Question about Hoover F5892-900 SteamVac Upright Vacuum
How to you take off the plastic shield in front? There is a lot of carpet fuzz that I want to clean out. I've unscrewed the phillips screw on top, but am not sure where to go from here.
    Sergeant:
  • 270 Answers
Go to this site and select the model / type of your vacuum and open the appropriate manual..
http://homeappliance.manualsonline.com/ex/thread/view/idThread/1306047
good luck and don't forget to vote!!!
Posted on Oct 11, 2010
Have a power brush and cannot get the brush out to clean. I've taken off the main cover, but the brush is held in by a bracket. I can't take off the main cover as I don't have the right kind of...
I have a Miele STB-205-3 Turbobrush. After opening the brush cover using a quarter, I use a T-7 torx screw driver (shaped like star of David) to remove the main cover that is held by 4 screws.
There are 2 more screws holding the fan housing. After unscrewing them, you can take the whole thing apart and clean it. Make sure you clean all rotating parts as they collect a lot of hair, dust, etc,
Sep 13, 2011 | Miele S251i Plus Bagged Canister Vacuum
The motor on my carpet tool (beater brush) stopped running yesterday. The main vacuum still works, but the switch for the carpet tool just clicks and doesn't turn it on.
Knowing the model would help.
Possible problems:
Broken or disconnected wire in hose, connections, power nozzle.
Hose needs replaced. Check all connections for discoloration and cracked supports. Have power nozzle checked at a vacuum shop. Depending on the model, take it to an authorized Aerus Electrolux store for this.
Bad power nozzle motor Needs replaced.
Bad switch. Take the whole machine in for thorough check and repair..
Jan 25, 2011 | Electrolux Vacuums
How do i use my bissell 7920
The 7920 is a great little carpet shampooing vacuum. Look up manual information for detailed assembly and starting/breakdown procedures. Make certain that the carpet/floor has been vacuumed previous to cleaning with the shampooer! The small nozzle opening will get clogged with as little as a toothpick or cheerio! Step on the rear release arm pedal and drop the handle down to the floor, Pull up on the resevoir bucket handle and place the handle of the resevoir back down to open the top of the tank and fill the bladder with hot water. Replace bucket top and place bucket back into vacuum. Raise the handle until it clicks into place. Fill on board soap/shampoo dispenser by lifting out of chamber on unit and fill with appropriate Bissell or upright shanpoo cleaner. Replace unit and make certain the top is tight. Plug unit in and turn on both vaccuum switch and preheat water switch and wait approx. 2 minutes to get water hot enough to proceed with cleaning. Start by rollling cleaner onto carpet and engage trigger approx 2-3' pathway away from you and then release trigger and draw vacuum /shamppoooer back over wetted area, repeat without using water again unless heavier traffic area. Do not over wet area draw unit back and forth a few times until water runs clear thru the front clear window. Proceed to make another path along side cleaned area and so on.
Once you hear the water run out or you have finished cleaning an area then shut of heater and vacuum. release handle with foot pedal release and lift out bucket and pour out dirty water and rinse area/tank /resevoir etc. You should also clean the small red filter in the resevoir of any debris by popping out and replacing. Also, there is an onboard filter under the clear window (where spinner is located) . unscrew clear top , take out spinner device and pull out small plastic screen and rinse or blowout. Clean also the front clear cover if there is debris, by rinsing off with sprayer or wiping clean. You may also find that you have to take off the clear plastic hood window, by unscrewing two screws on either side of nozzle opening (top ) and rinse out as well. Do not, get water under unit into motor area. Place unit upright and in a warm place.. Do not let freeze if in climate that is known to freeze. Good luck cleaning!!
Apr 23, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My roomba won't go forward it just spins in a circle and will go backwards. I have already tried cleaning it out and cleaning the front bumper sensors.
You will need to take the top off to clear those wheels.
This happens a lot when cleaning new carpet. The fuzz jams the wheel switch, and dosey do you go.
Mar 05, 2010 | iRobot Roomba 530 Robotic Vacuum
My bissell powerbrush won't **** up the water
had same problem - carpet soaked with dirty water and very little, if any, cleaning fluid used. Easily remedied. Removed water resevoir and found that the rectangular shaped washer at the top of the front cover (the bit you had unscrewed to give a good clean) had become dislodged. It has small lugs on either size which lock on to the plastic opening when pushed down firmly. Resevoir then sits on top and makes full connection, also ensure that grey locking handle is fully pushed down.
Seemed to me that the water wasn't being sucked up as there was air getting in and this has down the trick. Sorry if this is difficult to follow but all will become clear when you look for the black washer! Good luck
Mar 18, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Power cord broken inside s251i miele How do i open the s251i ????
HOW TO OPEN MIELE 251 VACCUUM: 1-Unplug from wall and disconnect power cord 2-Remove black switch panel at back of top panel: A-Use Phillips screwdriver, remove two silver screws visible between back of hinged top door and front of black switch panel
B-Push back of the panel down while pushing it forward (towards front of machine). There are two plastic notches and clips which are tightly fit together that you need to separate.
Once it releases, push it a bit more towards the front of the machine and lift off panel. It has wires connecting it to the main body so it will not remove completely.
C-Be careful not to lose the springs that simply sit inside of two plastic channels, one under each of the two switches. These are required for your witches to operate properly.
3-Locate screw at bottom of deep rectangular hole now revealed (under former location of black switch panels). Unscrew using Phillips screwdriver. 4-Open hinged top panel. Locate two silver screws, one on each side of main housing. Unscrew using Phillips screwdriver. 5-This will let you lift off the whole top assembly, door and main housing, revealing the plastic chassis and the motor unit within.
You now have access to the motor, wiring connector harnesses, circuit board and the cord reel.
Dec 07, 2008 | Miele S251i Plus Bagged Canister Vacuum
How do I take my Miele S251i apart to be able to chenge the powercord?
Sep 13, 2008 | Miele S251i Plus Bagged Canister Vacuum
Cleaning the bissell powersteam cleaner
If you are talking about the cover over the nozzle asm, where the water is sucked uo, the are 2 screws, one on each side, take those off, you may have to pry some, but it will come off. When you put back on, at the top end, it should snap into place, then lower it and put the 2 screws back in.
Dec 05, 2007 | Vacuums
Hoover Steam Vac Model #5899-100
there is a single screw at the top of that shield (under the dirty water tank) and then there is 2 screws on the bottom that you unscrew and the shield will slide right off and you wipe it out and put it back on.
Nov 20, 2007 | Hoover SteamVac F5914-900 SpinScrub...
No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Dec 12, 2006 | Euro-Pro Super SC710Z Steam Vacuum
Hoover F5892-900 SteamVac Upright Vacuum Logo
157 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
