Question about Makita MAC5200 Electric Powered Air Compressors
Will only build pressure to 100psi of rated 140psi
  • 24 Answers
Chances are that the pressure switch, were you turn the compressor on and off, is bad. When they go out, they no longer build pressure to the regulated level you are looking for. If you haven't already, try turning up the regulator, if no more than 100psi build's, then it's a sure thing, bad pressure switch.
Posted on Jan 04, 2011
Will a air compressor that runs at 11.8 cfm at 90 psi run at 10 cfm at 100 psi?
if it is a 11cfm compressor then it produces 11.8 cfm of air regardless of the pressure
pressure has nothing to do with cfm but with the restriction to air flow
for example the tire inflator -air hawk- has a very small cfm but as the tire restrict the air flow the pressure builds up to set pressure on the gauge
so if you want 100psi from the 11.8cfm unit just adjust the pressure switch to shut off at 100psi
Cfm is only important when using air tools as a compressor that is not capable of maintaining the cfm thereby the pressure to run the tools is not a good idea
as an example
a sand blaster that uses 11.8 cfm at 100 psi will not work on your compressor
that unit will require a 20cfm compressor to run it peoperly
Sep 25, 2017 | Psi Air Tools & Compressors
Makita MAC5200 air is comming out of the cylinder side when running but still makes it to 140psi under 3 min
as long as the cylinder moves pressure will build up.but you will need to change gaskets on the cylinder
Jun 05, 2017 | Makita Air Tools & Compressors
Pressure switch shut-off set too high.
It is adjustable. Remove the square cover nut and adjust the spring tension. . It would be best to lower to 110-115 psi. The compression rings will thank you for it..
Aug 24, 2014 | Campbell Hausfeld CW210500SJ Pressure...
Pressure drops significantly before compressor starts
Some pressure switches can be adjusted with an allen wrench. You can't get more pressure from the regulator knob of the pressure isn't in the tank. look at the pressure switch with the cover off. If you see a screw with a spring around it. turn it clock wise 1/4 turn at a time until 125 is reached. The motor will labor more, so 2 hp may not be enough.
May 15, 2013 | Makita MAC700 2.0 HP Air Compressor
Adjust cw210500sj
My CW210500SJ is rated to shut the compressor off at 125psi but it shuts off at 140psi. Did you resolve your question?
Sep 08, 2012 | Campbell Hausfeld CW210500SJ Pressure...
When the unit is on and building pressure, the safety valve goes off before it reaches the factory set 150psi pressure. I then lose most of the air and it starts over until the safety valve releases again...
The pressure switch (on / off switch) must be adjusted or has failed. A qualified Bostitch Technician can determine if the switch can be adjusted or must be replaced. Each model is different and without the model number I cannot give you a more precise answer.
May 15, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
I have an Eagle 3 cylinder single stage compressor that i've had for years and it has performed flawlessly. Lately i've noticed that as it is building pressure the motor drags down to a lowly putt putt and...
I think you are correct with the motor problem but without the model number it hard to know what set up you have.
Eagle Compressors is now located in Belmont Mississippi so you can still get replacement parts for most of the Eagle compressors.
Thanks
Oct 03, 2010 | Eagle Air Tools & Compressors
Tank pressure will not build above 50 psi
don't know what model you have. They are all pretty similar tho. Look for the regulator should have a cover on it with a single nut in the center of the cover holding it on.Under the cover is a diaphragm and a spring. tighten the adj. on the spring the compressor will shut off at higher pressure. You don't want to exceed the max rating (ie: if is suppose to shut down at 100psi don't try to go higher.)
Oct 03, 2009 | Craftsman Air Tools & Compressors
Pressure switch out of adjustment
Before you adjust the perssure switch, make sure that the intank check valve is not leaking pressure back to the pressure switch after it cuts off at 140psi. The check valve should hold pressure at 140psi. Follow the discharge airline to the tank to find the checkvalve (either chrome or brass with large cap). To check for leaking valve, run compressor till shut-off at 140, then unplug the compressor from wall and remove the 1/4 air fitting at the checkvalve and check for leak. If leaking, replace valve and leave the pressure switch at present setting. You should be good to go. Good Luck with your repair and email if you have questions.
Apr 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Cut off switch problem
The pressure switch will trip off when the compressor reaches the rated setting (usually 120 ~150psi). If the compressor keeps running untill the safety pops releasing air (usually about 160psi) then the switch is most likely problem. I use SquareD switch from WWW.Grainger.com. However if the compressor keeps running but never pops the safety and only reaching around 90 to 100psi, then you could have several other issues including: leaking fittings (check with soapy water), worn cylinder and piston (on oilfree compressor examine cylinder from below and look for scratches), leaking valves on oil type compressor. Please email with your finding and any questions Good Luck
Jan 28, 2009 | Porter Cable Cable 4.5 Gallons 150PSI Job...
Makita MAC5200 Electric Powered Air Compressors Logo
265 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
