Question about Garmin iQue M5 GPS Receiver
Garmin IQue M5
Garmin IQueM5 loses all data when battery is changed. Programs, user info everything is lost and must start as if new. It seems the internal backup battery is completely discharged. How to fix?
Make a sprite backup to an SD card before changing battery. If you lose data just restore it from the backup.
Posted on Jul 20, 2008
Battery drains in sleep mode
most GPS will drain in sleep mode unless on some slow charge. Everything is actualy working inside except the screen Like the TV standby.. no picture or sound but chews up the power
Jul 19, 2009 | Garmin iQue M5 GPS Receiver
Garmin iQue M5, Not aquiring satellites
Two possibilities - Antenna (in power cable) or electronics related to antenna. First, do a hard reset. Place the pen top into the RESET hole for 3 seconds...
Next, when the unit is powered, page over to the screen showing satellite signal strength....
If NONE appear within 1 minute (and you are outside and NOT under trees), you have an antenna or antenna interface issue.
Garmin WILL repair the unit for 3 to 4 times its value... A 265WT GPS is cheaper, faster and more accurate. The IQUE is no longer worth repairing....
-Jim
Apr 07, 2009 | Garmin iQue M5 GPS Receiver
Garmin iQUE M5 antenna broke off
BUY A EXTERNAL ANTENA PART #010-10702-00 FROM GARMIN IT PLUGS INTO THE UBIT ON THE TOP WHERE THERE IS A RUBBER CAP
Feb 06, 2009 | Garmin iQue M5 GPS Receiver
IQUE M5 Antenna broke off
BUY PART NUKMBER 010-10702-00 FROM GARMIN IT IS A EXTERNAL ANTENA THAT PLUGS RIGHT INTO THE UNIT.
I would like to get routable map of Thailand that could be used on my Garmin iQue M5 PDA.
I only needed a simple answer to the question of whether the iQue M5 would take a Thailand Map. Actually, I waited for twenty minutes on the special Garmin line for this discontinued product and gave up, deciding that it probably wouldn't work.
Sep 19, 2008 | Garmin GPS
Garmin iQue M5
I had mine fixed by a GPS Repair Service, they also have a gps repair guide if you want to try a self-repair.
Aug 14, 2008 | Garmin iQue M5 GPS Receiver
Active Sync USB OK but City Navigator won't find device.
Somewhere I read that if you do a soft reboot to the iQue M5 it will connect to the City Navigator. I did this and it seemed to work, although between downloading and uploading I had to do it again. The process of loading map set (entire US) took an extremely long time (about 3 hours). Also, if you try to receive maps, waypoints and tracks from device all at once, it chokes.
Jul 20, 2008 | Garmin iQue M5 GPS Receiver
Garmin ique m5
eBay should have some, though they may be used.
May 24, 2008 | Garmin iQue M5 GPS Receiver
IQueM5 - Screen issue/question
First of all check out this manauls perehps you can Find a soultion there https://buy.garmin.com/shop/store/manual.jsp?product=010-00344-00&cID=165&pID=246 2nd, if you can post a Photo of the monitor and the lines that you speak about perehps somone will understand it better 3rd, Can't you see anything in the monitor?
Apr 30, 2007 | Garmin iQue M5 GPS Receiver
Garmin iQue M5 GPS Receiver Logo
152 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
