Question about Sony PlayStation Portable (PSP) Console
Psp switch is broken
The switch on my psp is broken and i have noticed that the switch can come off . But when i took the switch off I saw a yellow thing that had a square hole in the middle of it and the switch looked as if a little piece snapped off. And now when i push the switch up it just comes back down, like its disconnected from ware it was so post to be connected to
  • 53 Answers
You should get it fixed. You can get it fixed on ebay.com just type in psp repair and you will see people who fix them.
Posted on Nov 11, 2008
How do I fix the spring on the switch for a 10 inch ryobi miter saw? I can hear it rattling around and the switch won't work. Also plastic screws holding handle together are broken.
Hello Anonymous,
First locate the model number of your Ryobi Miter saw... then search Google for Ryobi Miter saw replacement parts... one result I got is below:
http://www.mastertoolrepair.com/ryobi-power-tool-parts-ryobi-miter-saw-parts-c-873_895_937.html
Try that link, select your Ryobi saw model and zoom into the provided drawings so you can locate the switch, screws, and spring (if needed). The part numbers are supplied and you can order them online easily on that same link... Then just repair your saw with the new parts. As you already noticed, the saw is easy to disassemble and get access to the parts for repair. Have fun and good luck...
RYOBI Miter Saw Parts
Mar 10, 2015 | Ryobi 10 In Miter Saw With Laser
The saw will not start. It's plugged in. I've confirmed power at the outlet with another tool. It ran trouble free for about a year. Then it stopped. I took it to an authorized warranty...
No offense, but are you certain the safety plug us in the switch? The little yellow child proof key.
Other than that, are you certain it is wired correctly, ie 110 or 220?
Sep 17, 2011 | Ridgid Saws
I can't find the cheats for soul calibur broken destiny for psp that i saw on a video of youtube.Can somebody please tell me if they know some cheats
One of the best sources for legit and up-to-date for cheats/codes is gamefaqs.com
The soul calibur PSP game can be found here http://www.gamefaqs.com/psp/959863-soulcalibur-broken-destiny/cheats
Don't be too sure on YouTube videos, there are a lot of fakes out there.
Good Luck.
Mar 09, 2011 | Video Game Consoles & Games
I have a skill 3400. I flipped the on/off button and the motor started and then stopped immediately I figured it was the switch as this happend before but I put in a brand new switch and it still won't...
There is no fuse in the Skil 3400 saw. Check your cord, then brushes. You might have a broken brush spring, causing one brush to hang up in brush tube. Possibly there maybe a lot of sawdust holding a brush up.
Feb 09, 2010 | Skil 10" Table Saw 3400
Have Rancilio Rocky for about 3 months. Noticed grinds around base from time to time. Yesterday picked up machine, saw accumulation. Tapped base, more came out. Took off base, about 2 oz. of grinds inside....
Hi There could be a piece broken around the chute where it comes out of the grinder and enters the grounds chamber. There is a rectangular opening in the plastic that can get broken causing the grounds to enter the machine.
Feb 07, 2010 | Rancilio Rocky Doser Espresso Grinder...
I took my daughters psp apart to change the case that was broken and now i can' get it back toghter...
if your having problems putting the cover back on check the version of the psp because theres the psp fat, 2000, or 3000(slim) that should help you out
Aug 10, 2009 | Sony PlayStation Portable (PSP) Console
I own a Jet Left Tilt Cabinet Saw Mdl 708663PK. The on-off switch seems to stick and does not always start the saw. The saw runs normally when it starts. When it does not start, the on switch depresses and...
I took the front cover off of the switch and noticed the portion of the switch the off button contacts was fully depressed and would not slide back to its proper position. I lubed (silicone) the slide portion of the off switch and cycled it manually to free it up and distribute the lubrication.
Feb 17, 2009 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
New psp will not charge
If you have multi meter at home make sure that voltage is coming from the adapter.
if the psp have some battery backup check the battery level when u put on charge...
Go to Settings>> System Settings>> Battery Information>>
If you dont have the equipments to check go your nearest electronic service center or sony showroom. Take your charger with the psp so that they can find out the exact problem
Jul 28, 2008 | Sony PlayStation Portable (PSP) Console
Bad Vibrations
new washer time ..inner basket has broken "spider" support on rear new basket and outer tub with bearing will both probably need replacing yellow straps were probably part of original shipping pins
May 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
No sound
Try to restore to default setting, ( on setting menu) if it not work you'll need reflashing your psp under recovery menu.
hopefully this helps. Pls post back should you need additional information.
Jan 07, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
