Question about Whirlpool Duet GHW9150P Front Load Washer
Contol locked light is on and wont go off even though i unplugged for about 5 mins is there something i can do?
    President:
  • 1,430 Answers
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Posted on Oct 11, 2010
Testimonial: "thank you, thank you, thank you!"
Thanks so much. this worked. I thought I was in for a huge repair bill. Thanks.
Posted on Oct 20, 2010
B200 wont go on line or connect took off cord and still wont work
Error B200 means that there's a problem concerning the Printhead in most cases... in a great 90% of the cases is not fixable but...
Please try the following to see if we can resolve your issue:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Gently clean the printhead contacts with alcohol.
6. Place the print head back in and lock the lever down.
7. Place all of the ink tanks back in the printer.
8. Close the cover and turn the printer off.
9. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
10. Plug the power back in and turn the printer on.
Jan 02, 2016 | Cannon Office Equipment & Supplies
How do i fix
It is due to component failure at its main power regulator board. check for open resistor, connected as start voltage supplier. It can be located at the main board, will be connected to AC input to its SMPS oscillating section circuit. Even though it is easy to say; you need to be something in electronics to locate this very small component. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 23, 2015 | Sanyo Televison & Video
Cb seven fifty f2 19994 wont start battery fine was funning 10 min before hand
find out why neuteral light not working first ! could be a worn senser ! make sure you are in 1st gear and snik it up slightly for neuteral , have you tried to start it while in gear and clutch in ? starter or solinoide could be failing ! ???
Feb 10, 2014 | Honda CB 750 Nighthawk Motorcycles
Cant get itouch to connect to internet even though bt hub etc all in correctly
If it's connected to your wi-fi connection and it's not working then there's something wrong with the BT hub if it's not connected to the wi-fi then it has to be a problem with that , try unplugging it and leave it for 5 mins and plug it back in and try it then . that usually works for me Hope this helps.
Apr 16, 2010 | Apple iPod touch
Control lock light is on and dryer wont operate
push and hold lock for 5 secs
if that does not work you may have a contol issue
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
TV WORKED FINE AND AFTER A THUNDER STORM, WONT POWER ON
Sets such as this still have power applied to stand-by circuits whenever it is plugged in. Try unplugging it for 5 min or so and then if normal operation does not return, ask around for a competent repair shop. With lightning or surges it can be either something "simple" to someone experienced (about $50 maybe) or well exceeding replacement cost. A power strip with surge protection is a good idea in the future, unplugging everything is better but not always practical.
Sep 05, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Installed a new steering column now the security system has kicked in and the car wont start even though i have power
Turn key on for 10 mins. security light should flash for ten min. go off turn ignition off and back on repeat procedure 2 more times total of 30 mins should crank up
Aug 05, 2009 | 1994 Buick LeSabre
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
1997 Mazda Protege LX 1.5
replace the fuses and check all the wire connections unter the dash by the pedals and under the hood if that doesnt work get your computer checked
Apr 02, 2009 | 1997 Mazda Protege
Drum light flashes
its the sensor, its not aligned to specs. make sure the drum is in its proper space then, unplug for 5 min to reset the control panel.
Feb 11, 2009 | Brother HL 5140 Laser Printer
Whirlpool Duet GHW9150P Front Load Washer Logo
234 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
