Question about Behringer Pmp3000 16 Channel Audio Mixer
I have a behringer pmp 3000. In the middle of the show, one of our inputs started making a loud static sound. stopped and turned it off then on. Checked the cable and not that, it still looked like it was making static sound. Everything worked ok on second set. Then towards end of third set. Static sound came on. It was on one of the channell, board is 3 weeks old.
  • Behringer Master
  • 5,603 Answers
Take this in for WARRANTY repair immediately !!!! This is NOT DIY.
Always power any interconnected equipment from the same receptacle or power distribution box.
Also READ my tip regarding a speaker polarity grounding hazard on Fixya.
Posted on Oct 11, 2010
We are trying to purchase a pmp mixer for our church choir. What's the difference between the pmp 3000 and the pmp 4000? Thanks!
The answer is "Not Much"... they upped the rating for power out and added 1000 to the model number... I don't know of any circuitry difference between them... it would probably be minor. Functionality is the same.
Oct 17, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Not enough sound, im using a pmp 3000 with rhino rh2112 250 watt speakers its up at max and struggling badly at very small venues
The speakers would receive about 250 watts max each from the PMP3000 since they are 8 ohms.
That is quite a bit and should fill a 1000 square foot venue with plenty of sound. The type of program material will affect what sound level you can get to. I would recommend you procure a sound meter and measure the sound level. You should be able to get 90 to 95 DB out of these easily. I use a PMP 3000 with two Peavey 15 inch with horn cabinets and can get 98 DB in a 30 by 40 foot room easily. You need to respect the OSHA sound level limits and a sound meter will help you comply. The 12 inch speakers would probably be too small if you are running a lot of bass through them. Please read my tip on Fixya regarding a hazard of the PMP mixers. Essentially, when using 1/4 inch adapters or plugs from the speakon connections of the PMP's, channel A sleeve or barrel is the hot whereas the tip of channel B is the hot. This is not documented in the user manual and if you inadvertenly ground the sleeve of channel A you will likely blow the amp.
Jun 27, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I have a pmp 3000 and a pmp 6000. what is the best wast to run out of the boards to the speakers? and is it better to run in mono?
No preference, just use mode that fits your venue. As far as system safety I would run in Stereo A/B rather than bridged mode.
Now please read my tip about PMP units on Fixya regarding a hazard if you convert the Speakon outputs at some point to 1/4 inch plugs. If you do this, please note that the SLEEVE, not the tip on channel A is HOT to ground and shorting this to ground will often fry channel A. Channel "B" the tip is the hot speaker lead. Thsi is done by Behringer to facilitate switching to bridged mode.
Mar 06, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
My behringer pmp 3000 has litle power i thing is 3000 or how much power it haveit? I put 2 speaker only ,,,, thankyou
The unit should drive 400 Watts RMS into a 4 ohm load per side.
The amount of sound power you get will VASTLY depend on speaker efficiency. You would likely use at least 15 inch speakers with the unit.
Aug 08, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Hello...last night at a show, i plugged up my syst...
Hi, first get a battery and a wire to comfirm if the speakers are still working.
If the speakers work that means one of your connecting cables is bad and it needs to be replaced.
You can just do a general troubleshooting of all the cable for connecting.
Good luck.
May 20, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I HAVE A BEHRINGER PMP POWERRED MIXER 5000,I LOST ...
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} tries websites like Shopjimmy.com,Ebay.com to buy parts for the replacement.
Good luck..
May 21, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Fuse and fuse holder needed for Behringer 3000 pmp mixer
Try this Behringer support:
BEHRINGER USA, Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
Fax: +1 425 673 7647
I just repaired a PMP3000.
A bit of warning on these. Do not let a speaker leads get pulled while powered. They can arc out the power amp causing extensive damage.
If the fuse ever blows do NOT replace the fuse as much more damage will result. Service the unit before using.
May 12, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Behringer Pmp3000 16 Channel Audio Mixer Logo
193 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
