Question about Microsoft Xbox 360 Console
My xbox 360 wont work propley with hard drive on.with hard drive off works fine .it takes ages too load games up with hard drive on sometimes tells me too cleen disk wen the same game works fine no proplems with hard drive off .av you heard of this problem befor thanks tristram
    Genius:
  • 1,175 Answers
Can you reformat the hardrive through the Menu options?
If so , try that.
Posted on Oct 11, 2010
When I play Black ops it loads but never goes past the black screen after you press play game. I have an Xbox 360 white and I'm wondering is that the problem. When i took it to my uncles 360 it worked...
I have never heard this issue before. You probably have a lager issue then what can be resolved here and might face future issue in the future. Is this the only game you are having issues with?
Seeing that you mentioned you have purchased a hard drive then I would recommend you install the game to your hard drive and try play after that. This will resolve any issues possably of your disk drive possably getting hung up during gameplay.
follow these instructions to get your game installed on your hard drive:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press Y on your controller.
  5. Select Install to Hard Drive.
    A progress indicator appears while your game is being installed on your hard drive.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Jul 17, 2011 | Microsoft Xbox 360 Console
My xbox 360 games wont load. What can i do to fix that
your xbox 360 disk drive is messed up and you need to clear cache to do this go to system settings then memory then hover over your hard drive and clic ky then click clear system cache if this does not work contact xbox at 1-800-4my-xbox
Jan 16, 2011 | Microsoft Xbox 360 Console
My extra content won't load
I've had the same problem. Delete from the hard drive and re-download. Should work fine after this.
This game(along with several others) has some issues when trying to access the hard drive. Could be missing data in the download file, a corrupt area in the hard drive, etc. Removable hard drives, although convenient, are not the most reliable. Like I said, I had the same issue and this solved my problem. :-)
Jul 15, 2009 | Bethesda Softworks Fallout 3 for Xbox 360
60 gb hard drive wont let me play my game.
Thats very strange, are you able to rip game to hardrive?
May 13, 2009 | Microsoft Xbox 360 Console
Wont read disk
i had that problem i took it back to the shop and swapped it now it works fine
Nov 29, 2008 | Microsoft 20GB Hard Drive for Xbox 360
How to put x box games on to X box 360 hard disc
you have to download them them from live or go to xbox.com and get a list of old games that work on 360
Nov 04, 2008 | Microsoft Xbox 360 Console
X BOX 360 AGES TO LOAD WORKS FINE
Is it a clean disk? Try a brand new game
Oct 24, 2008 | Microsoft Xbox 360 Console
Slow
There are multiple reasons why this could be happening. The most odvious would be the disk but you say that it looks fine. Next i would try to reset the xbox hard drive cache which involves a couple steps. "To perform the function, access 'memory' in the system blade, and then highlight the hard drive. Now press: Y, X, X, LB, RB, X, X. The following message should appear: "Do you want to perform maintenance on your Xbox 360 storage devices?"" After doing that does it improve the load times in the game? If that doesn't help it is most likely either the drive or the saved game. To test the drive try playing another game. If that works fine and loads at the normal pace then it is your saved game might need to be deleted. (If you have or can get ahold of a memory unit move the saved game to that and then delete it from the hard drive and test it. Afterwards you can then move it back over.) How that helps.
Oct 21, 2008 | Microsoft Xbox 360 Console
Error E 68
This behavior occurs when an Xbox 360 Hard Drive hardware failure occurs.
1. Turn off the console. 2.
Remove the hard drive. For more information about how to attach or remove the Xbox 360 Hard Drive 3.
Reattach the hard drive, and then turn on the console. 4.
Obtain the latest automatic update for the Xbox 360. To do this, connect to Xbox Live. 5.
If you continue to experience this behavior, contact Xbox Customer Service.
Oct 13, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
