Question about Vacuums
How do i set the thermo sensor 433mhz to my westclox 70034 model
If you've lost the signal, press and HOLD the search button until you hear a beep. Then the number of the channel being searched will start flashing. It takes about a minute or two and then will read out the temperature.
Posted on Nov 12, 2011
Hi, First check the both channel of clock and thermometer (you can see the controler in battery insertion of thermometer and you can set up channel by pressing ch button on the clock)
Next press F/C search button until the clock find thermometer and press F/C search button again.
Posted on Nov 28, 2010
I need a manual for a westclox thermo sensor 433MHz
Posted on Feb 11, 2011
Shop vac doesn't work. Does my shop vac have a thermo fuse?
Contact the manufacturer of device. They may help you. If not, make sure that current is reaching the on/off switch and that the power is reaching the motor - if power gets to motor and still nada then the issue is probably with the brushes not making proper contact with the commutator.
Dec 23, 2016 | Shop Vac Vacuums
Why after cleaning my thermos with bleach does it no longer holds heat?
The bleach would not have affected the inside of the thermos, but it may have deteriorated the seal of the cap? Try filling it with water, cap it and turn it upside down and leave it for a few hours, see if you get a leak. Or you could submerge it in the sink and look for air bubbles.
Mar 02, 2015 | Stanley Classic Vacuum Thermos 16-Ounce...
I need a lid clip for thermos grill 2 go part no. 11-6047-012-200 model no. 4656110
You can purchase them from this site: http://www.grillparts.com/thermos/
Jun 15, 2014 | Vacuums
The remote sensor on my wireless thermo Te279NW does not record temp on inside unit
Check batteries in remote sensor and if OK try moving the sensor closer to the inside unit. Any kind of RF interference will limit the range including flourescent lighting.
Sep 07, 2011 | NexxTech Vacuums
I have Westclox Atomic Clock, Model # 70026. I have lost the instructional manual. I only activate the alarm for 6:00 AM on Sunday, then I silence the alarm by pressing the Alarm on/off button. But...
Greetings.
According to the product manual, press the 'ALARM ON/OFF' button on the back of the clock until the bell symbol and 'Zz' disappear from the display screen. These symbols are between the hour and minute digiits, above the colon ( : ).
If you would like to see the instructions, they are in .jpg format:
Front page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%201.jpg
Back page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%202.jpg
You might want to save these images on your computer in case the webpage is no longer available.
Good luck from Detroit, MI.
Jun 12, 2011 | Vacuums
I have a westclox 70034 and I need to know how to set the alarms
Push the alm1 alm2 button until your desired alarm number shows. Then hold the alm1 alm2 button for approx 3 seconds. The alarm time will flash. push the ADJ button until you reach the time hour you want. Then push the alm1 alm2 button to set the minutes. push ADL until you find the desired minutes. The push alm1 alm2 button and alrm will stop flashing. Your alarm is now set...... I to lost the manual and had to figure it out myself.
Dec 14, 2010 | Vacuums
How do i set up my westclox 70034 outdoor thermometer to read on my clock unit.
Oct 16, 2010 | Vacuums
I have an older Electrolux canister vacuum - model #2100 and the temperature sensor shuts down the motor. How to I take apart and clean?
Check to be certain the thermo lite is on and not the bag full indicator. The thermo detector is very reliable, but the bag fill valve often fails. If it is the thermo, check your hose and wand for blockage by dropping a coin through them,before opening the vac itself.Otherwise you may have a bad set of motor bearings causing the motor to overheat due to its age.
The 2100 and all its canister cousins made since 1982 seem to be prone to failure of the dial valve on top cracking internally. The causes the bag full indicator to come on and the vac to shut down.
To open the vac you will need to slide the locking keys and bumpers forward with the bag door open. Do this with a set of pliers. Once done the vac will open from front to back like a **** shell. Be careful to look at the underside hinge are of the bag door before separating and mark and locate the wiring harness . This vac only goes back together one way, perfectly assembled it pops together with ease. If any piece is out of line it`s like a RUBIKS Cube. Take your time . OEM parts are only available through an AERUS Elctrolux dealer or repair shop
Dec 14, 2009 | Electrolux UltraLux 2000 Bagged Canister...
My daughter purchased a Steam iron Make
Don a thermo fuse can generally be bought at an electronics parts store or Radio Shack type outlet in the hobby parts area. Like any other fuse they are rated specific to the requirement of the appliance, do NOT use a higher temp one.. If you have warranty, ( likely 1 year???), return the iron, If you replace it, it is generally an in line crimp. I would only attempt it once as the iron may be defective.
Sep 11, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
1,622 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
