Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
There is water constantly draining through the drain valve.
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Grab a cap from the hardware store to stop it on the cheap. If it it is a brass drain valve you may be able to get away with draining the tank and replacing the small washer inside. Replacing the drain valve will be the ultimate solution.
Turn off the power on and electric or shut the gas valve to its off position.
Turn the water supply off above the tank or at the house main.
Connect a garden hose to the drain and open it all the way.
Open the safety valve on the top or side of the water heater to allow air in the tank so it will drain faster.
Unscrew the old drain valve with a pipe wrench.
Wrap plumber's teflon tape clockwise around the threads of the new drain valve and screw it into the tank by hand.
Tighten the valve with your pipe wrench until it is facing down at a 45 degree angle.
Close the safety valve.
Turn the water back on.
Open a faucet or two in the hows to let the air out of the tank while it is filling.
Turn the power or gas back on ONLY after the water heater it filled with water.
Posted on Oct 11, 2010
RUUD PVP75E-1 Gas Water Heater short cycling
1) Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Otherwise Rheem-Ruud does not post service manuals
http://www.ruud.com/products/tank_water_heaters/gas_water_heaters/
3) Sound like bad gas control valve thermostat.
Newer Honeywell electronic controls can be replaced without draining tank.
Older mechanical controls are replaced by removal from tank after tank is drained.
Feb 01, 2013 | Water Heaters
Steady water coming out of drain line
Bad safety shut off valve turn off the power and drain the heater and replace the valve
Nov 02, 2012 | Water Heaters
After plumber flushed out my gas water heater the valve where he connected flush hose leaks. 1st only a few drops, but now a dinner plate size puddle. It never leaked before this. I had the flush done
Put a brass garden hose cap over the dripping drain valve.
Call the plumber.
Absolutely the plumber should take care of this for you since the cap has to be tightened pretty tight.
See illustration:
http://waterheatertimer.org/images/drain-with-cap-500.jpg
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
Comment back and let me know what happens.
Oct 01, 2012 | Water Heaters
I just noticed that my hot water heater that is 6 years old is dripping very slowly from the bottom faucet, how can i stop this leak. thank you.
If you mean the drain valve, then buy garden hose cap at home center.
Cap will have rubber washer that seals tank.
If drain valve is plastic, the cap may not thread on without sanding down end of plastic drain valve.
Otherwise replace drain valve, which is simple if drain valve is brass, but can be difficult if drain valve is plastic.
Turn off power to water heater: Electric: turn off circuit breaker. Gas: turn knob to pilot.
Turn off water, open bathtub spigot on Hot side, drain water heater, remove drain valve with wrench.
If plastic drain valve breaks while being removed, then 'gently' break out broken part using hammer and big screwdriver.
Buy new drain valve at box store in water heater department.
Put teflon tape on new drain valve threads.
http://waterheatertimer.org/Water-heater-is-leaking.html
http://waterheatertimer.org/Water-heater-will-not-drain.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
My pressure relief valve on my boiler is allowing water to pass through constantly.how do i adjust it to stop the water flow? only have about 15 pounds of pressure in system
Even a small amount of crud on the rubber washer/sealer can cause the valve to seep. Some valves can be taken apart and cleaned but it will be better to replace the valve. They can be found on line for around $12 or more. You will have to shut off the water in take valve and drain most of the system unless you have a main line shut off valve so the system wont drain back into the boiler. These valves are usually set at 30PSI.
Feb 21, 2011 | Watts Regulator Temperature and Pressure...
Water heater drain valve leaks
You have two choices. First make sure you are dealing with the drain valve and not the temperature and pressure relief valve. Then you can either cap the drain valve with a garden hose cap or you can drain the water heater and replace the drain valve - if you chose replace make sure you get a water heater drain valve (3/4" MPT).
Please rate my answer!
Mar 18, 2009 | Fasco Bradford White Hot Water Heater...
Dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches.     Normally the drain valves are plastic with a Male hosebib attached.  Attach a  garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve.  If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level.     Replace the P/T valve  and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads.    You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
Jan 31, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
189 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
