Question about Kicker SX650.1 650W Mono-Block Amplifier w/Remote '04 Series
I HAVE A KICKER 650.1 WITH THE DIGITAL SCREEN AND DON"T HAVE THE REMOTE GAIN AND I GOT IT WORKING BUT ITS SET TO LOW JUST WONDERING HOW TO TURN IT UP
I have a kicker ix 500.4 hookd up to polk audio 6x9 and 6.5. if you play the system past about 25 volume the subs will keep playing but the speakers will cut out for a few seconds as if its hiting the
Make sure your frequency is no higher than 80 on the low and 120 on the high. Check speaker polarity with a AA battery(Speaker pops out when polarity is correct) Make sure the speaker crossovers are working properly. Check your ohm load when you connect the speakers together with a multimeter at the amp. Ohms that are too low = heat. See what your amp is rated for. After all that, turn the gain down all the way, turn up the volume to 25-28 and readjust the gains
Dec 07, 2013 | Kicker IX500.4 4-Channel 500 Watt Car...
How do I tune my KICKER 08ZX1000? I have the amp running to alpine type r 12 inchs at 2 ohms but I don't know where the bass boost , gain, and crossover knobs should be pointing or what one to turn up...
To start, turn the gains on your amp all the way down. Bass boost should be off (this us used if you listen to your subs at low volume, the boost will heat your amp up quick if you use at high volume). Then turn the volume on your headunit up to 3/4 full. Make sure the filter on your amp is on low pass. The crossover point should be at it's lowest too. With all these in place, you can begin turning up the gain. You will have to decide at what point to move the crossover point. Since there are different styles of music, you will have to listen to where you feel notes are "dropping off" from the music. Adjust the crossover point to your liking, but remember that subs were made to reproduce low frequencies. Hope this helps
Aug 20, 2011 | Kicker Car Audio & Video
I need to know what to put the frequency at for my subs... they are 2 12" kicker comp's
40 - 45 Htz is the usuall. It really depends on the music you listen to. They are built to handle a little more mid bass. Where they are located, power supplied, direction the subwoofer is facing will all have an effect on what you need to set it at. My suggestion is follow the basic steps in setting up your amp. 1. turn your amp gain all the way down. 2. turn your radio volume to 75% of max. 3. start turning up the gain until you obtain the sound you want. You want to do this so your don't "clip" the sub. Kicker is good, but the comps can only handle so much before they start popping. This will heat up the voice coils quickly and cause them to fail prematurely. Hope this helps.
Jul 31, 2011 | Car Audio & Video
I have a pair of kicker cvr 124 with a kole 1500 watt amp that is bridged to the woofers. the amp is 385 rms at 2 ohms where should the gain be to get the most power without distortion.
When setting your gain you want to set the gain high usually between 75% to 95%. if the gain is low than turning up the volume on your radio will only amplify the distortion coming from the under powered head unit. By turning up the gain you are maximizing the signal that is amplified coming from your head unit
Mar 20, 2011 | Kicker Car Audio & Video
Kicker amp shutting off
hello my friend you should have the input signal set to 500 miliamps do not go over, another thing is that if you have good ground and the battery is good and it has the sufficient amps to push it.also the ohms of your spkrs are not too low,you need to check all that.
good luck
caypianan@yahoo.com
Nov 02, 2008 | Kicker 04KX250.2 Car Audio Amplifier
Setting low pass and bass eq
Hello, i have a hifonics brutus also, in the manual it states to set the eq at half way, so that there is no clipping or at least to prevent clipping , the eq will make the bass punchier, if you do go pass half way, i would recommend to readjust your gain settings, also check your head unit settings and make sure everything is flat, bass, mid bass etc. example i had my eq past half but i had my gain at mid way, it was hitting hard, then i tried turning the eq all the way down and the turning up the gain and the bass was smoother so it depends where you set it, and what settings you have on your head unit tone control (bass, treble etc)
May 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Kicker ZX1500.1
Set your multimeter to DC volts. Place the black lead on the ground terminal of the amp. Place the red lead alternately on the B+ and remote terminals. Both of the terminals must have 11+ volts. If the voltage is low on either of the terminals, follow it back to determine why the voltage is low. If the voltage is low on both of them, you may have a bad ground.
The ground needs to be connected to the floorpan of the vehicle. Scrape the area down to bare metal before boltting the ground lug to the floorpan.
Dec 23, 2007 | Kicker ZX1500.1 Car Audio Amplifier
Kicker SX650.1 650W Mono-Block Amplifier w/Remote '04 Series Logo
133 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
