Question about Garden
John deere La140 belt diagram - Garden
SOURCE: how to replace belt on john deere 425
take a sharpy and outline it before removing
Posted on Jul 19, 2009
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
  • 203 Answers
SOURCE: I have a John Deere LA140 Automatic riding lawn
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
That should help. It's on the John Deere website.
Posted on Nov 19, 2009
SOURCE: i need to run the mower deck belt on my john deere...
I have to replace my broken belt on my L110 John Deere mower. I have the new belt in my hand...
Posted on May 25, 2010
I need belt diagram for sx95 john deere tractor
Contact John Deere directly to request both a manual and a belt installation diagram.
Aug 14, 2017 | John Deere Garden
I have a John Deere la140 will not turn right can you please help
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
May 24, 2017 | John Deere Garden
Belt routing diagram for a LTR 180 John Deere
Ian, John Deere LTR 180 Belt routing diagram. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://jdparts.deere.com/partsmkt/document/english/featbene/fb_MaintSheet_LTR180_42RearDischargedeckLawnTractor.pdf
https://groundscare.custhelp.com/app/answers/detail/a_id/264/~/mower-drive-belt-routing---170,-175,-180,-and-185
John Deere LTR 180 Belt routing diagram Google Search
Aug 14, 2016 | John Deere Garden
John Deere LA140 wiring diagram
Request the wiring diagram directly from John Deere.
Jul 28, 2016 | John Deere Garden
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
Need wiring schematic john deere LA140
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
John Deere Model 140 Hydrostatic Tractor Complete Workshop Service Repair...
Aug 06, 2011 | John Deere Garden
I have a John Deere LA140 Automatic riding lawn mower. I need the diagram to know how to put on the new belt. Belt path?
Nov 15, 2009 | Briggs & Stratton Garden
Garden Logo
784 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
