Question about Intermatic & Indoor/Outdoor Rain Tight Timer
The timer keeps stopping when it gets to the off switch.. i changed the little switches and it still keeps stopping at off switch.
  • 4,348 Answers
Your desctiption sounds like the motor may be damaged. If the unit does not have enough power to drive past the switch triggering.
Check carefully the off adjustment, to see that it is fully seated on the dial. Thinking of hitting the lever dead on and jamming.
Posted on Oct 11, 2010
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
Why is my motor making a loud clicking noise? I have power when I switch it to the "On" position. Switching the "Off" or "On" switch does not change the clicking sound. I have not used this since I
1) Question posted under T101 Intermatic 120Volt timer.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
2) Blow out timer with compressed air.
Turn power off, and spray highly flammable WD40 vapor onto timer parts.
Wood surface will carry sound, like a guitar or violin ... apply sound deadening material between timer and wood surface.
Apply bit of white grease to motor gears.
Treat timer as any other electrical appliance and keep timer door closed to protect agains fire hazard.
3) Add comment and say what product you are talking about and what you have done so far.
Jan 05, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
Whirlpool commercial washer stopped running mid
Most likely the pump is plugged with lint, pillow stuffing, a small object, or some other obstruction which is not allowing the motor to turn.
Oct 29, 2009 | Whirlpool Washing Machines
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
Doesnt go through programs
sounds like you have a bad timer or lid switch. does it finish a cycle but not advance or does it just keep washing or does it wash then stop and get stuck? if it just keeps doing one cycle like wash wash wash you would have a bad timer. if it washes then stops and gets stuck you have a bad lid switch. But then again if you had a bad lid switch it would never spin. What is the brand name of this washer?
Jun 10, 2009 | Washing Machines
Timer not moving on clothes dryer
You need your timer switch tested and replaced.
Apr 03, 2009 | Dryers
Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Dec 13, 2007 | Washing Machines
Washer stops and make clicking sound
sounds like the timer needs a little assistance to get "over the hump". perhaps many cam switches must be switched at his point of cam rotation. if machine is getting old, then attempt to lubricate the electric motor that turns the timer mechanism. also lube the shaft bushings for the timer cam plate as well if possible.
Aug 17, 2007 | GE WHRE5260E Top Load Washer
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
63 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
