Question about Dell AS500 Sound Bar Computer Speakers
I am trying to turn on my radio on the computer but i'm not getting any sound. please help!
  • Dell Master
  • 27,725 Answers
Control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Posted on Oct 11, 2010
2008 Mitsubishi eclipse radio not working after battery change
Unfortunately in newer vehicles, they sometimes need to have the computer re-flashed IF you unhook the battery with the radio on. It's a crummy deal. The dealership will probably have to re-flash the computer. You could try turning the stereo off, then disconnect the cables on the battery for a minute, then re-connect and POSSIBLY it could reset the system and it may work again. Don't get your hopes up, this may not fix it.
Nov 11, 2012 | 2008 Mitsubishi Eclipse GT
1996 GMC JIMMY WILL NOT START: Turn the ignition and there is a repeated clicking sound. The interior lights, radio and power windows still function. Replaced the "in line" fuel filter under the...
It sounds like you probably have a shorted battery cell. This will not only cause the repeated clicking that you described, but it will also rob power when jump-starting from another vehicle. There is probably enough power when jump starting to turn the starter over, but after the starter take the power that it needs, there is not enough power to operate the computer system....so I have no doubt that you probably are not getting any fuel. The computer has to tell the fuel pump to run. If there is no power for the computer....I think you can figure it out from here.
Replace the battery and try it again.
Please also review this article: My Car Won't Turn Over
Aug 12, 2011 | GMC Jimmy Cars & Trucks
My clock AJ 3010 clock radio gives off an electronic sound every 10 to 20 minutes. It's like a warning sound you get from a smoke alarm when a battery is running low. I've tried replacing the batteries but...
If you want to turn off all system beeps (like the ones that go through your computers' internal speaker ):
  1. Go to Start-->Run-->Type Regedit.
  2. Go to HKEY_CURRENT_USER\Control Panel\Sound
  3. Edit the key Beep and give it a value of No
This will help you to turn off system beeps.
Apr 20, 2009 | Philips AJ3010 Clock Radio
Radio/Speaker Problem
Check your radio and trunck to see if you have a equalizer/amplifier built in or otherwise.Adjustments would cause radio to go into safety mode.Try your balance from side to side.A busted speaker would cause the fuzzy sound or a shorting speaker wire.If none of this is your problem you may need to take it to a sound specialist.
Apr 20, 2009 | 1994 BMW 5 Series
1996 chevy blazer radio turns on but there is no sound
I have a strong feeling that the head unit "radio" has finally gone bad. You describe a situation, in which you have to turn it on and off, to get it to work. Typically if the sound comes out of all speakers, after doing that, then the speakers were never broken. The head unit itself should be replaced. I hope this helps.
Nov 16, 2008 | 1996 Chevrolet Blazer
Dell AS500 Sound Bar Computer Speakers Logo
67 people viewed this question
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
