Question about Canon Cameras
Mirror locked up at 125th or slower and infill flash does not flash. At faster speed it works fine. The display on top of camera goes virtually blank and battery display flahes a sif it battery was exhausted. If shutter release is pressed again then camera goes back to normal 'ready to sheet' mode.As flash is synced to 125th I suspect that the flash is the problem (or maybe it is just coincidence) I have tried cleaning, used lenses and put in a brand new battery. Any clues?
  • 2 more comments
  • Bernabia May 31, 2008
    This is NOT a digital but a film camera Canon Eos 100/Elan bought about 10 years ago and working up until a few months ago.
  • Bernabia Jun 01, 2008
    Sorry but the manual does not answer the problem. I still think that the flash is a part of the problem. Help
  • Bernabia Jun 02, 2008
    Sorry but still no answer
  • Bernabia Jun 05, 2008
    I have tried with a flash unit attached. Still the same two problems. Mirror locks up at 125th and slower. In addition neither the fill-in flash nor a full flash unit will work. The flash gun does work as I have tested via test button.
    Genius:
  • 1,665 Answers
Canon EOS Elan/EOS 100 - an unofficial manual.
http://photonotes.org/manuals/eos-elan/
Posted on May 31, 2008
How do I fix the speed of my Jensen JTA-460 turntable? I've tried numerous records that previously worked perfectly, but now the speed is too slow regardless of what album I try.
Could be the belt for the pulleys is stretched a little, or there is something making it slip, or the potentiometers were set incorrectly from the factory . It is normal to have one for each speed. It is unknown if you can access these from the bottom of the unit. Slippage is less likely to be caused by something oily, since it would alternate the speed faster and slower and yours seems to have worked then reached a constant slower speed. Do your 45's and 78's play ok? (yeah I know, does anyone have a lot of 78's on hand)
Your model does not have an outside pitch control to fine tune the speed faster or slower. Another Jensen model JTA-230 does. Entry level turntables such as yours are not speed accurate reliable. After reading reviews on your turntable, it's possible that the belt is the problem. If the slow speed problem had happened from the start, it would be safe to say that the speed wasn't calibrated correctly and you could have returned it and perhaps had better luck with another one but because it worked fine at the start and then now plays slower, it's either the belt or the potentiometer for the 33rpm speed has somehow changed.
May 23, 2017 | Jensen Audio Players & Recorders
I have a D60 and when using my new lighting kit if the aperture is faster than1/200 it creates a blackout across part of the image due to the mirror. Any solutions?
It's not the aperture, it's the shutter speed. It's also not the mirror, but the shutter.
The camera's fastest shutter sync speed is 1/200. You must use a shutter speed no faster than that. Due to the construction of the shutter, the frame is not fully exposed simultaneously at faster speeds and thus part of the image is blacked out.
Using a flash, the amount of light is controlled almost exclusively by the flash; the exposure is controlled by the aperture and the shutter speed is all but irrelevant.
Feb 15, 2013 | Nikon D60 Digital Camera
How can I use Metz 45 CL-1 with Nikon D3000 and what should be my setting on Flash and on Camera
First you need a hotshoe adapter to connect flash Sync cable to camera. You have to pay your attention about the following settings. Set the same ISO speed on flash gun and camera.( 100 or 200) White balance to Auto or Flash on camera. Mode dial to M (manual) and shutter speed to 1/200 or slower on camera. Aperture setting to 5.6 or 8 (both on camera and on flash) Now take some trial photos and check on the LCD display and histogram and do fine tuning to your exposure. Change the aperture value on camera to control the exposure of flash as well as the ambient light Change the shutter speed to control the exposure of ambient light. (!/200 or slower speed) I hope you got the solution to your problem. I also have the same set of equipments to do my photography.
H.D.Shirantha.
Sep 10, 2010 | Metz 45 CL-1 Flash
Sometimes my viewfinder goes dark and the lens' autofocus stops working. What does this mean, and how should I fix it?
In all probabilities, the mirror lock-up feature of the camera is on. When the mirror is locked in the upright position, the optical viewfinder will go blank. This will also prevent the AF from working. If the mirror lock-up feature is not on, then the camera's mirror box could have been damaged. If this is the case, then the camera would require a minor repair (alignment of mirror) by a service center.
May 12, 2010 | Sigma HF 28-80mm f/3.5-5.6 Aspherical...
16GB flash drive as virtual memory?
If you mean an USB pendrive/stick, these are much slower than hard drives.
There are so-called SSD - Solid State Disks, which have a special construction (many Flash banks running in parallel) enabling them to offer transfer speeds comparable to a hard disk. These come as ATA or SATA drives that you connect just as you would a traditional hard disk.
Nov 26, 2009 | Computers & Internet
Shutter curtain dont reset mirror in certain speeds
wwinters81
your K1000 needs a clean, lube and adjust. ( CLA ) the shutter must be repaired and calibrated. not a hard job, but a special calibration instrument must be used to calibrate all shutter speeds.
slamming the camera just makes things worse, you could brake the meter. take or send your K1000 to a camera repair shop and get an estimate for a CLA.
there are no new parts available, so if the camera requires parts the shop should state good used parts only.
Mar 12, 2009 | Pentax K1000 35mm SLR Camera
Display screen goes blank
The camera is writing to the memory card during that process. Upgrading to a faster SD card may help solve your problem.
SD card prices have dropped dramatically. Unfortunately the very low price cards that you see these days also have very slow write speeds. It's the tradeoff that you will have to accept with these cards.
Dec 25, 2008 | Canon PowerShot A530 Digital Camera
Mirror locked up and camera is showing help in the lcd display
Did you ever find out how to fix for your mirror lockup problem?
Sep 17, 2008 | Minolta Photography
Black Image
Are you taking these images with a flash? If so it is possible that you are shooting with a shutter speed which is too fast for flash photography. Anything faster then 1/125th (i think) on that camera with flash will produce the result you are describing. If this is without flash then the problem lies elsewhere. New flashes from canon have the capability to work with any shutter speed, but classic flashes only work properly at lower speeds. David Millier Advance Camera Repair
Feb 21, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Cameras Logo
76 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
