Question about Cub Cadet Garden
Kohler ch18f revs up and down at half throttle. is this normal?
    Scholar:
  • 150 Answers
No this isn't normal. Sounds like high speed adjustment is to lean. Back it out counter clock wise with machine running until it smooths out.
Posted on Oct 11, 2010
98 saturn with trottle wide open engines revs up then down
Sound like you have a bad TPS. Also make sure your throttle body is nice and clean, that will contribute to the problem.
Aug 18, 2014 | Reliance 98-02 Saturn Sc Sl Sw Series 1.9l...
Need instruction on how to adjust carberator
Adjusting carbs on chainsaws is not to be taken on lightly, there will normally be three screws, an L screw, an H screw, and an idle scre, the L screw will increase the fuel mixture from idle to half throttle ( they are fuel screws not air screws ) the H screw will adjust from half throttle to maximum revs, start with a base setting of between one turn and one and a half turns out, start the saw and warm through, allow it to idle, if need be increase the idle screw to get an idle, turn the L screw in slowley, the revs will increase as the mixture leans off, it will reach a point where it starts to die, now back it off a quarter of a turn, blip the throttle, the saw should pick up clean, if it has a flat spot increase the L screw slightley, now set the idle so it idles without the chain moving on the bar, now screw the H screw in to get full revs, be aware this should be set with an engine rev counter, do not exceed the manufacturersmax revs, hobby saws normally run at about 12500 rpm with an idle speed of 3000 rpm.
Oct 26, 2011 | Garden
I HAVE A CRAFTSMAN KOHLER THAT WILL RUN WHEN
the foat could be plugged or not alowing enough fuel to get into carb.
Jul 08, 2010 | Craftsman Garden
Won't idle until it is warmed up
Depending on the type of intake system, if it's a normally carburettored bike, there is an air mixture screw on your carby(s). Set this screw at one and one half turns out from being screwed to stop. Run bike till it is warm and set IDLE screw or throttle stop at optimum idle revs. Without using choke or throttle, turn the air mixture screw slowly in or out till revs build to highest level. Reset idle screw or throttle stop to set revs back down to optimum level as before. If this does not cure your problem, depending on if it's a 2 or four stroke, single or multi cylinder engine your problem may be one of many from fuel ratio, valve rocker clearance, ignition, plug range etc....specify make/model for proper info.
Cheers
May 19, 2010 | Motorcycles
2001 Tiburon high rev problem.
Throttle position sensor or idle control sensor. Try cleaning the map or maf and throttle body first.you can get the cleaner at parts stores or walmart. Takes about half an hour.
Sep 13, 2017 | 2001 Hyundai Tiburon
Engine revs up and down, improves when choking half way
Sounds like to me that your governor may need to be adjusted. Too much detail to explain here as to how to do it.
A dealers technician can fix that in 5 minutes if he knows what he's doing.
Sep 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Suzuki 2009 DR-Z 250 won't rev past half throttle
I would have it checked out. I know that it has limitors on it but it shouldn't be half throttle. It should rev as soon as you start twisting the trottle.
May 21, 2009 | 2001 Suzuki DR-Z 250
Kohler lp shuts down
What you need to know is there enough fuel going to the regulator. It should be 7 to 11 inches Water Column. If not your problem may be not enough fuel. That includes when the heater in your house kicks on and what ever gas appliance you may have. Once you verify that you need to figure out if you have the proper pressure coming out of the regular on the inside of the generator. Next I would look at compression of the cylinders. It may need new piston rings.
Dec 13, 2008 | Kohler 12 kW Emergency Power System -...
Garden Logo
113 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
