Question about Black Box IP Address Translator With Bandwidth Management (LR0051A) Proxy Server
Xbox 360 im running windows vista via a 3g broadband wireless ip adress failed could u possibly help me with this problem
  • kevsta2000 Jan 03, 2009
    cant connect xbox to 360 problem IP address
Try and check your RAM. If you have two RAMS remove one let the other runs for some time and observe, if it continue misbehaving change over to the other RAM. am sure either of the RAM is bad or if it only one RAM try and check wit a new one.
Posted on Jun 01, 2008
Xbox live ip address test fails
If you are using Windows XP or below, press START, click RUN and type "cmd". If you are using Windows Vista, press START, click the search bar and type "cmd". The command prompt should appear.
Type: ipconfig /all
Search the list for your network adaptor and make a note of the MAC address.
Turn on your Xbox 360 and go to network settings. Select manual settings and enter the MAC address under the Alternative MAC address option. Retest the connection. If your computer is connected to the internet, your Xbox 360 will be too,
Jan 24, 2009 | Microsoft Xbox 360 Console
Wireless adapter for xbox 360 isconnected to bt wireless broadband because the light on xbox is green, but IP failed
try going to your router page and find all the information on your ip address and everything else and put it in manually
Jan 16, 2009 | Microsoft Wireless Network Adapter Xbox...
Ip address failed
In order to connect your XBOX 360 to your laptop (if the laptop is connected via dial-up), you'll need a cross-over ethernet cable. It's a special type of ethernet cable, which is typically the same price as a regular ethernet cable, but it allows two devices (in your case) to communicate with each other. Then, you'll need to configure your laptop to allow incoming connections via your Control Panel -> Internet Connections preferences.
Hope this help!
Robert W.
Jan 08, 2009 | Microsoft Xbox 360 Console
My xbox 360 says i need an IP adress
The XBOX is configured for connecting to a router or server that will assign it an IP address. Connect it to your router instead of your laptop.
Jan 06, 2009 | Microsoft Xbox 360 Console
Xbox 360 Connection to internet
the IP address will fail when it is set on manual, rather than automatic. Be sure, once you enter it, it is set to automatic
Jan 03, 2009 | Microsoft Xbox 360 Console
Xbox live is not working
How are you connecting Your Xbox console upto your Internet ? if your Connecting Via WiFi, Make sure you have the Xbox compatible WiFi adaptor, if you are connecting Via a Local Area network, Ensure that your Console is hooked up Directly to Your Router, and if your connecting Via a Shared internet connection thru a PC, Ensure it is Hooked up correctly and also that your computer is set up to allow sharing the internet connection, That sometimes makes Xbox live faulty.
Also another problem for IP addresses not working is Due to your Internet service provider, Some broadband companies constantly renew IP addresses changing them every so often which the Xbox doesnt like. I would suggest contacting your Service provider and seeing if they have any Technical Support !
Oct 27, 2008 | Microsoft Xbox 360 Console
Xbox 360 setup
it way be that your modem and/or router does not recognize the ethernet cord. the contacts on either the cord or port might be fried. try plugging the xbox cord into the laptop port if the laptop is hooked up by cord or try using a wireless adapter for your xbox if the wireless seems to work fine with your laptop.
Oct 11, 2008 | Microsoft Xbox 360 Console
X box 360
Who is your ISP, (SKY)?
what modem is it ?
any other info....
May 31, 2008 | Microsoft Xbox 360 Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Xbox live connection
three is the network
connect and install three usb modem
connect xbox to pc with ethernet cable
then start right click my network places and go to properties in network connections right click 3 usb modem then properties then advanced, tick the box allow other network users' then okay
now connect 3 3g device turn on xbox and BINGO !
Dec 15, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
81 people viewed this question
Top Black Box Computers & Internet Experts
Johnny Massengill
Johnny Massengill
Glyn
Are you a Black Box Computer and Internet Expert? Answer questions, earn points and help others
