Question about Sega Saturn Console
How to play game with sega Saturn model number HST-3200
4 Suggested Answers
  • 52 Answers
SOURCE: Can't seem to play the games
Sounds bad
the contacts for the carts may be worn
get a credit card, cloth and head cleaning fluid.
put the cloth around the card and a few drops of liquid and push in to the slot and clean the contacts.
make sure none are bent out of place.
if cleaning won't help then you may need to open up and look at the contacts for dry joints; a blob of solder may help.
failing that you may need to look on ebay for a replacement console (you won't need the leads so it shouldn't cost more than a tenner including postage)
Posted on Oct 29, 2008
  • 14 Answers
SOURCE: Sega Saturn doesn't boot correctly. Can't play games.
This could be a situation where the Laser Lens voltage is off and it is not reading CDs. I have had this before.
You will have to take your case off, and look for a little orange "screw" or "dial" which is just above the cable that connects the laser assembly to the circuit board. It might have a Philips head looking top.
Make sure the system is off and unplugged before doing this.
Turn the orange screw approx 35 degrees clockwise, and the reassemble the system. This should give the laser enough juice to start reading the discs again.
If this is not the solution, it is possible your clock battery is dead. Buy a new CR2032 3Volt battery from wal-mart or your local watch store, and pop it into your top right (on the back of the system) compartment to fix this.
Good Luck!
Posted on Feb 01, 2010
RescueTechLA
  • 2653 Answers
SOURCE: I have a sega saturn that plays games just fine
Dirty laser, failing laser. I'd try to clean the lens in a circular motion with a DRY q-tip.
Let me know if that works ;)
Posted on Nov 12, 2010
Sega Saturn CD spindle is too low: I've recently purchased a Sega Saturn. It plays games, but the disc rubs against the plastic of the console while it's spinning. It doesn't appear to be scratching the...
This is a common problem with the Sega Saturns, what you need to do is take the top of the Saturn off so you can get under the hub. Then you need to gently pry up on the spindle hub from underneath until it slides up the shaft of the motor. You have to be careful when you pry it up though, because you can damage the motor. A pair of pliers works best, because you can kind of rock the tool from side to side and get it to slide up that way. It doesn't take much to fix the problem so just go slow.
Dec 13, 2013 | Video Game Consoles & Games
I have a Sega Saturn with about 15 years. I unboxed it and started to play my games. Everything worked fine until Resident Evil 1. I start the game (everything fine, menu fine, options fine, intro movie...
It sounds like its definitely something wrong with the system. There must be something about this game that the system is having trouble reading correctly. I don't see there being much of a fix for this unless maybe you brought it in to a local game shop and had let look at it.
Aug 12, 2013 | Sega Saturn Console
Game says disc drive empty , wont play
chances are the laser is either dusty or has stopped working all together, try buying a cd lense cleaning kit and running this in the computer, that may solve the problem, or go to computer shop and buy a small can of compressed air and give it a good blast out inside to get any dust out, if this dont work then this means the laser is no goof and been a sega saturn the chances are it would be cheaper to buy a replacement console than it would to get the laser changed,
May 18, 2012 | Sega Saturn Console
I have a sega saturn that plays games just fine but will not play the background music to some games and will not play music cds. Any ideas?
Nov 12, 2010 | Sega Saturn Console
When I turn on the Saturn and place a game in the drive. and close the door. It gives me a message drive door open.
Sounds like the CD tray is not closing. Try opening up your Saturn and checking on the top-left corner, next to the part you plug your power cable into. There is a small switch that the CD cover presses on, try holding it down while you turn it on with a game in it and the top half of the case off. The game should spin and play. If you tape it down, it should work fine. If that didn't work, try replacing the battery. The battery you need is called a CR-2032. You can get this at you local CVS, Wal-Mart, or any place that sells watch batteries. After you do that, simply pop off the back panel, take out the CR-2032 battery, and pop in the new CR-2032 battery and then it should work. If that worked, congrats for your Sega Saturn being back in action.!
Aug 11, 2010 | Sega Saturn Console
My reset button on my sega saturn is stuck, and for some reason, the console won't play. How can I fix this?
Open the console and take out the reset button and take all wires away from it to stop any random reseting in game
GL
Apr 20, 2010 | Sega Saturn Console
I have Microsoft Windows XP Professional but I am unable to use Sega Worldwide Soccer CD Rom. I get a message coming up saying ' Cannot run on Windows NT 5.1 ( Build : 2600) I would be very grateful if you...
Hi Maguerite
Am I right in thinking that you are trying to play a game made for the Sega Saturn on a PC? If so, it will only work in a Saturn.
Hope this helps
Scott
Mar 24, 2010 | Sega Sports Worldwide Soccer for Sega...
Good Luck!
Jan 21, 2010 | Sega Saturn Console
Video Game Consoles & Games Logo
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
