Question about Gateway P-6313 Notebook
I have a gateway p6313 i have no wireless every since i rreformatted my computer but wi-fi light is on any idea which driver i need
Pyrhyc
  • 2028 Answers
SOURCE: Drivers for Wi-Fi (drivers for Ethernet Controller and Modem Device on high definition audio bus)
Not much offered at Compaq's driver site for XP. For the modem driver, try the link below, it says it's for Vista, but it should work. If it doesn't then you will need the make and model of the modem, then go to the manufacturer's site or driverguide.com for the drivers, and the same for the wireless, make and model, manufacturer's site or driver guide. To be honest with you, modems are just about obsolete, unless you have dial up at home, you'll probably never use it.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&lang=en&dlc=en&product=3739733
Posted on Jul 09, 2008
Jack_Dawson
  • 287 Answers
SOURCE: DRIVER PCI MODEM & WI-FI FOR NOTEBOOK A*NOTE MODEL CL51-14
search it with ur model no. on Google Serach !
Posted on Jan 07, 2009
  • 54 Answers
SOURCE: after shutdown of gateway laptop blue power button stays lit.....
Hi this sounds like your computer is in hibernation mode as opposed to shut down mode. Could you check and see as if running Vista many people assume that clicking on the brown power type selection under start that they are shutting down where as this actually only hibernation mode and clicking on the little arrow to the right of this and selecting shutdown is the way to go.
I hope this helps
Posted on Apr 07, 2009
SOURCE: hi my name is Ali blanc , i hade several probleme
Olá, boa noite
estou precisando de ajuda para configurar o bios.
Na inicialização tenho que tecla f1 não inicia automaticamente
As vezes o windows não carrega.
A placa é msi v class o windows é vista.
Desde já agradeço.
Posted on Mar 18, 2010
  • 84 Answers
SOURCE: how do I enable wi-fi on gateway mx6920 laptop
Follow this link to get the drivers for your machine. Be careful to read for the newest udated drivers. https://support.gateway.com/s/Mobile/Q106/BladeC/1009030nv.shtml
Posted on Mar 21, 2010
Wi-Fi stopped working on my Gateway NV77H19u. I can connect to the Wi-FI from a different laptop. Is there an external switch on the NV77H19u to use Wi-Fi?
Your Gateway either has corrupt drivers or has forgotten your WiFi.
Go into your device manager and remove the WiFi device. Then have your computer search for any hardware changes. It will find your wifi device and reload drivers. If this does not work, you have a bad wifi card.
Semper Fi,
Z
Jan 31, 2018 | Gateway Computers & Internet
Wi fi is on but still can't connect to the internet
Not only does Wi-Fi have to be on, but it has to be connected to a wireless access point (sometimes called a wireless router), and the wireless access point has to be properly connected to the internet.If the wireless access point/router has empty ports on it, plug your computer into one of those ports, and see if you can connect to ther internet then. If you can, the problem is somewhere between the wireless access point/router and the computer. Could be the transmitter part of the wireless router, could be the wireless network adapter on your computer, or could be the driver that runs the wireless adapter on the computer. If you cannot access the internet when you plug into the wireless ap/router, then you need to go one step "upstream." This would likely be the cable modem or DSL modem. Plug directly into that with your computer, and reboot both the modem and the computer (just unplug the power from the modem and then plug it back in to reboot the modem). If you can connect to the internet then, the problem is the wireless router/ap. If you cannot connect to the internet then, contact your ISP.
Feb 09, 2012 | Gateway 7330GZ Notebook
How to activate facebook without wifi?
Accessing Facebook needs internet connection. Without any active connection, you will not be able to connect to internet.
Internet connection option for such devices:
Mobile phone:1. GPRS - settings will be coming from your mobile service provider, data rates will be deducted from your load credits.2. Wi-fi connection - needs active wireless connection from your modem/router/gateway. Charges will be applied via ISP 9internet service provider)
Laptops / computer / PSP:1. USB Dongles - this will use the gateway connection via BTS for its using the internet connection like the protocol of ISP.2. Wi-fi - Wi-fi connection - needs active wireless connection from your modem/router/gateway. Charges will be applied via ISP 9internet service provider)
Thank you for choosing www.fixya.com.If you have any other issues under the sun, just post your questions here and we will provide you the answer.
Dec 01, 2011 | Myphone Computers & Internet
How to install broadband to android tablet pc?
Share 01 Feb
2011 How to configure IP address of wi-fi connection on a Android Phone (Samsung Galaxy Tab) Posted in: Gadgets Tagged Under: Android, Galaxy, Samsung, Tab 7 Comments samsung_galaxy_tab-small-1.png
By default Androids phones (including Samsung Galaxy Tab) are set to automatically configure IP address, Gateway, Netmask and DNS address of wi-fi network.
But if you want to manually assign IP address, Gateway, Netmask and DNS address of wi-fi, here is how you can do. Method below is described for Samsung Galaxy Tab, but it will work for all Android phones.
  1. On Home screen, press Menu key.
  2. Tap Settings
  3. Tap Wireless and network.
  4. Tap Wi-Fi Settings.
  5. Press Menu key again.
  6. Tap Advanced.
  7. Enable "Use Static IP".
After you have enabled "Use Static IP", you will be able to manually assign and configure IP address, Gateway, Netmask and DNS address of wi-fi network.
Sep 23, 2011 | Android Apps
Printer is not responding to wifi network. everything has been checked but i may have missed something
To set up a wireless printer in your system, your computer needs Wi-Fi hardware and the Wi-Fi connectivity enabled. If you face any issues with the Wi-Fi hardware or your Wi-Fi driver, you will have issues in setting up your Wireless printer. You need to make sure of the compatibility of your driver with your Operating System. An incompatible or a corrupted driver will also create issues in running the set-up.
Jan 11, 2011 | Office Equipment & Supplies
I am unable to pickup internet wirelessly with my computer.
Hi Fred!
I have checked the specification of your laptop here and found that your laptop is Wi-Fi capable and wi-fi drivers are available and can be downloaded and installed here. (if required)
Most Gateway notebooks have a designated multi-function button or function key to turn your wireless on and off. There should be a tiny slide switch or button with a small antenna symbol. There should also be a light with the same symbol to show when it is on and from the keyboard Press Fn+F2 to enable wireless.
Let me know if any further clarification/ assistance is required.
Good Luck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 14, 2010 | Gateway MX6421 Notebook
I have a laptop dell with vista windows, i want to make it wireless , using my wireless router ,how do it using the model of birght house step bystep. thank you.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Then in vista make sure wireless lan driver installed then right clickc on wi fi icon and click on view available wi fi then you can connect it.
Let me know if you need further assistance.
Thanks for using FixYa.
May 05, 2010 | D-Link AirPlus DI-614+ Wireless Router
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
Gateway PC crashing when connecting to Wi-FI
if i was you i would load up a version of win xp on another hard drive inserted into your laptop, load the drivers for the laptop including wi fi drivers then see if ok. if not you can be sure its a faulty wi fi card in your laptop,you need to disable internal wi fi card remove,replace it.but first try borrow a pcmcia wi fi card just to check if everythings ok
Dec 06, 2008 | Gateway MX6438 Notebook
Wi Fi driver downloading
Yes that should work fine, just as long as you download the driver for his card and his OS.
Sep 21, 2008 | Computers & Internet
Gateway P-6313 Notebook Logo
46 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
