Question about Linksys BEFSX41 Router (DHBEFSX41)
I am trying to change some settings in the port forwarding. When I go to save it ask for my log-in info. But it will not recongnize me. I know I am using the correct log-in info because I am IN. I have the most up-to-date firmware. Any suggestions?
    President:
  • 1,768 Answers
1. try typing the user/ password into a word pad or to see if you have caps lock on
2. just try typing "admin and leave the password blank and hit enter.
3. If you are still unable to enter properly then reset the router to default and establish
new user information for the router.
Posted on Oct 11, 2010
Have not been able to download from "utorrent" for days. says waiting to log in and when I do tests it says the forward port is not working, however should download. it does not. can you help please. Lyn
Do you know how to log in to your router and adjust the settings? Most likely it IS a port forwarding issue. Most routers have a way to set up one device in a way that frees up all ports for forwarding. If you know how to do this let me know so I can try and get detailed instructions.
Nov 21, 2013 | HP Pavilion Computers & Internet
Echolink port forwarding problem
such a complex topic and so little info!
to reach an open port you need to know a couple things
1) the ip address your trying to reach x.x.x.x
2) the port you will use :xxxxxx
and it can be put into a browser like so 71.233.23.40:8080
to make it so people can reach you is the fun and dangerous part!
things you will need:
1) your wan ip (google "what is my ip")
2) the specific device you are making available's lan ip (cmd - ipconfig /all works well on windows)
3) what port your supposed to open (i'm sure the documentation or program says somewhere)
log into your router and find the port forwarding and triggering section under advanced in a netgear (application and gaming in some others)
1)name it
2)put the number to open in twice
3)select protocol (ive usually used tcp... udp for file transfer sometimes)
4)fill in the rest of your lan ip
5)tick the box to enable and save settings
now there is a hole letting traffic on a certain port reach the named lan ip... OH, make certain that device has a static ip, if its ip changes you'll find headaches at inconvient hours.
hope i got you pointed the right way
Mar 18, 2013 | NetGear N600 Wireless Dual Band Router
Hello, i wonder if anyone can help me.. i was given a router today i set it up and it was working perfectly. When i turned my xbox360 on and went on to a game and it said my NAT was moderate. so i tried to...
For resetting the router You have reset key on the back of the router, press and hold the reset key with any sharp objects like toothpick or a paper clip for 35 sec(or more) From the xbox you have to manually enter the ip address
Configuring port forwarding In order to configure this, you need to know:
- The IP address of the computer or device to have the port forwarded to.
- The port numbers to be used and whether these are TCP or UDP ports
(Note: We recommend you use a computer that has a wired connection to the router.)
Oct 04, 2010 | Belkin (F5D7230-4) Router (587009)
Remote Access
IF you are getting public ip from your isp, please go to administrator tab of the router and first change the router's password which is on the top on same page in black dots,,type your new password by deleting old one and re-confirm it just below and save it..router will prompt for the new password just to let you know settings are saved now enable remote managment option on the same page and port is 8080(default, you can use your own port number) and save setting..now you are ready to access your router remotely for that note down the public ip you are getting on your router's status page and in remote location you need to type something like :- http://x.x.x.x:8080...x.x.x.x is your internet ip (public) and 8080 is port number for remote management.
For host applications need to know which application you are running according to that need to open port in the router using Port Forwarding feature of the router.
Jul 15, 2010 | Linksys Wireless-N WRT150N Router
How to set port forwarding?
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. By default the IP address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are blank. Click the Ok button to log in to your router.
Click the Firewall button near the top of the page. Use the Protocol drop down box to select the protocol type of the ports you are forwarding. If you are forwarding a single port, enter that port number into the LAN port range, Left WAN port range and the Right WAN port range boxes. If you are forwarding a range of ports, enter the lowest number of that range into the LAN port range, Left WAN port range box. Then enter the highest number of that range into the Right WAN port range box. Enter the IP address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box. When you are finished, click the Add button.
When you're finished, click Save near the bottom of the screen to save your changes.
And that's it! You're done! Hope this helps.
Dec 22, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
How to port forward with netgear wgr614
Start>Run>Cmd
Type: ipconfig
a list of numbers should come up. After that, open up your web browser. Look for the number that comes after "Default Gateway"
Enter that into your web browser. It will take you to a page that might ask for a password. Try "admin"
From there you go to basic settings and there should be spots for you to add ports acceptations.
Add them then "apply" or "save" the settings.
After that it will ask you to reboot for the changes to be saved. Do that and you should be good to go man. Make sure you allow the ports through your firewall too.
Good Luck.
Jul 10, 2009 | NetGear WGR614 54Mbps Wireless Router...
Port forwarding & Remote Management setup on Linksys WAG200G
here is how you set up port forwarding:
1. log into the router;
2. Click the Applications & Gaming link near the top of the page. 3. You should now see a new menu. Click Single Port Forwarding or Port Range Forwarding.
4, Enter sth like: HTTP; 80; 80; TCP; 192.168.0.1; check
5. When you're finished, click Save Settings near the bottom of the screen to save your changes.
go to administration-> remote administration to set up remote management
Remember, remote Administrator requires you to forward the 4899 ports.
Mar 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Port Forwarding in DI524
Log into router
- Default ip should be 192.168.0.1
- Go to advance settings
- Open ports that are needed
- save settings
Aug 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Port forwarding
hi there,
this is a basic step used to forward ports to your system.
Port Forwarding Steps for Routers 1. Log into your router. Usually the URL is http://192.168.1.1/, and enter the username , and the password . If you have never set a password, the password (which you should change) is admin. Consult the manual if you have never set up your router before or need to reset the password. 2. Click on the "Applications & Gaming" tab or Under Advanced, click Port Forwarding.
3. Click on the "Port Range Forward" tab .
4. In the "application" field, type "web" (if you are forwarding wb traffic on port 80) or "torrent" (if you are forwarding bittorrent traffic on port 40156). This is just a "nickname" so that you can recognize what you were trying to do when you come back to it.
5. In the "Start" field, enter: 80
6. In the "End" field, also enter: 80
7. Set "Protocol" to TCP. Web and Bittorrent servers use only TCP, so there's no reason fo forward UDP traffic too and create an unnecessary security risk.
8. In the "IP Address" field, enter: 192.168.1.11 or your system IP address.
9. Click "Save Settings." Forwarding should begin immediately.
Apr 15, 2008 | Computers & Internet
Utorrent downloads with WRT54GL?
Before we can forward ports for Utorrent, we need to figure out what ports Utorrent is using. Here is a brief walkthrough on how to do that. Go ahead and open up Utorrent.
Click Options in the menu at the top of your screen. In the list that drops down click Preferences.
Click Connections on the left hand side of the Utorrent program. You should now see the menu shown in the screenshot above. Make sure the Enable UPnP box is unchecked. The number in the Port Used for Incoming Connections box contains the port you need to forward. You can change the port number, if you want to. Please enter the port you chose into the box below.
Utorrent's Port for incoming connections To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step! Please enter the static ip you want to forward to: 192.168.1.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
Port Range Application Start End Protocol IP Address Enable To Both 192.168.1. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Utorrent requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Port Range Forward menu.
Feb 21, 2008 | Linksys Wireless-G WRT54GL Router
Linksys BEFSX41 Router (DHBEFSX41) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
