Question about Kitchen Ranges
My liftmaster garage door is beeping at me. I called a repair shop and they said it was the backup battery. I have removed the cover and can unhook the red wire from the battery. The black wire won't come off. Should it just pull off? It also feels like the battery is attached in the back and won't pull all the way out. Before I take the entire cover off I wanted to ask the experts. Additionally, I want to be sure I'm just supposed to pull off the black connection before I break it. (May take some "I don't give a **** if this breaks, I'm just going to "brute force" it off.) Thanks!
    Top Expert:
  • Kitchen Ranges Master
  • 12,962 Answers
Both wires are of the pull off variety. Spray a little WD 40 on the negative terminal to make it easier to slide off.
Posted on Apr 19, 2017
  • 4 Answers
SOURCE: Oven lower element wiring
I just looked at the back wiring of my JBP90 oven. The main element (bottom) has both black wires together on one element terminal and the single yellow wire on the opposite terminal. Not that it should matter, but both blacks are on the left and the yellow is on the right as viewed from behind the oven.
Good Luck!
Posted on Nov 22, 2008
teknowolf
  • 207 Answers
SOURCE: Removing cover from Dell Dimension 8250
Stabalize163,
Dimension desktops usually have a hinged case. With an oval shaped buttton on the top AND bottom. Push both of these buttons and pivot the side panel open. Take it slowly because its usually quite crowded in there and you don't want to pinch your wires/cables between the drive cage and the chasis or end up ripping them out.
Thanks for choosing Fixya
Dave
Posted on Dec 31, 2008
SOURCE: frigidaire compact 30 elec. stove.
My frigidaire compact 30 just bit the dust and I removed it finding the wiring diagram on the back. do you still need/want this?
Posted on Jul 04, 2009
SOURCE: Oven Not Working and Door Catch Broken
If you turn the oven on and set it to the highest temperature you will see a black coloured cover plate at the rear of the oven with holes in. Located beind this cover is the oven element. THis after a few minutes at most should be glowing red, the fan then circulates the heat so that the oven reaches the required temperature. IF this is not glowing then the element is blown. If your house fuses tripped this is also a fairly good sign that this is the element. Zanussin provide a spare element for £48.50 but take 7 - 10 days there is a man called element man on the web, he provides the same for £24.50 and delivered in a day. I have had two elements go on me in 6 years... hope this helps ....Jack
Posted on Jul 29, 2009
  • 160 Answers
SOURCE: How do I replace the light in the oven? Unscrew
these oven lamp covers if not been turned in a while will be baked on.. you have to force the twist with teatowel, truth be known the glass is pretty thick and i think i have only lost 1 in many years of repairs .... if able to loosen when replacing do not overtighten..
do not use wd40 or lubricants to shift as when in operation the smell will be terrible as well as rendering the unit unuseable
Posted on Dec 18, 2009
My liftmaster garage door openers as a constant alarm noise. Not beeping. Just constant. How to fix?
Premium Chamberlain garage access systems feature an internal battery backup that will operate the opener in case of a power outage. The garage door opener will emit a beeping sound when it is operating off of battery power or when the battery is no longer able to recharge. needs a battery.
Hope this helps.
Dec 31, 2017 | Building Materials
Battery is bad. I removed it and garage door opener is still beeping. It is driving me crazy. Help
as long as garage door is powered(plugged into outlet), then with a removed battery backup or a bad backup battery, the unit will beep to alert you to the issue. replace the backup battery with a new/good one.
Jul 11, 2015 | Chamberlain 3/4-HP Whisper Drive Plus...
Alarm on garage opener is going off
Do you have a model with a battery backup on it? The battery, like most batteries, eventually wears out and will start beeping. If you don't have frequent power outages in your area, or have another way to gain entry to your home if there were a power outage, (like an old fashioned key), locate the battery which is approximately 4"x5" located on the outer side of the opener motor head, unplug it and forget about it. This would get rid of the beeping noise. Or you can replace the battery.
Nov 01, 2013 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener is continuoulsy beeping. It is only four years old
This issue is almost ALWAYS the battery needs to be replaced. The beeping is because the system is not going to work in a power failure....Batteries on constant and variable charge seem to have much shorter life.
Jul 21, 2011 | liftmaster 485LM EverCharge Battery Backup
Have a chamberlain lift master garage door opener with evercharge battery backup red led light on followed by a beep every 30 seconds. Need to find out how to get rid of the beep or fix the problem.
It sounds like the battery system is not working. How old is the battery, they do eventually, just quit working, and require battery replacement. Extract and test the battery. try an external (different) charger.
Jul 16, 2011 | liftmaster 485LM EverCharge Battery Backup
Red service light is on the diehard battery backup of my craftsman garage door opener.
time to change the batterys- they cost $90. and owner can install or a gdo repairer can, but consumer should, its harder to make coffee then replace these batterys.....
Nov 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
The garage door is closed and wont open, it beeps and all the LED's light up. there is no obstructions. I think that it keeps to try and shut but already is. Its a securalift GDO - 7 V1
Tries changes batteries in the remote,unplug the main operation motor,replug it,see if it reset it self.This a temp.fix,call the mamfucture for repair or replacement.
Oct 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kitchen Ranges Logo
995 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
