Question about Sony Playstation 3 (PS3) Console
Ps3 Can't start - correct hard disk not found
Hi i get this problem after i upgraded my 60gb Hard drive to a 320gb. At first it worked but after an hr or so when i switched my ps3 back on it gave me a message saying "Can't start - correct hard disk not found "
i have to switch the console off and on untill it finally shows me the list of user names and not the error message. ive read other reports off this online but no solid solutions.
i Have removed the drive and put it back in and also ive reformatted the drive succesfully using the ps3 format method and still no luck after a while.
Also the drive i have is an
"Western Digital Scorpio WD3200BEVT 320GB 2.5" Internal SATA Hard Drive"
please help if you can
thanks
  • 5 more comments
  • Fenners007 Aug 31, 2008
    Same Problem... Recently installed new software from Beijing Olympics game and then the other night it froze machine. Switched PS3 off at mains as nothing else worked and now i'm getting the message about my hard disk not being the correct one, every time i try to switch on!? Can also hear disk drive trying to initiate but it just makes a noise. Won't do anything!
    Do i need to send my PS3 back as its fairly new or is there a solution... please help.
  • callumdb14 Sep 11, 2008
    its getting on my nerves
  • anidada Oct 04, 2008
    I brought ps3, and after 1 month it fall down from 2.5 feet height and had a small ( small means very small ) damage on the corner of the console. It was working but after 3 month it gives me error like Can't start - correct hard disk not found.
    I took the ps3 and went to the vendor for servicing. but he took his hand up by saying " it is damage by you, and we can not take it under warranty condition.
    What i do?
  • Anonymous Jan 18, 2009
    the exact same thing happened to me n i dont wanna **** about with the hard drive ncase i do it wrong n destroy it, what can i do n please for the love of god will some one help us
  • chippee Apr 23, 2009
    I found out the problem thats causing this error. well these guys have in this link:
    http://community.eu.playstation.com/play...
    you need to add a jumper to the hard drive for it to work correctly, be carful though western digital hard drives no longer support the jumper bypass. but i got rid of my hatd drive and got a seagate brand 320gb and still got the error untill i did this and so far so good all is working.
  • chryystal May 02, 2009
    Does anyone know how to get past the damn ,Cannot Start. The Correct Hard Disk not found, message? This is driving me crazy! I have unplugged it. I have taken the hard drive out and put it back in. I have held the power button, Getting the beeps and still i get that Cannot Start. The correct hard drive not found.
    Does anyone know of annnny way that i can get past this irritating issue? Please!!!!!
  • aja1617 Jan 07, 2013
    same problem when i switched my ps3 back on it gave me a message saying "Can't start - correct hard disk not found " i don't know what to do now.
I do believe that it is a firmware issue and not a hard drive issue. If it where a true hard drive failure, your hard drive would be completely useless. Since this error only happens at start up i believe this is what happens.
1) PS3 starts-up and displays the "wave" and plays the "music"
2) The hard drive spins and the PS3 firmware is looking for the "files" on the hard drive for start-up
3) If the start-up files are not found in a certain amount of time, this message is displayed.
I may be wrong but this is my guess.
Posted on Oct 18, 2008
  • 3 Answers
Please e-mail me @ mrronahan@hotmail.com the procedure that fixes this problem is easy , no computer required.
#1 push power button ps3 powers up , wait three seconds then push and hold power button untill you here three fast chirps. wait five seconds and you will be presented with the ps3 bios page. note: if this does not work please e-mail me your sony model number as some versions require a different button configuration to be pushed thanks good luck good gaming . i can also be reached online @ LLadnar420 this is my ps3 online address for the ps3 network
Posted on Mar 23, 2009
I'm getting the same problem.....but i was playing COD4 last nite on my 40G PS3 and I switched it off midgame.....without quiting the game first and then console..... I just switched the power off....
when i came back after a while and switched on my PS3, i get this message:
"Cannot start. The correct hard disk was not found"
what do i do??? i don't know what to do now.... i cant do anything at all!!!
It doesnt even go into the menu screen....i'm just stuck with this message......
Posted on Jun 01, 2008
  • kash22 Aug 25, 2010
    dude exact thing happened to me, i was playing mw2 online everything was working normal then it froze turned it off and on the message comes up and wont eff off ..
    is there anyway around it !
  • T_Paul Mar 31, 2011
    The same thing happend to me but I was playing black ops and then I went to switch users while in the game still and it froze so I turned it off and when I turned it back on it gave me that message
The same happend with me! I soulved the problem by taking out the harddrive, en took away the dirt in the hardrive room, and it worked good after i did it:) Hope it works for the rest of you guys!
Posted on May 28, 2010
I just bought a 80GB PS3 this afternoon and I got this message the first time I plugged it in... Should I just take it back to the shop...?
Posted on Sep 13, 2008
I have the same f'ing prob, I used dust off to get all the dust out and that did the trick for awhile, but now its doing it again I used dust off and it work again. So I dont know what it really is, but that seems to work for mine, for now at least.
Posted on Jul 29, 2008
This just happened to me today, and it sucks! It seemed to be working fine this morning, but I turned it back on to play music, and I got that message! :(
So... does turning it off and on for a while get it to work again?
And does dusting it out help? How do you do that?
Posted on Jul 30, 2008
  • Gemma Jul 30, 2008
    This happened to me today. The PS3 was working great this morning while playing Oblivion, but I turned it on to play some music a little while later, and I got that message!
