Question about Hotpoint Aquarius WF000 Front Load Washer
Wf540 hotpoint washing machine making a banging noise
I have been told there should be a filter somewhere that may have 5p's stuck in it or bra wires etc & friends have just emptied this & its solved their noise problem.
There is a big red disc on the front I've taken off but that is empty
Does my machine have one???
I can't get to the back at the moment but could if necesary but would mean disconnecting pipes etc
Please help?
  • Anonymous Jun 11, 2008
    I too have that flat red disc with nothing behind it! Where is the pump clean access??
    Genius:
  • 1,028 Answers
Remove lower front panel pump right of center turn small plastic handle counter clockwise pull out
Posted on Jun 01, 2008
Hotpoint Aquarius WMA58 washes, spins but won't drain water away !
I would check the filter assembly and the drain line to see if there is an obstruction visible or twist in the line that you could smooth out. The drain solenoid valve could be faulty and just isn't opening any longer. It's an electrically operated valve that makes a rather loud "click" when it energizes to open the drain and let the water flow out.
Dec 28, 2016 | Hotpoint Washing Machines
Help,a wire from an underwire bra is stuck somewhere not visible in my washingmachine
You can get to this most times by removing the heater asssembly not too time consuming 1/2 hr job. once you remove heating element look in and grab wire with long nose pliers , hard part is getting out the rubber gasket se curing element. happy Easter
Apr 03, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Bra wire stuck between inner and outer drum how to remove Hotpoint WMF760
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Jan 24, 2010 | Washing Machines
My hotpoint wf540 on off switch flases and the
sounds like your water pump has failed??
Try cleaning the filter first, normally accessed at the bottom R/H side of unit at the front.
If not, replace water pump (approx £35 for part) good luck!
Jan 04, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Bra wire stuck somewhere in machine
You will not see it as it is trapped between the inner and outer drum, what you need to do is remove rear panel and the large hose from the pump to the bottom of the drum,
Then reach in with your fingers and see if you can feel it , if you can't then short of removing the drum (not recommended) ther is not a lot you can do, hopefully it will find it's way into the filter, where it wiil not be a problem
Plz rate this solution.
Dec 15, 2008 | Washing Machines
Noisey washing machine
i had the same problem check the holes inside the drum for a bra wire stuck in one of them which was my problem we also thought the bearings had gone but they were not hope this helps
Oct 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
230 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
