Question about RCA P50830BL 50" Rear Projection Television
I have no picture on my rear projection RCA Model P50830BL. For the last month I noticed changes when I was watching it. it was like showing three colors sreaks on the top coming from sides to a center point. Then it was the picture going in the same way. I would temporarily get the pic back by shutting the machine off and on. Then this morning heard a whistle when I turning it on and no pic at all I have sound but no pic.
SOURCE: rca rear projection tv has sound but no picture. clicking noise coming from the back.
replace the lamp.
Posted on Apr 15, 2009
hotratchet
  • 952 Answers
SOURCE: 52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Posted on Jun 19, 2009
  • 19 Answers
SOURCE: I have a RCA R52WH74 Projection HDTV. Today I was
You will need to have the convergence IC'S replaced and realine the set again.
call around and get prices.
Posted on Jul 09, 2009
SOURCE: RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Posted on Nov 07, 2009
  • 139 Answers
SOURCE: 60 INC RCA PROJECTION CURVED PIC. TOP BOTTOM
This problem is caused by a faulty Convergence amp. This amp keeps all three colors aligned together and square on the screen. It could also be the power supply section that supplies power to this amp.
A local TV shop should be able to repair this for you for about $350
Posted on Jan 06, 2010
Testimonial: "VARY HELPFULL THANK YOU"
My RCA model P61929 picture is curved inward on the top and bottom
Is there also a misconvergence? If so you need to replace the convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to correct it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the generous rating!!
hardrocko
Apr 27, 2010 | RCA P50830BL 50" Rear Projection...
Blowing fuses p50830bl
the board mounted overtop the of the chasis is the convergence power supply board
replace that board will bring your tv back to life
then go into menu readjust convergence red and blue DO NOT MOVE GREEN
Sep 01, 2009 | RCA P50830BL 50" Rear Projection...
Watching movie... heard a loud pop...then picture was gone...clicking sound coming from back...green light flashing.... RCA hd lcd tv
Your bulb is toast.
They are just $90 on ebay.
Got one last month from discounttvlamps.
Delivered in 3 days using their free shipping.
Easy install.
No problems.
Feb 21, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
BOWED PICTURE AND COLOR CONVERGENCE
You can replace the whole convergance board assy Part #239126 or 239126R and it should take care of problem.
Dec 18, 2008 | RCA P50830BL 50" Rear Projection...
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA P50830BL
Hi,the trouble is the power supply for the convergence,it the board that mounts above the two board that lay flat,there is a ic on that board that is heat sinked,part number is 215530,replacing this ic will return the menu and repair the set,the board is green 5 inches wide and 8 inches long.
Mar 13, 2008 | RCA P50830BL 50" Rear Projection...
RCA P50830BL 50 in.
This is burn in on your set. Something that had those words set on your set for too long. There is no solution to this problem replacing the CRTs would not be cost effective...make sure you do not leave any still images on your tv for extended amounts of time.
Feb 04, 2008 | RCA P50830BL 50" Rear Projection...
RCA P50830BL will not turn on
You have a shorte chopper diode, on main board look in middle of BD. You will need to change Horizontal output and Block blue caps and big Diode.
Nov 26, 2007 | RCA P50830BL 50" Rear Projection...
Rca p52771at - dark picture
Sounds like a bad screen asy,part number 204809,must use the generic,or you could have weak tubes,if so you may just need to turn up the screen drives,this part is located in the right top of the set with the back removed,if no cracks are present adj. the three marked screen's,turn the color all the way down in your menu and adj. for a black and white picture.
Oct 07, 2006 | RCA P52771AT 52" Rear Projection...
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
