Need replacement spark board model # to replace board on duo therm model #65930-064. Model year 1983.
5 Suggested Answers
  • 400 Answers
SOURCE: Dometic Duo-Therm - 13,500 B.T.U. Model #3107541.009 - Serial # WA346967 - Yr. 1999-2000. Blower motor will not start. Replaced the start capacitor - no help. It will run by spinning the motor by hand
Yes you should try replacing the run capacitor.
Posted on May 08, 2009
SOURCE: rv air conditioner leaking
I have the same problem....it is a negative pressure problem holding water inside the unit until it overflows the pan and runs into the duct system. why this occurs....I don't know....I cant find a problem with my air return, but as soon as you turn in off, the water comes gushing out the drains on the unit. I resolved this....temporarily....by twisting up a paper towel into a wick, and placing one end up into the drain tray, with the other end lying well out into the exterior case. This lets the water wick out and keeps the tray drained. I don't understand the problem and don't know what the permanent fix will be, except maybe cutting a hole and placing an intake vent directly below the unit.
Posted on May 11, 2009
  • 59 Answers
SOURCE: How do I install a blower motor in a duo therm
ITS NOT EASY. YOU NEED A LONG SET OF ALLENS TO LOOSEN BLOWER WHEELS. THIS IS A  DUEL SHAFT MOTOR , BACK COIL NEEDS TO BE PULLED AWAY FROM MOUNT WITHOUT BENDING COPPER. MOTOR BOLTS 3 OF THEM HAVE TO BE REMOVED AND WHEN BOTH BLOWERS ARE REMOVED AND WIRES REMOVED THEN IT CAN BE REMOVED . THE PROBLEM IS THAT THE NEW MOTOR IF IT IS NOT FROM DUO THERM YOU WILL HAVE TO CUT SHAFT TO RIGHT SIZE AND WIRES MAY NOT BE SAME COLOR. IF IT IS SAME MOTOR FROM DUO THERM YOU CAN CUT WIRES AT OLD MOTOR AND WIRE NUT THEM COLOR BY COLOR.
Posted on Apr 22, 2010
SOURCE: My duo-therm forced air direct
I currently have the same problem. It's happened before and it was the circuit board on the right inside of the heater. Tired of that board going out ($) several times, so this time I'm going to remove the board and look at it myself for any common problems such as broken or bad solder joints (vibrations). I use a magnifying glass to do this because some cracks can be very small and invisible to the unaided eye. I don't know if your'e up to this but it's worth a try if you've looked at other things such as no gas, valve not open, etc. (and, of course, need to save money such as I do).
Posted on Oct 27, 2010
I have a duo therm model 630035.321. What is the best replacement unit?
There isn't one. Every a/c unit is a piece of junk. Just like your t.v., fridge, and microwave. Buy cheap, replace when it breaks down. It's all luck, so Good Luck!! Best Wishes!!
Jun 04, 2017 | Dometic Heating & Cooling
Furnace refuses to cycle off even when room is 20 degrees warmer than setting
Do you know how to access your furnace wiring ? What make/model furnace?
Jan 18, 2013 | Dometic 3109228.001 Duo Therm Comfort...
Replacement Fan Motor
Try Johnstonesupply.com. Use the information you provided above.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
