Question about RTO Silicone Spray- Treadmills, Bikes, Rifles, 6.23fl-new
Where can i get unisport silcone spray for tread mill belts in a 6.23oz. aresol spray
Sears has it in 4 ounce size for about 19 bucks online.
Posted on Dec 23, 2013
SOURCE: walking belt on image 10.0 tread mill slips,
There are adjustment screws on the very back of the deck… one on each side.
1. You will need a hex wrench that came with your unit (look on the side of the deck) sometimes it is attached to a bracket or look in your plastic bag with your instruction manual. If you cannot find it, do not worry, it is a common “hex” size. Purchase a "multi size” hex wrench at the hardware store"
2. Locate the screws on the back of the treadmill on the deck "where you walk" You will see one on each side.
3. With your wrench in hand, start your treadmill on a low speed and take note of which side the belt is "creeping" to the left or right.
4. If the belt is not centered and over to the left side take your tool and adjust the screw on the left side slowly a few turns until you notice the belt creeping back to the center....usually it does not take much adjustment.
5. Once you start getting the hang of what adjusting each particular screw does to the belt....You will be a pro in no time.
6. Once the belt centered, turn off the treadmill and unplug it. Take your hand and slide it under the belt about midway. The belt should feel "snug" against the deck. If it feels too loose...use your new found adjusting skills to tighten the belt adjusting each side a few turns…unplug…checking for tightness until you feel good about it.
7. Last suggestion: Some treadmills decks need lube to help it run smooth. Without it your deck will get worn and the belt will "stick" to the deck....not good. Buy the lube a sporting goods store or at a place that sells treadmills. If you cannot find any buy some spray on graphite.
Posted on Feb 27, 2010
  • 6 Answers
SOURCE: Tread Mill Skips Jerks Every So Often
Your treadmill is trying to tell you its due for a tune-up!
Posted on Mar 17, 2009
  • 33 Answers
SOURCE: the belt on the tread mill slips while operating
hai ,check the walking belt and motor belt tension
Posted on Oct 01, 2009
maxtreadmill
  • 832 Answers
SOURCE: I need to find rubber belt for tread mill Dynafit
The only suggestion I have since this manufacturer has gone the way of the dinosaur, is by going to a local dealer that carries industrial belt of different sizes and and shapes you may get lucky and find something. I wish good hunting
Posted on May 17, 2010
SOURCE: looking for instructions to remove belt from J8 pro-form treadmil
I have a proform j8li treadmill. What size allen wrench to I need to adjust the belts?
Danielg@jcnj.org
Thanks
Posted on Apr 28, 2011
How do I tighten a slipping belt
My tread mill has a bolt on each side at the rear end that I put a hex key in and turn to tighten. Do both sides the same to keep the tread even on the track. Don't over tighten. I have a different make but most operate the same.
Oct 14, 2014 | Sportcraft Tx 4.9 Model 4041 B Walking...
Tread ajustment
under the shroud cover there is a bolt that loosens the tension on the belt...be sure the belt sensor "sees" the belt as that is why you have an E-1 error code
Dec 03, 2013 | Exercise & Fitness
Oma-002mb what the weght can this tread mill work my weght is 125kg can i trainning in this tread mill
yes you can every treadmills made for hourse training can weight for 250 lbs aprox.
Happy new Year.God bless you
Dec 31, 2012 | Star trac ST Fitness 8921 Treadmill
Where do you sray the silcon lubricate spray
Lift the running belt insert the spray nozzle, begin at the motor end spray to halfway point of the deck repeat this procedure on the other side and let the belt absorb it for about 10 min and thats it your ready got now remember when using silicon spray it needs to be applied every 30 hours of use.
May 17, 2010 | Treadmill Doctor Weslo Cadence 835...
My tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Apr 10, 2010 | Proform Exercise & Fitness
Jan 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
RTO Silicone Spray- Treadmills, Bikes, Rifles, 6.23fl-new Logo
1,223 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
