Question about Insignia 1200W Class D Bridgeable Mono Amplifier
What is the data link jack input on a 1200 watt insignia amplifier used for
2 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: what is the, data link jack input, on a 1200 watt
The radio shack site should have the manuals for that
Posted on Oct 11, 2010
How do i bridge a 1000 watt amp to two 1200 watt subs
a sony 1000 watt rating is an exagerration. you will blow your 1200 watt speakers far before reaching sonys claim of 1000 watts
Jul 10, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
Just wondering if i really need to run the wires "sensing power on & HIGH LEVEL INPUT" from my amp to my deck..?
If your deck has RCA's use those. If not then run your high level input wires to the output wires on your deck. If it is not stock, then it should have RCA's
Sep 03, 2011 | Sony Z2X-1200 SPL Car Amplifier (1200...
How do u know if A sony xplode XM-552ZR amp is on and how do u connect it to a sony xplode cdx-gt570 head unit.
Just to the left of the output (speaker) terminals, near the top of the amp, there's an LED marked "POWER/PROTECTOR". If the amp is connected properly and powered on, the LED is ON.
If the amp is being used for normal speakers, use a pair of RCA cables and connect the left/right channels to the appropriate inputs on the amp. The switch marked "LPF" should be "OFF".
If the amp is being used with the channels bridged for a subwoofer, use an RCA "Y" adapter and connect the single "Sub Out" preamp output from the head unit to both amp inputs. The switch marked "LPF" should be "ON" and the crossover set to about 80-100Hz.
Nov 03, 2010 | Sony Z2X-1200 SPL Car Amplifier (1200...
I hooked up 2channel 500 watt amplifer and 1200 watt 300 rms subwoofer now the protection light comes on when i turn up volume
your speakers rating is too low for your amplifier. 300 watts RMS means the speaker can operate on an average of 300 Watts continuously. the 1200 watt rating is peak wattage input and meant for intermittent intervals only, a like a bass drum beat count. also , your speaker impedance must match your amplifier impedance or the speaker must be a higher impedance than the amplifier. Never lower than the amplifier's impedance output rating. If The amplifier is rated into an 8 ohm load, your speaker must be 8 ohms or higher. in other words you cannot use a 4 ohm speaker or you will damage the amplifier .
Mar 14, 2010 | Car Audio & Video
I have a RF punch 401s 1200 watts and the RCAs broke off the mother board what do i do to fix it
If you have a soldering iron simply epoxy the jack down to the board and then take some wire and solder rthe center conductor of the RCA jack and the other end would go to the trace on the PCB. Do the same for the ground connection.
Jan 26, 2010 | Rockford Fosgate Punch 401S Car Audio...
A3200e wattage
Here are some specs:
  • 4800W Max, High-Current 2-Channel Car Amplifier
  • RMS Power Rating:
    • 300 watts x 2 chan. @ 4 ohms
    • 600 watts x 2 chan. @ 2 ohms
    • 1200 watts x 2 chan. @ 1 ohm
    • Bridged:
      • 600 watts x 1 chan. @ 4 ohms
      • 1200 watts x 1 chan. @ 2 ohms
      • 2400 watts x 1 chan. @ 1 ohm
  • Max Power Output: 4800 watts @ 1 ohm
  • this is the web site I got the specs from
  • http://www.sonicelectronix.com/item_61_Audiobahn+A2300HCT.html
  • Hope this Helps...
  • Jul 22, 2009 | AudioBahn A2300HCT Car Audio Amplifier
    Logic alx1280 2 ch amp
    Amps can be rated based on their RMS power or their peak power. In this case, the amp's rated RMS power is 300x2 at 2 ohms (total 600W RMS) with a peak power rating of 600x2 (1200W peak). For the most part, peak power means almost nothing.
    If your head unit didn't have RCA preamp outputs, you would used the standard speaker outputs from the head unit and connect them to the hi input plug of the amp.
    Mar 17, 2008 | Logic Soundlab ALX1280 Car Audio Amplifier
    Insignia 1200W Class D Bridgeable Mono Amplifier Logo
    252 people viewed this question
    Top Insignia Audio Players & Recorders Experts
    Alan Matzke
    Alan Matzke
    jason
    Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
