Question about AT&T TTY 8840 Corded Phone (TTY8840)
I have a AT&T 8840 TTY phone that can not be answer by the person. I get on the screen that its sending the ID and never get a response from the other end.
Phonebook says not available/why?
In my State a lot of my calls say unavailable if the person doesn't want their name shown for some reason. But it always has the phone number under that.
Sep 14, 2014 | Uniden Dect1480-3 Dect Cordless Phone, W/3...
Imei for nokia6300 is 359537019227485 i want master code for nokia 6300
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Jul 26, 2011 | Compu-TTY Health & Beauty
What is tty mean in settings
TTY stands for "text telephone" or "teletypewriter." It is a technology that allows a person with speech or hearing impairments to use a home or cell phone to communicate
Identification
TTY stands for "text telephone" or "teletypewriter." It is a technology that allows a person with speech or hearing impairments to use a home or cell phone to communicate.
Feb 09, 2011 | Pantech Impact P7000 Black Rubber Feel...
How can i get a job in the subberbs because the keep saying no becasue i am black
Try to present yourself as a responsible person looking for employment that you are absolutely qualified for. They cannot say it to your face NO!
I assume it is a question of misunderstanding. So keep trying till you win.
Oct 13, 2009 | Health & Beauty
How do i get mute off my phone
Well that would be hard to believe you can't get mute off since you have to personally initiate mute while during a call and the mute would be disable after you hang up. The mute button is located on the left side below the screen. Now here is what you might want to look at. Make sure TTY mode is off, this option would put your phone in permanent mute. Go to settings then to call settings, TTY mode should be off. If this still doesn't work and your phone displays "car kit" on the main screen then your phone is probably water damage or needs repair.
Jul 13, 2009 | LG VX8350 Cellular Phone
TTY
TTY is the system used for the Hearing Impaired so they can read instead of hear the phone.
DTMF (Dual Tone Multi Frequency) is used by the phone when you are calling a land telelphone line and asked to enter press numbers to get a response, such as a password or changing to a different language.
May 24, 2009 | Motorola Mobility KRZR K1 Cellular Phone
TTY/ TDD Phones Question
TTD/TTY devices use normal phone lines to communicate. An individual with a TTY/TDD can either communicate with another TTY/TDD device or can make a call to a standard telephone. In this case, the TTY/TDD device calls a live relay operator and the live relay operator communicates with both parties either with a TTY/TDD device or uses their normal human voice on a standard telephone. It is important to note that there are different protocols that can be used to communicate with TTY/TDD devices, however many newer TTY/TDD devices can handle a wide range of protocols and can even communicate directly from a personal computer using special software and a computer modem.
Aug 27, 2008 | Clarity Large Visual Display for TTY
Can't get ohio relay at all
I had the same problem with my Ultratec 1000. When not using the phone in voice only mode, I have to push the "dial" key before actually dialing the nbr.  Otherwise, the phone just sends baudot code for the nbrs you dial instead of touch tones. Once the call is answered the phone will switch back to baudot.
Apr 17, 2008 | Ultratec Uniphone 1140 Phone/Answering...
Palm treo 750 not ringing
Taking the battery out to switch your phone ON/Off can cause serious problems.
To receive calls, your phone must be on.
This is different from having only the screen turned on (see Turning your phone on). When your phone is off, your calls go to voicemail. To see a picture of the person calling you!
Learn how to assign a caller ID picture in Assigning a caller ID ringtone. If music is playing when a call arrives, the smartphone rings softly. You can answer the phone as you normally would. The audio pauses during your call. To answer a call, do one of the following:
• Press Phone/Send .
• Press Answer (left action key).
• If the headset is attached, press the headset button.
To ignore a call and send it to voicemail, press Menu (right action key) and
select Ignore or press the Power/End key.
Waking up the screen and turning it off.
Wake up the screen and leave the phone turned off when you want to use only the organizer features of your smartphone, for example, when you’re on a plane and want to look at your calendar. You can also turn off your smartphone’s screen without turning off your smartphone’s wireless features. You can turn your screen on and off by pressing Power/End.
Mar 08, 2008 | Palm Treo 750 Smartphone
Phone shows a call coming through but no sound
Feb 20, 2008 | Palm Treo 750 Smartphone
AT&T TTY 8840 Corded Phone (TTY8840) Logo
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
