Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
When we tried to light the heater the CFH shows, then I get a SPK which stays on for aroound 1 minute, then I get a LO. The heater never lites.
  • adam hudson
    adam hudson Oct 27, 2010
    Is this heater newly installed? The LO immage indicates that you have a propane heater that is not igniting with the 90 second timeframe dictated by the CPU. MAke sure the gas valve is open, and that you are getting gas to the unit. Bleed the gas line if possible, if not, these units can cycle 20 times or more to bleed a long propane line. More info needed
  • 310 Answers
The CFH is a Call For Heat.
The SPK tells you that it is creating a spark for ignition.
The LO tells me that you are on propane.
The fact that it doesnt light tells me that either the ignitor is not sparking, or that there is no gas, or an incorrect gas supply.
If this unit is installed with flexible gas line, replace this with rigid black pipe or a larger flex line.
Posted on Nov 04, 2010
Why do I get CFH but then no SPK?
CFH = Call For Heat
SPK = Ignitor is Sparking - attempting to ignite raw fuel
In a lot of cases, Pressure Switch opens up, CFH , is cancelled and therefor no ignition sequence.
try cleaning filter really good. If cartridge, may be time for an overnight soak.
May 21, 2015 | Raypak RP2100 DIGITAL POOL HEATER R265
Why does pool heater read SPK and won't light?
Sounds like your ignitor is shot. You may have to replace it.
Jul 24, 2014 | Rheem Water Heaters
Rheem pool heater not firing off
Try in the correct section, this one is for computer motherboards.
May 11, 2013 | Computers & Internet
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a five year old Raypak 207A on my 500 gal spa. When I turn the unit on, the display shows: PV 1, then CFH, then SPK, then the burner ignites, then CFH again, then it displays the flame icon and...
CFH means "Call For Heat", and SPK is "Spark". It sounds like you are running out of gas.Propane tanks need to have 30% in the tank for a heater to run correctly,and after they are filled you must bleed the air out of the line.If you have Natural gas,the gas line may be too small to supply enough gas to keep it running. NOTE...gas pressure MUST be checked with the heater running.
Sep 28, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
504 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
