Question about Craftsman Garden
I have a Craftsman 4-cycle tiller #316292710. The engine starts and idles fine, but when I give it gas, the engine dies. The choke is in the close position during starting, but then I move it to the open position after the engine has warmed up.
jelsegood
  • 32 Answers
SOURCE: Maxim tiller won't run
Try better quality gas. I had the same problem. Ethanol too high in lower grade gas. Buy better grade or ethanol free. Mine works fine with better gas.
Posted on Apr 06, 2009
Healeyman
  • 1198 Answers
SOURCE: engine starts but sputters then dies when set to run when warmed
Take the carb apart and clean it. Carb spray should do the job. Check the little holes in the brass part that goes down thru the float bowl. Run the engine out of fuel at the end of the season, don't let gas sit in the carb too long.
Posted on May 01, 2009
  • 138 Answers
SOURCE: Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Posted on Aug 21, 2009
  • 61 Answers
SOURCE: ihave a craftsman 5hp(briggs&stratton) reartine tiller that won't
Hi.....I am assuming that you have a bowl type carberator on that tiller. If so, the bolt on the bottom of the bowl, is the main jet. If you remove it, you SHOULD, see a hole drilled from the top down to a hole cross drilled thru, near the bottom. Run a small wire thru these to be sure they are clean. Other then this, I'd install a new needle and seat. You can purchase just a needle and seat set, no need for a complete rebuile kit. You will also need a bowl gasket, and if you have a primer bulb, you will also need a new intake gasket or the primer will not work worth a darn. Hope this is of some help, good luck
Posted on May 29, 2010
  • 110 Answers
SOURCE: have a tecumseh ohh50 4 cycler engine on a garden
Check for condensation in the tank. Fill with FRESH gas, then if no luck, proceed ...
Main jet partially blocked. Undo bowl nut. Some models have the jet in the side of the nut - check and clean. If not, the jet is in the emusion tube of the carb - accessible throught the bowl nut orifice. Clean out & test.
Posted on Jul 24, 2010
Will start and idle,but give it gas and it dies.
Hi Tammy:
Make sure the air filter is clean.
Check the muffler. Sometimes they get clogged with carbon and the unit will idle but dies when you try to increase revs.
May 04, 2015 | Craftsman Gas Mini - Tiller/Edger
Managemylife
Crank engine a few times. If spark plug is dry carb needs dismantling and cleaning. Probably gummed up.
Jul 10, 2014 | Craftsman 4-Cycle Mini Tiller
Poulan pro ppb350 weed trimmer stalls when choke is open
-After start for 10-20 second. Choke lever should turn or move to full open before need more gas. Why it stop when you give more gas..?
Because the engine need more air to burn the gas.
Good Luck
mai
Jun 06, 2014 | Garden
My MTD Yard Machine Y2500 starts fine and works with the choke partly closed. It also idles fine with the choke fully closed but stalls when I press on the throttle when the choke is fully closed.
when the choke is fully closed your choking the fuel out,, thats why when you give i t gas it dies , its not supposed to run with the choke on and getting fuel , use the choke only until the motor warms up to operating temp,, then open it,, and you should be fine,
Jun 01, 2011 | Mtd Garden
Machine runs fine for approx 20 mins. Thereafter when drive is engaged will run for 20 seconds before engine starts to die .If drive is disengaged engine will idle fine until drive is engaged and problem...
your engine is starving for fuel supply. Remove fuel line from carburator. If fuel flows from line remove carburator and clear obstruction from needle valve and insure that fuel is not being restricted. If fuel flow is slow: clean and rebuild if necessary the fuel pump (if applicable) or follow fuel line to fuel tank and remove blockage: in line fuel filter fuel, tank strainer, or on and off valve that may be choked off.
Mar 02, 2011 | Mantis 4-Cycle Tiller
Craftsman tiller, 850 series, model 917.297032, Briggs and Stratton engine, will start but not run. If it does start, it's a rough idle, and it kills as soon as I move it off of choke. I have cleaned...
It could be the gas you are running in it, if it contains ethenol use some stabil in this type of gas. Ethenol attracts moisture and will cause the carbs. on small engines to gum up and get a fouled. I run 100% gas in everything. It may cost a little extra now but it will save you alot more in the long run!
Feb 26, 2011 | Craftsman Gas Mini - Tiller/Edger
Engine does not continue to run
Are you laying off the choke at any point? Full choke should only be used when starting a cold engine, it should run with no choke on full throttle. If there is not enough throttle i'd first try adjusting the tiny black screw on the carb beneath your air filter while you have it idling, letting the throttle have a little bit more room. If this doesn't work and you're running it properly than you may need to make some adjustments to the H L settings for your gas/air mix. This is also done while idling mind you and only with a clean air filter.
Apr 02, 2010 | Honda 25cc 4-cycle Mini Tiller
Engine bogs down when speed is increased.
Ok I have r Royobi Tiller (30CC Gas) And last year it ran fine after rebuilding the Carb. This year it was "hard starts" Idles fine, (Tiny whisps of blue smoke in exhaust with correct ratio) Even seems to run better with the choke "on" but still...at idle only. as soon as I touch the throttle...its bogs down in tune with how much gas I give it. Little throttle? Little bog down, Little more throttle? Almost stalls, a normal throttle rev? it stalls dead! Then starts right back up again in 1 pull and idles fine again!? WTF? So after cleaning a clean carb again, (twice) and seeing no change I thought I'd go look at the original diaphragm and compare it with the rebuild kit diaphragm (which is the one in the carb.) And guess what? The replacement has a larger rivet by a factor of "2". So basically it was flooding the carb, I bent the needle tang down, better but no cigar. But I could rev it half way now. A second disassemble to bend it yet a bit further and Vrooom vroom vrooom ****! So check your needle valve even though you think its 100%. (Especially if you rebuilt the carb with a kit!)
Mar 27, 2010 | Honda 25cc 4-cycle Mini Tiller
Roto tiller won't start - primer bulb
Carburetor needs to be rebuilt or replaced. Replaced would be my choice.
May 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Garden Logo
130 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
