Question about ASK Proxima C460 Multimedia Projector
White appears as yellow, colors are off - ASK Proxima C460 Multimedia Projector
    Genius:
  • 1,175 Answers
Get into the setup menu and check your color settings
You should be able to adjust red , green and, blue plus gamma
Posted on Oct 11, 2010
Color wheel for ws55313
Model indicated here DOES NOT HAVE A COLOR WHEEL- so you might want to enter customer menu and call up CONVERGENCE-THEN advanced convergence---a grid of yellow lines should appear----are they showing blue or red skewed etc?
Other is to look with color off to see if black and white screen or not?
Jun 14, 2012 | Mitsubishi WS-55313 55" Rear Projection...
The white plastic(?) full length door handles OUTSIDE the refrig are turning yellow on my white, side by side refrig. What can I purchase or use to re-whiten them and make them look clean and white again?
That yellow coloring is most likely a result of the white paint coming off, and the yellow plastic color showing underneath. Other than painting them with a good paint, which you would have to ask a paint expert for the proper type, my suggestion is to replace the handles altogether.
Oct 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Blues' appear more green
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 05, 2010 | Philips Televison & Video
My game appears in black and white instead of color.
Ironically enough,I have serviced a Philips that has that problem,and the sticker that portrays the component/composite inputs were wrong and the jack coloring was wrong as well. dont be afraid to try different combinations as for what jack goes where
May 28, 2009 | Philips 47 in. LCD HDTV
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
When printing in color a yellow line appears on document
A horizontal line U say and U don't have problems in B&W pages.... ( on the length or width af a A4 page?) the yellow line is just a line or parallel lines at the same distance?.
1-st of all try replacing the Y cartidge.
Jan 17, 2008 | HP LaserJet 2840 Printer
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Dec 01, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Monitor problem- colour changes to white appearance to yellow appearance
COLOUR MONITER BASE COLOUR IC SOLDING AND BASE SOLDING OR CHEAK DATA CABLE
Mar 18, 2007 | SAMTRON 55V 15" CRT Monitor
Accurate color
Digital cameras rely on "white balance" to control total overall color accuracy as processed for the final image. Colors are greatly affected by light. For example, look at any wall in your home or office and you can easily see that shadows will make the color of the wall appear to be different shades. Sunlight has a very different effect on colors than incandescent light or florescent lights. Digital cameras start with white (the absence of color) to measure the effect of light and adjust the metering (measurement and accuracy) of all the other colors. Of course, white in a poorly lit room may appear gray or even yellow to some digital cameras. So how can you get accurate color? 1) Turn the Mode Dial to MANUAL MODE (Red camera icon with an "M") 2) Use the Arrow Down on the ENTER Button to select W/B (White Balance) 3) Press the center on the ENTER Button to select and adjust W/B (White Balance) 4) Use the Arrow Right (once), then Press and Hold the Arrow Down. Note: Continue to Press and Hold the Arrow Down. There will be a pause as you reach the bottom of the common preset conditions. Then a new "hidden" option will appear. 5) Once PRE SET appears, Press the center of the ENTER Button to select it. 6) A Special screen will appear. Point the camera direct at something WHITE, like a piece of paper, a white wall or a white shirt. Regardless of the lighting conditions, the camera will accept this "white object" as the new starting point "base of reference" or "True White". 7) Press the Shutter Button to program the new "True White" setting. 8) Press the center of the ENTER Button to accept and continue photography. These new settings will be saved as PRE SET True White conditions in Manual Photography Mode until you change the settings with another selection. This will not "go away" when the camera is turned off. These settings do not impact Auto Photography Mode.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Accurate color
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
ASK Proxima C460 Multimedia Projector Logo
94 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
