 10, 2009 | Compaq Presario CQ60-220US PC Laptop
Compaq Presario CQ60 touchpad problem.
The touchpad on my Compaq Presario CQ60 has stopped responding
Aug 17, 2009 | Compaq Presario CQ60-220US PC Laptop
Compaq presario sr2150nx keyboard and mouse wont work
maybe the devices are both defective or you mistakaly plug it to the wrong ps2 port.check its pin.
May 05, 2009 | HP Compaq Presario SR2150NX PC Desktop
Broken USB Port compaq presario v5000
The hardware USB ports are identical for both versions. Only the software and hardware controller are different.
I suggest you use a temperature controlled soldering iron with a fine tip for this job.
You need to dismantle the laptop completelt to remove the motherboard from the plastic case. Take a note of where the screws come from because they may be different lengths. Don't apply excessive pressure on the plastic case else it will break, start from one side and work around each side, the plastic case has catches to hold the halves together.
Start by rmoving the hard drive, CD/DVD drive, battery etc.
Jan 12, 2009 | HP Compaq Presario V5000Z Notebook
Hi my name raji I have a laptop ... compaq presario v5000 wel its touch pad scroll is not working what can i do
their is only one solution for compaq v5000 as you have to buy a usb port small mouse.
i mean that you have to purchsae a new mouse.
George_raji
i want to ask a question that wheather you touchpad has been coloured off by using it.
if yes than tell me yes?
Jan 03, 2009 | HP Compaq Presario V5000Z Notebook
Aspire 5101wlmi
If you have got a usb mouse plug it into your computer then go to control panel>system>hardware>device manager and go to pointing devices. Right click on the + sign next to keyboard and touchpad, click on uninstall. Then reboot your machine, take the usb mouse out. Windows will reload the correct drivers for the keyboard and touchpad as new hardware and your problem should be resolved.
I hope this helps
Nov 12, 2008 | Acer Aspire 5101WLMi Notebook
Touchpad doesn't respond
MY SOLUTION - Hello, I have Compaq Presario V2000 Laptop and at once my touchpad stopped working.
So i rebooted it several times but it still didn't work.
Then i detached the battery from the laptop and let it like that for 5 min. I attached the battery again and the touchpad was working again.
So, try the simplest solutions first before you start messing with complicating solutions.
Good luck !
Nov 11, 2007 | Acer Aspire 5610-4648 Notebook
Trouble with touchpad & dvd functions
you probably need to reinstall the drivers.
HP Compaq Presario V5000Z Notebook Logo
387 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