    So does either dusting it out, or turning it on and off help it to work? I'm kinda scared at the thought of mucking about, taking the hard drive out and stuff, so is that easy enough to do? Does that leave any damage?
I brought ps3 in may 2008, and after 1 month it fall down from 2.5 feet height and had a small ( small means very small ) damage on the corner of the console. It was working but after 3 month it gives me error like Can't start - correct hard disk not found.
What i do?
Posted on Oct 04, 2008
Umm, thats a 3200 speed hard drive? looks like one. ps3 takes 5400 speed. they are very specific on this, wont work at any other speed
Posted on Feb 27, 2009
My solution is replace your internal harddisk in your ps3 than you need to download the ps3 firmware if your in asia asia.playstation.com if your in the us us.playstation.com thats the link hope this works good luck guys
Posted on Sep 04, 2012
  • Jiun Aizaki
    Jiun Aizaki Sep 04, 2012
    oops i all most forgot you need a usb then place your download files in the usb
DEANT
Posted on Oct 27, 2008
I got the same thing i downloaded like 30 demos i think that was my problem and i was also playing cod 4 and i usually turn it off during the game but my ps3 is very dusty so its either one of those problems
Posted on Sep 03, 2008
Same thing happened to me, I turned mine off while the system was running while playing Call of Duty 4 and guess that is what caused it,. I'm aswell clueless on what to do.
Posted on Jul 16, 2008
We r in ****
Posted on Jul 09, 2008
Same thing. i just installed the same problem. but i installed the drive, i cant even get it working with a game lol. chuck_bung@hotmail.com
please help ace out!
Posted on Jul 18, 2008
I am trying to install a WD3200BEVE hard drive into a Dell Inspiron 6000 and it reads "Internal HDD Error" I received this hard drive from Dell after my previous hard drive WD600 went bad. Do I...
It's possible that the only problem is that the replacement disk-drive needs to be "initialized" for first-time usage. Or, it's possible that your Dell won't support your new _larger_ disk-drive.
Did they send you a disk-drive with _greater_ capacity than your old 60GB drive?
It's possible that they "upgraded" you, because they had no (small) 60GB disk-drives in inventory.
Take your Dell "System Restore" set of CD/DVD disks, and reinstall Windows.
The Windows Installer will "initialize" your disk-drive.
Dec 18, 2010 | Western Digital Scorpio WD600VE 60 GB Hard...
My ps3 shut off and says ... can not start the correct hard disk was not found
Have you recently upgraded the hard drive on the PS3? If so, this could be giving you a problem and a solution is posted here:
http://community.eu.playstation.com/t5/PlayStation-3-Media/Startup-Problems-After-Upgrading-To-320GB-Sometimes-Cannot-Start/m-p/4958411?view=by_date_ascending
Nov 11, 2010 | Sony Playstation 3 (PS3) Console
Ps3 cannot start. the correct hard disk was not found
Hi if you replaced your hdd or if the old went foul try this plug your controller in with the usb lead insert a game disk, put it on standby (red Light) press and hold the power pad you will hear beep,beep, then it will shut down, Do it again beep, beep then beep beep take your finger off then follow your instincts on what it says. Also you may have to replace your hard drive ,not very expensive good luck
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
PS3- cannot start. Correct hard disk not found.
when your ps3 is standing upright the tall way tip it over and look at the bottom there should be a plate that says something about the hard drive. get a flat screwdriver and pry on the right side of the plate. The hard drive is directly behind that plate and is secured by a blue screw. take out the screw and flip out the little u shaped handle and slide it to the right and pull out your hard drive. Try blowing out all the connections and putting it back in hope this helps
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
Cannot start. The correct hard disk was not found.
u will have to get a new hard drive i would get this one it is cheap http://www.walmart.com/catalog/product.do?product_id=10710953
you will have to take the cover off the hard drive.
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Ok there is only 1 500gb drive that is compatible with the ps3 and thats the Samsung spinpoint, go here to find out
http://www.1800blogger.com/2008/08/31/how-to-install-a-500gb-hard-drive-in-your-playstation-3/
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 hard disk problem
i replaced the hard drive and now it works fine. thanks for your help
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 upgrade
Yes, you can. And Sony lets you officially do that. Just for that it has a slot on the side. You just need to remove the screw and pull out the HDD. You can then replace it with any capacity 2.5" HDD also popularly known as laptop hard drives.
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
PS3 corrupted hard disk
Yes. All you need is a Seagate SATA 2.5" hard drive. It doesn't matter how many GB it has. If you have the 20GB or 60GB model of PS3 for goodness sake keep it!! That model is backwards compatible and will play PS1 and PS2 games. The 40GB unit does not have this luxury. I hope this helps you. Good luck and happy gaming!!
Aug 28, 2008 | Sony Playstation 3 (PS3) Console
My Playstation 3 will not start. It keeps coming up with an error message saying, "Cannot start. Correct hard disk is not found." Any ideas why?
Yes, You need to re-format your hard drive via your laptop or purchase a new hard drive.. sometimes they become invalid/corrupt and you need to reset it or put a new one in.. I suggest taking it out and put it back in to see if it was knocked loose if not then you need a new hd! a 60gb ps3 original via eba is 40$
Jun 19, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
34,926 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
