Question about Samsung LN-T4061F 40 in. LCD HDTV
Cables Can you give me your best advise on what cables I actually need to set up my LCD T.V.? It's an investment and I want to get the best quality picture as I know owning a LCD T.V is nothing unless you get the quality it's designed to deliver. Thanks for your support
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi trvsmart1
    Is you TV the same model one listed with your post LN-T4061F 40 in. . Sorry to have to ask you that, but sometimes, the models we each refer to may be different. I start referring to that model, and you dont know what I am on about :) Awaiting your advice
    regards
    robotek
    Problem Solver:
  • 5 Answers
HDMI cables are the best you can get right now as long as all your components have HDMI connections. Just don't overpay. Order them online and you'll be able to find them for less than $20 each. Walk into a store and you'll get jacked for $75 or more.
Posted on Jul 15, 2008
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
I have Horizontal line running through my TV all the time how can I fix it?
Possible inverter cable got loose, there is actually no easy fix for this such as settings to be changed rather than ensuring that the LCD cables are tight and fixed inside. There is actually also a big chance that they were grounded and thus part replacement is advisable.
Apr 10, 2011 | Samsung UE-46B6000 46 in. TV
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Hi, Am planning to buy second hand samsung projectioon tv 43" from my relative. Its 4 years old, picture quality is ok but in numbers or letters colours spreads. Shall i go for that? Please give me...
NO ! You will be investing another $250-300 in repairs shortly. Good set, but I would invest in a new Samsung. They do make a reliable set. You may see a lot of posts on repairs but that's because they hold a very large market share.= They sell a ton of them.
Nov 27, 2010 | Samsung Televison & Video
Which printer cable best suites my needs?
Printer Cables are one of those things you never give much thought to until you need one. With the invention of the USB port it has made it quite easy to install a new printer. You simply plug your printer into the Usb port on your pc. With that said there are some things you need to be aware of that can affect the quality of your printing needs. There are many different types of printer cables to choose from. They range from very cheap to very costly. If you are just using your printer for everyday use you can get by with a standard usb printer cable but if you plan on using your printer for photos or any type of graphics work you need to consider a better quality printer cable. Which will give you a better quality print. Listed below is a brief explanation of the different of the different types of available printer cables. Keep in mind this is just a fraction of the difference's in printer cables and some cables may not applay to your printer. Be sure to click on the tabs above to find just the right printer cable.
Aug 12, 2010 | Brother Office Equipment & Supplies
Rca cables in place of component cables
Typically the Yellow is video and Red and White are Sound. So only one is for video two are for sound normally.
Basically they are about the same thing, the only difference there will be cables are made different. Some cables are better than others at transferring signals be they video or sound. So quality might be affected slightly.
Jan 06, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Suggestions to hook up HDMI cables
I'd suggest running all HDMI.  I believe your receiver has 2 HDMI in's and one out.  Run the out to your TV and run the components to the inputs on the receiver.  This way the receiver will control the video.  Works good for me!  Hope this helps!
Dec 27, 2008 | Yamaha RX-V663 Receiver
How to connect to ford mondeo
You can go two routes for this, wireless or cabled. Wireless is of course good because it has no cables but the sound quality is not that great - ok, but not great. So my suggestion is to go the cabled route which actuall ends up being neater anyway and gives pretty much 1:1 quality. There's plenty of people out there that creat adaptors and cables but check these guys out:
http://www.nexxia.co.uk/iPod_MP3_Adaptors/ford.htm
They range from about £50-100 - and doing a search on eBay for 'Ford iPod Adapter' comes up with similar devices at a similar cost.
All the best
Sean
PiDigital
Dec 26, 2008 | Apple iPod nano
HDTV has fuzzy picture
Greetings blueberrie,
Many times the cables that you are using can contribute to picture quality. You will want to utilize the best connection possible, in most cases HDMI or component cables. Also, you may want to invest in a line filter, sometimes known as a surge protector. Many of these items are able to control the inconsistencies in power your unit receives, giving you clean power, which will influence picture quality.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 23, 2008 | Televison & Video
Faulty tevion lcd 32
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degradation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem.
  4. Open OSD to adjust the picture: Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed. If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
May 25, 2008 | Televison & Video
Samsung LN-T4061F 40 in. LCD HDTV Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
