Question about Ingersoll Rand Electrical Supplies
Ingersoll rand g25 generator is running normally, but generating no power. what are the likely causes and solutions?
CarlGehrke
  • 169 Answers
SOURCE: Generator doesn't excite with small power tools.
Somewhere on the Generator is an Idle Control switch, turning this to the off position will stop the generator idling down in the first place. You'll need to do this to use tools that don't draw enough current to trip the idle control system into revving the engine.
It may say just how much current you have to draw in the manual (hint, hint).
Posted on Nov 29, 2008
ccrozier_agr
  • 36 Answers
SOURCE: generator runs producing no power
Hi, remove the electric control panel & check the wiring as sometimes we have seen the wires coming off the voltage change over switches.
Also some of these units you can check the connections in the rear of the alternator & if it has brushes that they are not stuck.
Another problem we have had is the trip switches have went faulty but still switch operates ok, they need to be checked with a probe type tester for conductivety.
CarlGehrke
  • 169 Answers
SOURCE: Honda EM 2500 Generator
I posted a general tutorial on troubleshooting this problem here.
Rate me?
Carl
Posted on Dec 05, 2008
mamicheddy
  • 79 Answers
SOURCE: McCulloch fg6000mk: generator motor runs, no power.
You need to trace out the power wires the come out of the genset. They will end up on a breaker. With a volt meter measure both sides of the breaker. If one side has voltage and the other side doesn't, then your breaker is opened. Press the breaker in closed to see if it actually closes. If it don't then you will need a breaker. However, if no voltage is being produced, it is possible that the voltage regulator let go.
Posted on May 09, 2009
  • 251 Answers
SOURCE: Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
Posted on Oct 20, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Why our g25 ingersoll rand mobile disel generator when start it cause overspeed and shutdown immediately
Check the mag pickup screwed into the casing where the flywheel is. Check for dirt and metal chips
Oct 06, 2014 | Ingersoll Rand Used Towable G25 21kw...
HOW TO SWITCH 6260 TO 60HZ
6260 isn't a model number for any Ingersoll Rand generator.
Generally, though, if you have a generator that generates 50Hz and you want it to produce 60Hz instead, you adjust the governor to increase engine running speed by 20%... if the engine will tolerate that speed. The first thing you need to do is find out what speed the engine runs when it's under normal load. If that speed can't safely be increased 20%, then the generator head has been built strictly for 50Hz and there's nothing you can do about it except run a UPS between the generator and your load.
If the engine speed IS low enough to safely increase by 20%, then that's what you do.
Jul 03, 2014 | Ingersoll Rand Electrical Supplies
Need a manual for a ingersoll rand pnld11-28-lp
Pnuematic No Loss Drains PNLD II
Use link - it's for your product.
'Contact Us' link available, it may help?
Good Luck
Jan 31, 2014 | Ingersoll Rand Pnld Ii-28
Oil seperator
Get the model and serial number located to the right side of the fuel tank 1/2 way up on the radiator and call someone who deals in Ingersoll rand (now Doosan). If you remove the old one you can read the numbers off the bottom of it.
Aug 29, 2013 | Ingersoll Rand Electrical Supplies
I have a 50KW genset and I am in need of a new radiator, could you point me in the right direction?
There should be a tag on the radiator of who the radiator manufacturer is and they should be able to supply you with a replacement or try contacting an Ingersoll Rand distributor for help http://www.ingersollrandproducts.com/IS/Category.aspx-am_en-31039.
Jul 05, 2011 | Ingersoll Rand Electrical Supplies
I have a G-235 generator that has a computerized starting system. As soon as I start it, it revs up really high without any electrical draw on the generator instead of idling. Can you give me some...
Your generator should be running @ 1800 rpm if its diesel . I have a 40 kw diesel generator and it starts up and runs a full 1800 rpm with no load . Thats how there designed because they have a 4 pole alternator. Hope this helps.
Mar 16, 2011 | Ingersoll Rand Electrical Supplies
Where can I find a oweners manual and spec. sheet to download for a ingersoll rand g80 generator ?? I am wanting to wire a outside box with several plug on it.. 120v
Ingersoll Rand generator business was purchased by Doosan so you could probably email them and ask for the manual. Here is their web site:
http://www.doosanportablepower.com/americas/Pages/home.aspx
Here is the generator info
http://www.doosanportablepower.com/americas/products/generators/Pages/PowerSource%20G80.aspx
good luck
Mar 06, 2011 | Electrical Supplies
Ingersoll-Rand G25 generator had been operating normally. Output stopped today with generator running and 120/240V breaker closed. Continuity test shows a short between ground/neutral and A phase with...
A ground to neutral short should not stop the machine and may be how the breaker panel was wired. Single phase 240 volt power just has two hot lines and the neutral just center taps the transformer winding supplying the 240 volts. The twin breakers that supply this voltage, should both trip even if only one line has a short on it. Check the resistance of L1 and L2 lines to neutral that feed the motor with the breakers off. Each should read nearly equal resistance which usually is only a few ohms when correct. Make sure the motor turns freely by hand as a locked compressor can certainly pop the breakers. If the compressor appears locked, remove the cylinder head(s) and try to turn again. If still locked, one of the connecting rods may have broken in the crankcase. The other problem could be a broken valve assembly in a head. If the motor has a capacitor start and/or run capacitor, it can cause a breaker trip because the motor cannot start with a defective capacitor. Hope some of this helps!
Jun 14, 2010 | Ingersoll Power Force By Rand PF235 Touch...
Electrical Supplies Logo
144 people viewed this question
Top Ingersoll Rand Electrical Supplies Experts
cwradio73
Tom Chichester
Rhonda Webster
Rhonda Webster
Are you an Ingersoll Rand Electrical Supply Expert? Answer questions, earn points and help others
