Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Top half of agutaor does not rotate - Kenmore 3.2 cu. ft. Plus Top Load Washer
    President:
  • 1,430 Answers
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. Here is a video this will walk you thru checking and replacing the agitator dogs . You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Oct 11, 2010
The revolving light on top of unit will not light.replaced it with one from the other half and it works fine.can this part be repaired or replaced?Where do we send it.
Organizational Maintenance Manual: Truck, Cargo, 8 Ton, 4 ...
https://books.google.com/books?id=oToYAAAAYAAJ
1991 - ‎Military trucks
If a voltage is not observed, perform a voltage test at socket F of the slip ring input ... the continuity of wire 496 to ground (wire is defective if continuity does not exist). ... DESCRIPTION: The rotating light system consists of a rotating light unit, ... Current flows through the switch to the rotating light unit (mounted on the top left ...
Nov 23, 2015 | Cars & Trucks
How do i open the waffle maker?
If it's the rotating type, it only opens when it's rotated in the correct orientation. The side with both Red and Green lights must be facing up. Simply rotate the handle to make these lights face upwards, and lift the handle up, which lifts only the top half of the waffle maker. If this doesn't work, it's probably defective.
Dec 28, 2014 | Kitchen Appliances - Others
Printing text at the same label in two directions
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Zebra TLP 2844-Z Thermal Label Printer
Where do you put batteries in transforming radio controller car by blue hat?
There is a plastic latch that loosen with a philips screwdriver. Rotate the latch down and you should be able to rotate the top half of the back up.
Nov 20, 2010 | Sharper Image Blue Hat Toy Company Kids...
The agitator tries to rotate, but instead jerks, but doesn't rotate in normal motion. It also makes a ratcheting snapping sound.
Does the lower half of the agitator still operate normally? (Back and forth) Can you spin the top half (spiraled part) of the agitator in both directions with out the lower half moving? If so then you have a worn set of agitator "dogs" they are little plastic ears located in the upper half of the agitator and catch the notched inner section of the agitator to make the top action work like a corkscrew, slipping one way and driving the other as the lower half goes back and forth.
To get at these parts you will need to remove the agitator, Remove fabric softener dispenser or cap on top, and look down inside tho opening.
You will need to remove the plastic cover inside that has two ears sticking up, pull on one side or the other and it should pop out, there will be a rubber seal around it so it will be a little difficult to remove.
Now you will have access to the bolt that holds the entire agitator in the machine. The agitator dogs are located right on the outer edge of the center cup that the bolt goes through. To access them you will want to seperate the two halves of the agitator and flip the top half upside down while holding your hand inside it to catch the cup with the dogs in it. Part number 80040, for the dogs.
Good luck to You!!
Jun 26, 2010 | Roper RAS8445KQ Top Load Washer
Selectric II type ball not rotating. from what i can see, the cables are all on their pullies. Every number letter and symbol come up wrong. Some letters type on top of each other and come up slightly...
Maybe the rotate tape slipped off either the left or right side pulley. You need to remove the platen and upper case half to fix it. If the tape (thin eighth inch metal tape that when pulled on slightly rotates the ball) is off either pulley, very carefully, without lessening tension on the tape, try to slightly rotate the ball counterclockwise which will loosen the tension on the tape and slip it back on the pulley.
Jan 11, 2010 | IBM Office Equipment & Supplies
The top half of the agitater does not work it just
There are small plastic parts called "dogs" that wear out. The agitator needs pulled apart and those dogs replaced. It is fairly simple to do.
Jan 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitater does not move when in operation..
If its only the top half of the agitator that is not moving it's probably the dog ears that are bad. They are located in the top half of agitator there are four of them and the set should be no more than $10 and any appliance service company would have them in stock.
Mar 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Top wash rack doesn't get water
does the unit have a half load selection? if so then it may be stuck in half load due to a faulty solenoid in the base.
Mar 14, 2009 | Dishwashers
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
235 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
