Back to:
Tags:
Vacuums
Generic problem for all Vacuums
Shop vac (by 3 users)
posted by wideglide on May 31, 2008
shop-vac quit working while in operation and will not turn back on. No strange noise or anything beforehand. Filter had apparently fallen off at some point but on proper reassembly, still not working.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by fishflank, posted on Jun 13, 2008
same problem. went dead and won't turn on. what do you do? take it apart but even if you find the problem can you fix it????
Comment by justin228, posted on Jun 13, 2008
I had the same problem with my Shop Vac. It just quit. Had taken it apart to see, and found power to the motor but not operating. Returned it with the same model. Three months later.....the same thing. I think Shop Vac has a problem with there motor vendor. Not sure what model number but it is a 10 gal 4 HP.
Clarification Request
by IB4G2008, posted on May 31, 2008
hmmm..sounds like either no power, or a bad switch..
Best Solution
posted on Jun 01, 2008
Thanks for Trying (70)
reddevil6
Rank:Guru Guru
Rating: 88%, 1207 votes
Could have a bad switch, bad cord, or a problem with the motor.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on shop vac:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Vacuums
bosch ergomaxx model bsg82000gb/01 bagged vacuum cleaner...
Vacuums
I am trying to connect a sansui 5000x receiver to my home...
Sanyo Permax SC-U125 Bagged Upright Vacuum
I need to replace the hose on the backside of the vacuum...
Rainbow E series Canister Wet/Dry Vacuum
i have the machine connected correctly but it wont spray...
Vacuums
Miele white star vacum cleaner - electrical cord not...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
